CBR600RR-9 is this past repair?
andybow
PostPosted: 17:46 - 06 Jan 2014    Post subject: CBR600RR-9 is this past repair? Reply with quote
hi guys had a unfortunate low side which resulted in a broken leg, i am now fully recovered and upon inspecting my bike last night i came across this, the clutch cover is easily replaceable but the actual engine casing has worn away what are my options, if any!!! Sad cheers in advance for any help
Andy[img][/img]
SQL
PostPosted: 17:53 - 06 Jan 2014    Post subject: Reply with quote
https://upload.wikimedia.org/wikipedia/commons/8/89/Duct-tape.jpg
https://static.ddmcdn.com/gif/hammer-1.jpg
Mr. Green
PostPosted: 17:58 - 06 Jan 2014    Post subject: Reply with quote
You can't repair that in situ unless you bodge it, so I suspect the bike is now a write off.
Unless the damage is confined to a removable component (IE the sump or an engine cover) I think you're very much out of luck.
andybow
PostPosted: 18:00 - 06 Jan 2014    Post subject: Reply with quote
thats what i thought, does anyone know what the engine casing is made from, possibly a specialist welder could magic something?
misscrabstick
PostPosted: 18:26 - 06 Jan 2014    Post subject: Reply with quote
Is that a loose chain flapping abut inside? anyway, I think if you could get the outer casing off the damaged bit of the crankcase could be repaired by a talented alloy welder.
Take some detailed pictures and go and talk to some welders and see if they up for it.
andybow
PostPosted: 18:31 - 06 Jan 2014    Post subject: Reply with quote
yes it is thats my next worry, it doenst look like a cam chain, so im hoping it is just for a pump or something not detrimental 2 the bike,
thanks i was thinking that and have already contacted some fabricators, Thumbs Up
1cyl
PostPosted: 19:38 - 06 Jan 2014    Post subject: Reply with quote
Sick
That's filthy mate.
You'd need some serious welding skills to repair that. Plus even if you can, by the looks of things you've then got to get a face on it that the clutch cover gasket will seal against, and you won't know till you've spent money.
Not to mention the damage inside caused by debris/impact.
Any better pics?
Chase my Witch up, Catch my Snitch up.
The SMC | The Pit | Stable
WD Forte
PostPosted: 19:39 - 06 Jan 2014    Post subject: Reply with quote
I'd suggest you check inside that clutch cover as best you can before committing to spending.
I'd also want to know how much debris got inside and probably drop the sump too just to be sure.
How long and fast was the engine running when you came off?
The oil pump could suck air when the bikes on its side and if the motors revving away, possibly damage a bearing.
Off load for a short time, its probably fine, but it pays to check.
the broken case is quite fixable with some creative bodgineering
bikers smell of wee
PostPosted: 19:54 - 06 Jan 2014    Post subject: Reply with quote
Me, I would consider it scrap.. others may be able to fix, but me, nope. would never trust it to keep together after a repair.
andybow
PostPosted: 20:19 - 06 Jan 2014    Post subject: Reply with quote
i dont know how long and fast the engine was running after it dropped, i was in a fence Sad. thinking back when that helpful fence stopped me it was silent so it probally cut out when it dropped? i have turned the engine over just to see, this was before i noticed the hole in the casing,
Scythe
PostPosted: 20:36 - 06 Jan 2014    Post subject: Reply with quote
I'd source a second hand engine if you can, and sell that for spares.
2009 Yamaha YBR125 -> 2000 SV650S -> 2005 Kawasaki ZX6R 636
PostPosted: 20:42 - 06 Jan 2014    Post subject: Reply with quote
Buy a replacement engine from a breakers and sell the borked one to someone/anyone. Thumbs Up
PostPosted: 20:43 - 06 Jan 2014    Post subject: Reply with quote
Weld that and you'll never know if there is debris inside the bottom end and gearbox. You could ride it and it blow up after five minutes. In fact, I'm fairly certain that is what will happen.
I think you were comprehensively unlucky, and the bike is scrap. Sorry.
WD Forte
PostPosted: 20:44 - 06 Jan 2014    Post subject: Reply with quote
Cant see it that well, (phonecam? ) but as misscrabstick says
Is that a loose chain in there?
oil pump or starter gear chain maybe?
seems a bit light for a cam chain but what do I know?
I dont know the bike, but if it were mine the case repair wouldnt worry me as much as possible internal damage.
bikers smell of wee
andybow
PostPosted: 21:17 - 06 Jan 2014    Post subject: Reply with quote
yeah guys the pic was taken on a phone cam, until i saw that i thought she would be up and running in no time, felt sick almost when i saw it, whats the cost of another engine does anyone know? by what you are all saying i'm assuming you wouldn't suggest stripping the engine to see for internal damage? and i take it there is no such thing as a replacement engine case?
thanks for all the suggestions,
PostPosted: 21:21 - 06 Jan 2014    Post subject: Reply with quote
Little point in stripping it down to check for damage unless you know what you're doing, or have plenty of time to learn.
For engine prices check out eBay and fill in some of the various part finder websites.
andybow
PostPosted: 21:24 - 06 Jan 2014    Post subject: Reply with quote
it wouldnt be me stripping it, one ov my good friends is a dab hand with engines he would know what to look for, ok mate will do cheers
WD Forte
PostPosted: 22:04 - 06 Jan 2014    Post subject: Reply with quote
Replacement engine case?
Forget it
Dont try spinning it up on the starter
Just get your mate to remove the clutch cover and sump
and check it out for debris and damage.
If its saveable you can think about a new clutch cover and case repair
bikers smell of wee
davebike
PostPosted: 08:42 - 07 Jan 2014    Post subject: Reply with quote
I think the motors had it
Get a second hand engine no way would it be sensible to even try to repair that unless you are a mechanic with serious alley welding skills
Total engine strip
Welded repair to crank case
rebuild engine
I would need to charge 1000/1500 just get another engine or break for parts
Dave
Dave
NC750Xdct + others at work !
[email protected]
dydey90
PostPosted: 09:02 - 07 Jan 2014    Post subject: Reply with quote
Did you lowside onto a grinding wheel? Shocked
I'd say it can be welded, the material looks good so it's possible with the right skills and equipment.
As Dave says though, you'd need to completely strip and clean the engine, then there's no guarantee that it'll be right, or that you won't find more problems. If the bike had cut out after the crash then there could be all sorts of internal damage.
Personally, I'd give it a go if you have the time, can strip it yourself and know a good welder who you can trust. Otherwise, break it for parts.
PostPosted: 09:43 - 07 Jan 2014    Post subject: Reply with quote
It's not worth the time or effort to repair it IMO.
0l0dom0l0
PostPosted: 12:04 - 07 Jan 2014    Post subject: Reply with quote
That engine isn't going to be running without a strip down.
Personally I'd strip the engine down. You might get lucky and find that nothing else inside is fucked, in which case some new cases and a gasket set would see you fit.
Weather that's cheaper than a replacement engine from a breaker, probably not.
PostPosted: 12:37 - 07 Jan 2014    Post subject: Reply with quote
When my ZX6R engine had the clutch basket break into lots of pieces (the previous owner was doing wheelies when it broke Laughing), a very low milage replacement engine was fitted.
The engine that had died was well overdue a major service and hadn't had an easy life. The cost of the replacement engine minus what I sold the broken engine for was quite a bit less than what a major service would have cost.
Mr. Green
The last post was made 12 years, 316 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 122.98 Kb
