| grant965 |
 grant965 Brolly Dolly
 Posted: 14:21 - 04 Jan 2014 Post subject: Car question - using coolant, wouldnt start |
Hi all, my car, 2003 Peugeot 206 1.4 petrol 8 valve, just shy of 60k.
Been slowly using water for past month or two, only needed topping up like every 2 weeks.
This past week or so its been hard to start, resembles when starter went on my bike, clicks but nothing, then all of a sudden it would start turning over and start, usually would run fine but it once it spluttered and took a lot of throttle to get it to start, was running rough for first 20 secs or so but then was fine.
Wednesday I noticed temperature slightly higher than usual and it was slowly rising so I pulled over and checked water and was bottom of the coolant tank so I filled it up, turned it over and filled it as air bubbled out. When i was sure it was full and no more bubbling i set off.
Thursday night I go to nip out and it doesn't turn over, jumped it (thought maybe a weak battery couldn't turn over an ageing starter) from girlfriends 1.3 KA and on second try it turned over and started perfectly.
Friday morning, same again, only this time it didnt turn over when jumped. Took leads off as battery clearly isnt responsible, rocked in gear and tried to turn over, nothing again. Checked oil and water and oil is discoloured obviously because water is seeping through. But coolant tank was near enough empty, it took about 2L of water (less than previous times) and it started up fine but with one massive cloud of white smoke (presumably steam).
Ran fine to local shop then wouldnt start again, started after 5 mins and drove fine.
So my question is, is it likely that the starter has gone just as the head gasket has started leaking more or is there something else going on?
Ordered some K seal in the hope that it will at slow down the coolant leak till my mate (mechanic) is back from his holiday in a weeks time.
In the mean time if there is anyone who can replace a head gasket cheap and you are local to Preston give me a shout
Thanks for all help,
Grant ____________________ Ex bikes: 05 Suzuki En 125, '98 Yamaha Thundercat, '08 Honda cbr125, '05 Kawasaki z750, '03 Triumph Daytona 600, '91 Kawasaki ex250, '03 Hyosung Comet 125
Current Bike: '02 Suzuki TL1000R |
| Robby |
 Robby Dirty Old Man
| doggone |
 doggone World Chat Champion
| grant965 |
| Walloper |
 Walloper Super Spammer
| Walloper |
| _Iain_ |
 _Iain_ Banned
| grant965 |
| _Iain_ |
 _Iain_ Banned
 Posted: 15:43 - 04 Jan 2014 Post subject: |
I suppose really it depends on how much the cars worth to you & how much the cost of skimming is.
My car was at the time worth basicly scrap value, so wasn't too bothered. ____________________ Please be aware that the above post may be full of complete nonsense.
| grant965 |
 Posted: 15:47 - 04 Jan 2014 Post subject: |
| _Iain_ wrote: | I suppose really it depends on how much the cars worth to you & how much the cost of skimming is.
My car was at the time worth basicly scrap value, so wasn't too bothered. |
The annoying thing is I only planned on having the car till my student loan was through, was gona buy a diesel then sell this to get some money back, wont get my money through for new car for another month or two so do need this fixing, I already have the parts, gasket, new bolts, oil etc so is really just the labour and any skimming I need. Think I might strip it down this week n if i cant finish get my mate to sort it for me when hes back. ____________________ Ex bikes: 05 Suzuki En 125, '98 Yamaha Thundercat, '08 Honda cbr125, '05 Kawasaki z750, '03 Triumph Daytona 600, '91 Kawasaki ex250, '03 Hyosung Comet 125
| _Iain_ |
 _Iain_ Banned
 Posted: 15:50 - 04 Jan 2014 Post subject: |
You'll need a degree wrench, torque wrench, specialist tool mentioned for cambelt tensioner, and haynes is pretty good on walking you through it. ____________________ Please be aware that the above post may be full of complete nonsense.
| Walloper |
| Kickstart |
 Kickstart The Oracle
| grant965 |
| poleposition |
 poleposition Two Stroke Sniffer
| Walloper |
| _Iain_ |
 _Iain_ Banned
| bladerunner |
 bladerunner World Chat Champion
| poleposition |
 Posted: 08:09 - 05 Jan 2014 Post subject: |
| Walloper wrote: |
Doesn't necessarily need skimming. Ive fited hundreds of cyl. Heads to engines and only one was skimmed. Only skim to change compression ratio or if gasket surface is damaged. If warped a new head is the correct fix. As cheap as an engineer to skim. To skim also means all valve gear out. If doing that then valves would ned lapping. So not advisable. |
Skimming on certain engines is essential, otherwise premature failure will most certainly happen, wacking a new head gasket on without even checking if it needs skimming is cutting corners.
I would imagine you've cut a few corners if you've only ever had 1 head skimmed out of hundreds...
Getting back to this guys head...No you dont have to remove the valves to have it skimmed, The rockers are removed quite easily which closes all the valves.[/quote]
If the head is good ot doesnt need skimmed if worn or 'seriously' warped then skim. As I said, I fitted hundreds of heads and none failed so I dont think any corners were cut, you cheeky cunt.
Skimming will interfere with compression ratios so who's cutting corners now smart arse?[/quote]
I've been a qualified mechanic probably before you were born, I've worked in more garages than i care to remember so my knowledge comes from experience, not internet forums.
Most people don't realise they have head gasket failure until the engine has been run dry..fact! If you have done "hundreds" of head gasket jobs then the law of averages would suggest that at some point you would have dealt with a "K-series" rover engine, since this engine probably has the weakest head gasket of all engines from the past 20+ years..another fact !
Of all the head gasket jobs I've done which is an awful lot and i would probably imagine more than you (but I don't know this for a a fact so I'm guessing on the basis that every garage I worked in usually gave me the big jobs as I was the most qualified to do them ) I would say at least 35 - 40% of those head gaskets were K-series engines, and anyone that replaces the head gasket on these engines without having the head skimmed is asking for trouble..another fact.
They only make different thickness head gaskets for diesel engines, (determined by the number of notches as rightly said) since the compression ratio on a diesel is a lot tighter, but this is not because it will alter the compression ratio, It will, but the effect will be negligible since we are only talking a very small amount, It is done on diesel engines to prevent contact between the valves and piston head..
You probably can get different thickness petrol engine head gaskets, but in the real world on normal non-tuned engines they are not really required or used.
Most machine shops will stamp the amount that has been removed during skimming into the head, this is to mark the history of any work done for future reference and because you can really only skim a certain amount before you start to run into problems, this amount varies with each head.
Lastly..I'm not a cheeky C***....Just someone who knows what they are talking about..  ____________________ Ride it like you stole it! |
| bladerunner |
| misscrabstick |
 misscrabstick Crazy Courier
| poleposition |
 Posted: 15:50 - 05 Jan 2014 Post subject: |
absolutely right, If left long enough the wet liners will form a deep groove in the head on the k-series, seen it happen a few times.
They modified the head gaskets a few years ago and decided the twin gasket and shim was the way to go..Personally I still prefer the old style gasket, If done properly they will last as long as the original.
These engines may be notoriously weak as far as head gasket failure is concerned, But as i have always told people, head gaskets don't just fail on their own, they almost always fail because of another fault, coolant leak, fan switch not working, thermostat not opening etc etc, Its worth pointing out that despite this weakness they are actually great engines IMO. ____________________ Ride it like you stole it! |
| stevo as b4 |
 Posted: 16:25 - 05 Jan 2014 Post subject: |
Is one or more of the spark plugs either white on the insulator or really clean like a new plug? That's a sure way of knowing that water/coolant has been getting into the cylinders.
If your filling up the coolant expansion bottle and needing to add 2litre's a week to get the levels normal. That is a very fucked engine and it will let go at some point when your driving it soon.
My mum's old car was using water, and has the classic signs of oil spots and gunge in the coolant tank. (K-series engine). I kept topping up the coolant with say up to a pint per week near the end, and 2 non scheduled longer journey's were then driven, the second one stuck in traffic on a hot day, and well you know what happened next.
If you overheat and lose a lot of coolant to the extent that you need 2litres to re-fill, then just drive the car home and not use it until it's fixed.
It's pretty obvious that less damage is done and possibly less work is required if you sort the HGF as soon as possible. Many mildly overheated engines, may get away with a new gasket and have a nice flat head, but serious overheating will scrap a head and even a cylinder bock/bottom end if it gets hot enough, either that or if your loosing coolant into the oilways, the milky mess in the sump will not lube the bearings and seizure is quite possible.
If your all aluminium engine overheats at 80mph on the motorway, it's only fit for the bin, as it will have cooked it'self so bad everything will be warped and distorted usually. |
| Walloper |
 Posted: 18:43 - 05 Jan 2014 Post subject: |
| poleposition |
The last post was made 12 years, 317 days ago. Instead of replying here, would creating a new thread be more useful? |
