Regulator issue? Honda hornet.
reed
PostPosted: 21:21 - 08 Jan 2014    Post subject: Regulator issue? Honda hornet. Reply with quote
Hello people of BCF. Smile
The other day my bike died whilst riding, and then only had enough power to very slowly turn the engine over a few times.
After charging the battery, and getting it to run again, it appears that the bike will run fine until the headlight is put on, then after a few minutes the rev counter will begin to cut out, and then the bike will die and the battery will once again be flat.
Does this sound like a regulator/rectifier issue? Or maybe battery or stator related? I have a spare stator anyway, so that will go on when the new gasket goes on.
Bike is a 1999 hornet 600.
Thank you. Thumbs Up
Generic XOR 50, Gilera SMT 50, GSXR 400 GK73A, Ducati Monster 600, Honda Hornet 600.
Sold. Stolen. Written off. Sold. Current.
Paddy Blake
PostPosted: 21:29 - 08 Jan 2014    Post subject: Reply with quote
If you have a multimeter you can check if it is charging.
If you check the voltage at the battery I think it should be 13v at 3.5k revs.
Islander
PostPosted: 21:35 - 08 Jan 2014    Post subject: Reply with quote
As above, check the charging system. Battery should be around 12.5V off load (no engine, lights etc) rising to around 14v when the engine is started and revved to 4-5k. You may also have a stuffed battery as well - it should run for longer than that when it's fully charged and that may be a direct result of a reg/rec failure.
reed
PostPosted: 22:32 - 08 Jan 2014    Post subject: Reply with quote
It does seem to be charging, up until the point I turn the headlight on, then it stops charging and goes on to die.
J.M.
PostPosted: 23:11 - 08 Jan 2014    Post subject: Reply with quote
Have you checked this with a multimeter? Multimeters are very helpful when diagnosing electrical faults.
2004 R1 & 2018 XSR900
reed
PostPosted: 09:27 - 09 Jan 2014    Post subject: Reply with quote
I have and the volts do seem a little low all round, I imagine the battery is due to be changed anyway, so I think I'll do the reg/rec and put my spare stator on as well, then everything is replaced and hopefully problem solved Smile
martyn107
PostPosted: 12:31 - 09 Jan 2014    Post subject: Reply with quote
My brother had issues with his reg/rec, bit of a weak spot.
Fizzer Thou
PostPosted: 13:18 - 09 Jan 2014    Post subject: Reply with quote
I recently worked on a Hornet 600 with a similar charging problem.Once I had removed the connector to the rectifier/regulator I found the reason for the insufficient charging volts
https://i1309.photobucket.com/albums/s624/YamaBlue2/Bikes/HornetRR1_zps0d87cc6f.jpg
Once I had cleaned the connectors with WD40 and applied some silicone grease everything works perfectly.
Always have a 'Plan B'
Islander
PostPosted: 15:21 - 09 Jan 2014    Post subject: Reply with quote
Do yourself a favour and check/replace the reg/rec first. It's more likely to be that that's faulty, it's easy to get to and replace and it'll save you a heap of work replacing the stator which is probably fine.
reed
PostPosted: 17:04 - 13 Jan 2014    Post subject: Reply with quote
Well the new Reg/Rec turned up today and the problem has been solved, bike now sits at around 14 volts on idle, the new mottobat battery should be here in a day or so as well. Smile
The last post was made 12 years, 305 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 65.11 Kb
