(nbr) vw passat 2.0 petrol running on 3
hmmmnz
PostPosted: 15:55 - 04 Jan 2014    Post subject: (nbr) vw passat 2.0 petrol running on 3 Reply with quote
hey kids,
well i have a bog standard b5.5 2.0l petrol passat estate,
the mrs came home the other day and said it was shuddering,
so i went out and checked it, sure enough,
plugged it in to the pc via the vag.com cable and popped a 16687 fault code which is
16687/P0303/000771 - Cylinder 3 Misfire Detected
Possible Causes
Ignition system
Fuel injectors
Fuel pressure
Running out of fuel
EVAP canister purge valve
Evaporative emission system
Low compression
Base engine problems
Controle Module damaged
*so i pulled the plug and changed it to cylinder 1 to see if it was plug related, - nope still cylinder 3,
*tested the resistance of the injector - 14ohm so normal,
*tested to see if the plug was sparking out of the engine
*did a compression test,
cyl 1 = 205psi
cyl 2= 200psi
cyl 3 = 200psi
cyl 4= 198psi
so compression seems all good,
tested that the injector was getting voltage (approx 10v) but was fluctuating because my meter wasn't fast enough to read the pulses any better, was getting the same result on all the cylinders, so ill assume its not wiring to injectors related ,
put plug back in and pulled it out a min or so later, and was wet, so injector is def getting fuel in there, whither its enough fuel is anyones guess, so failing swapping out injectors, any one got any ideas??
tl;dr
cyl 3 not firing, not sure why, give me answers
the humans are dead
I kick arse for the lord
TheCatSatOnTh...
PostPosted: 16:33 - 04 Jan 2014    Post subject: Reply with quote
I am anything but a mechanic, but if you know you have a spark, you're left with air (statistically diminishing unlikely issue) and fuel.
Our (diesel) Passat is on it's second replacement injector at 170k, so for us it's not unheard of.
Nb
PostPosted: 17:08 - 04 Jan 2014    Post subject: Reply with quote
Engine code? Ive done a lot of coil packs on b5 passats on the 20valve engine.
hmmmnz
PostPosted: 17:30 - 04 Jan 2014    Post subject: Reply with quote
its the sohc azm engine
bog standard 8valve engine, yeah feel the power
the coil pack is hidden away in the stupidest place near the back of the motor under the intake
the humans are dead
Aff
PostPosted: 17:32 - 04 Jan 2014    Post subject: Reply with quote
Vacuum leak?
Get a-sprayin' with the carb cleaner. Laughing
Electric Bike Project
Nb
PostPosted: 17:49 - 04 Jan 2014    Post subject: Reply with quote
The old square coil pack with the big heat sink in the middle, i remember those. Can you swap a ht lead round to eliminate a lead? Ive had cars where you can see a spark outside of the cylinder but its not good enough when under pressure.
hmmmnz
PostPosted: 17:51 - 04 Jan 2014    Post subject: Reply with quote
Vacuum leak?
yeah thats what im thinking now, i found this
my engine bay looks like this
https://img708.imageshack.us/img708/7035/unknownhose.jpg
i tryed to swap out a lead, but ill be fucked if i can even get my hand in there to swap the cunty thing, what a fucken stupid place to put a coil pack,
i want my vauxhall velox from new zealand here,
1 carburetor, 1 coil, a set of points and a condensor, when someting goes wrong its easy to sort
the humans are dead
Nb
PostPosted: 17:55 - 04 Jan 2014    Post subject: Reply with quote
I would of thought with a split breather hose you would have another code other than misfire. But always worth a spray around the intake i suppose.
hmmmnz
PostPosted: 18:48 - 04 Jan 2014    Post subject: Reply with quote
yeah i know, nothing makes sense,
i did have another error code that said my maf sensor was reading to high??
both things have said check vacuum lines,
so i guess its plausible, how it effects only the 3rd cylinder is frankly beyond me
the humans are dead
Nb
PostPosted: 19:01 - 04 Jan 2014    Post subject: Reply with quote
Mass air flow high is the kind of code i would expect with an air leak Thumbs Up
I seem to remember fitting some breather hoses to a similar engined passat not long ago that had the engine managment light on, the hoses are not cheap! The intake is quite easy to get off, although i just pulled it back a bit for access.
hmmmnz
PostPosted: 12:34 - 05 Jan 2014    Post subject: Reply with quote
right i think i cracked it,
i thought since its a wasted spark system, it would fire on both 2 and 3 at the same time,
so swapped lead 2 on to plug 3, and if still was running on 3 cylinders then it was going to be lead related,
if it started running on 2 cylinders then it was not, and was definite issue with cylinder 3 by itself,
what do you know it ran the same, (cylinder 2 was now dead, but cylinder 3 was running fine) also noticed that the metal surround of the lead was sparking on the rocker cover, hmmmm
i pulled the cover off and tried again, and spied this
https://i58.photobucket.com/albums/g257/hmmmnz/IMAG1154Medium_zps6deb81d5.jpg
you may not be able to see it, but in the center of the plug top there is a pin prick and a spark is escaping and earthing itself, thus taking the easiest way home rather than through the spark plug,
ive wrapped it insulation tape popped it on cylinder 3, started the car,.... ran perfectly
so there you go, f*cken metal surrounded plug ends, dumb sh*t,
mucho thanks, ill keep ya posted on any developments
the humans are dead
Nb
PostPosted: 16:06 - 05 Jan 2014    Post subject: Reply with quote
Glad you got it sorted, if you do replace the leads get a high quality set or even genuine so you wont have to be struggling for a while to change them again.
Try here for genuine stuff https://www.thetradepartsspecialists.co.uk/
raesewell This post is not being displayed because it has a low rating (Redundant). Unhide this post / all posts.
hmmmnz
PostPosted: 19:55 - 05 Jan 2014    Post subject: Reply with quote
raesewell wrote:
Post this on Passat forum
This is a bike forum
righto newbie, see the nbr at the top of the post that means not bike related, if you had posted this topic here, some one may have said post it on a passat forum, but since ive been here for ever, and i respect the opinions and experience of my fellow bikers, i'll post where i please and you can nibble on my salty balls,
any way cheers guys for the help, most appreciated
the humans are dead
The last post was made 12 years, 318 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 86.69 Kb
