oil filler as milky colour stuck to the tank
ukguy This post is not being displayed because the poster is banned. Unhide this post / all posts.
mentalboy
PostPosted: 23:19 - 11 Jan 2014    Post subject: Reply with quote
Just the cap or can you see if the oil is like it too?
I've had caps on cars go milky and could only put it down to some problem with the overflow setup as there was never a problem with my oil, could also be very minor influx of fluid due to crack in casing/porosity problem (If this it will not be long before you notice your oil going milky as well!)
Make mine a Corona.
Nobby the Bastard
Harley Gaydar
PostPosted: 23:31 - 11 Jan 2014    Post subject: Reply with quote
ukguy wrote:
cap and inside the tank filler
not sure if it ever had a coolant lose problem and been fixed as I only had it 2months and the person I brought from said he got it from a dealership
when I empty the old oil it was just black and I replaced the oil because it was black
Check the breather from the engine and the air box/air filter.
Sometimes if these are blocked/kinked, water vapour can get trapped by the oil cap, causing mayonaise.
N.B. Mayonaise is the correct term. It's an emulsion of water and oil....
Triumph Sprint ST 1050
Nobby the Bastard
Harley Gaydar
PostPosted: 23:52 - 11 Jan 2014    Post subject: Reply with quote
The biggest cause of mayo is too short journeys. The engine doesn't get hot enough and doesn't get rid of the water that naturally collects on things that warm up.
Assuming that nothing else is wrong, the best thing you can do is make sure that it gets up to temperature every time you use it.
PostPosted: 13:12 - 12 Jan 2014    Post subject: Reply with quote
ukguy wrote:
well I use it 50 miles a day and it always gets halfway on temp
also I not sure if this is a bad sign but I started it up and open filler cap for oil and theres air coming out Shocked is it post to do this
Yes it's supposed to do it to a small extent - that's why engines have breathers. If the oil itself is black when you drain it, and the coolant level is not dropping, then stop worrying.
Piercee100
PostPosted: 13:13 - 12 Jan 2014    Post subject: Reply with quote
I've had this on bikes and scooters. Its just condensation mixing with the oil. For some reason my GT550 is bad for it but it does live outside. The moisture couldnt come from anywhere else, being air-cooled.
Again, mostly short trips are the problem.
Rides: Honda H100a (Retired), VT500e (Sold), Kawasaki ZX400 (sold), Kawasaki GT550 (Sold), Suzuki Inazuma (Daily), Honda CD185t (Broken), LML Star 2t (Last run edition).
PostPosted: 13:27 - 12 Jan 2014    Post subject: Reply with quote
Remove the bolt and measure the length. Now poke something down the hole and measure the depth. If the hole depth is 9mm or more deeper than the bolt is long (assuming an M6 bolt here) then you have the standard 1.5D thread engagement to simply use a longer bolt. Just make sure it doesn't bottom out in the hole. TBH I would still do this at 1D but I'd be very careful not to over-tighten the bolt.
The last post was made 12 years, 285 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 69.9 Kb
