CBR600RR-5 Rraddiatorr: rrepairr or rreplace?
PostPosted: 13:43 - 06 Jan 2014    Post subject: CBR600RR-5 Rraddiatorr: rrepairr or rreplace? Reply with quote
Asking for a workmate.
Bit of a dribbly radiator.
Arrow £3 of Radweld.
Arrow £50 - £100 for a radiator repair.
Arrow ~£100 + import mugging + wait on a new pattern part from China.
Arrow ~£200 on probably the same pattern part from a UK seller.
Arrow ~£200 for a salvage part from a UK breaker. Shocked
Arrow ~£500 for a new Honda part. Pale
What, why, and from whom?
DrSnoosnoo
PostPosted: 13:49 - 06 Jan 2014    Post subject: Reply with quote
Try the Radweld first because it's cheap cheap cheap. Then if that doesn't work, spending 100 quid + 3 quid isn't much of a difference.
Walloper
PostPosted: 13:52 - 06 Jan 2014    Post subject: Reply with quote
Radiators are relatively easy to make. All the manufacturer would need are the top and bottom tanks.
I used to have radiators built from scratch by a company who were in Mossend. (Not sure if anyone in Glasgow area exists since Thatcher closed Scottish Industry before she was sacked from the Kremlin.)
I bet there is still somewhere regional if not local who'll make one to suit.
A quick google found this for a 1lt Nissan Micra
https://www.adrad.co.uk/prices/prices.php?id=NI393&model=MICRA&make=NISSAN
100 seems a lot for a fecking auld radiator...
And....
If doing the rad also consider overhauling/replacing the pump too. And of course all new rubber/s.
Walloper
PostPosted: 13:55 - 06 Jan 2014    Post subject: Reply with quote
Barrs Leaks work far better than Radweld.
I use it on heavy plant and gensets.
PostPosted: 14:08 - 06 Jan 2014    Post subject: Reply with quote
Get the radiator repaired. It's not worth the risk on a bike like that IMO. Plus radweld and their ilk can block up the small coolant channels in a motorcycle engine and cause problems.
Walloper
PostPosted: 14:11 - 06 Jan 2014    Post subject: Reply with quote
Barrs leaks is soluble and not harmful if used correctly.
But repair or replace as a last measure a sealant strictly as first aid.
Robby
Dirty Old Man
PostPosted: 14:18 - 06 Jan 2014    Post subject: Reply with quote
Get a used one on ebay. Ignore the buy-it-now auctions, either find someone breaking the whole bike or bid on an auction until you win one for cheap.
WD Forte
PostPosted: 15:14 - 06 Jan 2014    Post subject: Reply with quote
I agree waiting for stuff from abroad can sometimes be a chore
but this one in the USA may be worth considering.
https://www.ebay.com/itm/HONDA-2003-2004-2005-2006-CBR600RR-F5-OEM-REPLACEMENT-RADIATOR-NEW-/251414038928#shpCntId
$100 + $21.37 P&P +$30.53 estimated import duties
comes out to 92.75 GBP
There are still places in the Uk that will recore a rad but somehow I doubt you'll get much, if any, change from a oner.
You can always ask though
Depending on the location of the leak and the material of the rad
(brass/alloy/plastic) sometimes its possible to do a local repair or patch.
Never had much luck with all the magic stuff in can/snakeoil shit.
A good second hand one at a decent price with a cast iron guarantee would be nice if such a thing exists.
bikers smell of wee
charlie74
PostPosted: 15:20 - 06 Jan 2014    Post subject: Reply with quote
personal preference would be K-seal. or pricing up a re-core
lastime ( only time) ive had a rad recored it was for a jap import mpv, £150 v £350+vat and 3 week wait
so in that case it made sence, plus they added an extra layer of something to increase the cooling capacity for no extra
dydey90
PostPosted: 15:24 - 06 Jan 2014    Post subject: Reply with quote
Just bung up the leaky tubes, it's winter!
Also, I think there should have been more rrrrrr's in the thread title.
0l0dom0l0
PostPosted: 15:52 - 06 Jan 2014    Post subject: Reply with quote
Personally I'd get a new one from China. Bought some radiators for the TL 1000R From China and they're fansatic.
DrDonnyBrago
PostPosted: 17:00 - 06 Jan 2014    Post subject: Reply with quote
Depends where it is leaking from.
About 3 years ago mine was leaking from one of the corroded header tanks, so I had it TIG'd at a local radiator repair place then I painted it. Still leak free but it was a bit of a risk as the metal was so thin. Rads seem to be way overpriced, I've seen breakers asking for £100+ for crashed, bent and popped shitters.
PostPosted: 19:43 - 06 Jan 2014    Post subject: Reply with quote
Cheers, all. They do run eye-wateringly expensive and no mistake, I think I'll order / fettle up a screen for Ze Beemer while it's in my mind.
I'd hesitate to recommend a chemical sealant for a bike, although I dumped some petrol station Radweld in my C3 about 3 years back and it did the job and hasn't deaded it yet.
Bars Leaks looks interesting, I might point it out, without recommending it as such.
PostPosted: 19:56 - 06 Jan 2014    Post subject: Reply with quote
To minimise risk of it ruining the internals, could you not just remove it from the bike and block the exits of the rad off, fill with rad weld and then re-attach after you have drained the remains out?
PostPosted: 22:14 - 06 Jan 2014    Post subject: Reply with quote
Thinking Shocked
There's not enough Thumbs UpVery HappyThumbs Up for that.
Walloper
PostPosted: 22:34 - 06 Jan 2014    Post subject: Reply with quote
It needs some heat to 'cure' chemical sealant.
Something to do with heat and contact with air.
And if it was off the bike you would struggle to get circulation and heat into it.
There are no wee holes to clog in an engine. Nothing smaller than the tubes in the radiator. The only wee passage will be the bleeder hole in the temperature regulator (if is has one).
***walloper make PA***
Forum Chemists to the thread.
weasley
PostPosted: 22:40 - 06 Jan 2014    Post subject: Reply with quote
Can it not be recored?
PostPosted: 23:21 - 06 Jan 2014    Post subject: Reply with quote
Of course it can be re-cored, but why spend more than you have to?
I'd imagined that pouring boiling water into the radiator once it's off the bike should cure the gloop. If not, nothing much lost, it'd be coming off anyway for repair or replacement.
Walloper
PostPosted: 23:28 - 06 Jan 2014    Post subject: Reply with quote
It needs to circulate. Rolling Eyes Very Happy
The problem is it may just form a bolus in there when you add the hoat-wahtur.
Leave it on the beast.
Warn the engine and add the shit.
Run the engine till the fan kicks in or take it for a wee hurl.
PostPosted: 23:33 - 06 Jan 2014    Post subject: Reply with quote
Use water from kettle, close to proper water temp at the beginning of summer anyway... circulate by shaking.
cb1rocket
PostPosted: 00:40 - 07 Jan 2014    Post subject: Reply with quote
Find leak, and use a high temp sealant etc
Easter Bunny
PostPosted: 01:15 - 07 Jan 2014    Post subject: Reply with quote
I bought the ST1100 a new Copper & Zinc copy from East End Radiators in Glasgow 01415545281 at £250 delivered it was about £100 less than an original from David Silver.
I've always used Bars stop leak never failed apart from this time LOL
0l0dom0l0
PostPosted: 08:56 - 07 Jan 2014    Post subject: Reply with quote
The way I see it, is any form of crap repair on a bike like that is going to be noticed when the bike is sold on. If I was a buyer and I saw a radiatior repair I would use that as a tool to get money off.
If you spend £100 on a new one from China it seems a bit of a no brained really. I can't stress how good the rads are from China.
PostPosted: 10:47 - 07 Jan 2014    Post subject: Reply with quote
If you can see the back of the radiator on a CBR600RR while its in place, I'll eat a raw onion soaked in hot sauce Laughing
0l0dom0l0
PostPosted: 12:00 - 07 Jan 2014    Post subject: Reply with quote
I see no mention of the leak coming from the back Wink.
But general condition of the radiator regardless I suspect would be poor if it's leaking and been mended.
The last post was made 12 years, 316 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 130.03 Kb
