| drbaig |
 drbaig Crazy Courier
 Posted: 14:53 - 16 Jan 2014 Post subject: thundercat caliper pistons. |
Brakes were binding so pushed the pistons out, cleaned them and bleed the lines. Didn't make any difference as the bottom two are jammed so still rubbing.
Decided to rebuild the calipers. Now I have a piston out from each caliper by blowing air into it, but now the pressure is lost I cant get the others out. They are properly stuck.
Any solutions.
Thanks ____________________ yzf 600r  |
| weasley |
 weasley World Chat Champion
| P.addy |
 P.addy Red Rocket
| weasley |
| P.addy |
 P.addy Red Rocket
 Posted: 15:18 - 16 Jan 2014 Post subject: |
Oooh, didn't realise they were different! Never seen one without the pipes  |
| drbaig |
 Posted: 16:00 - 16 Jan 2014 Post subject: |
I was able to bleed the calipers fine. Just can't seem to get the pistons out. Haynes suggests doing one side at a time but the bottom ones are jammed stuck plus I don't want to buy new pistons.
Any suggestions other than destroying current pistons trying to get them out. ____________________ yzf 600r  |
| Robby |
 Robby Dirty Old Man
| temeluchus |
| Fizzer Thou |
| totalllama82 |
 totalllama82 Crazy Courier
| mcyoungy66 |
 mcyoungy66 L Plate Warrior
| weasley |
 Posted: 21:44 - 16 Jan 2014 Post subject: |
That'll work if the two free pistons are opposite each other.  ____________________
Yamaha XJ600 | Yamaha YZF600R Thundercat | KTM 990 SMT | BMW F900XR TE |
| Islander |
 Islander World Chat Champion
 Posted: 22:27 - 16 Jan 2014 Post subject: |
| drbaig |
 Posted: 00:07 - 17 Jan 2014 Post subject: |
I am going to try taking the dust seals out of the two top pistons I have already managed to get out by pumping air through the union bolt hole.
Then put the top two pistons back in and clamp three to get one of the bottom one out. Then remove the dust seals from that one put it back in and do the same thing for the final one.
Hopefully one seal shouldn't create too much of a problem, just prying them out with fingers. Or clean two at a time, fit them back and try two at the bottom. Or do them one by one cleaning and replacing the seals.
Lets see how it goes tomorrow.
Plus the speedo cable has snapped, I have heard that it can be changed by just taking the screen off with the top black plastic inside fairing bits and the gauge cluster. But It is brakes first. One problem at a time.  ____________________ yzf 600r  |
| StevenF |
 StevenF World Chat Champion
| drbaig |
 Posted: 13:38 - 17 Jan 2014 Post subject: |
I actually forgot to ask. Is there a specific way the seals go in (upside and downside). Like are they perfectly Square or is there a slight lip that creates the seal with the caliper and the piston. I've already done one caliper. Do I need to go back  ____________________ yzf 600r  |
| drbaig |
| Fizzer Thou |
 Posted: 18:48 - 17 Jan 2014 Post subject: |
I have only heard of Suzuki piston seals having a certain way that they must go in.Of all of the calipers that I have serviced I have never seen this on any seals.
If you do not have any red seal grease you can always use fresh brake fluid.
DoT4 brake fluid at Asda is £4 for 500ml
If when bleeding the brakes, remove the caliper from its mounting and lift it as high as you can get it and hold it there for a few minutes.Any air in the lines will go to the caliper,which you should then be able to bleed successfully. ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
| drbaig |
 Posted: 23:27 - 17 Jan 2014 Post subject: |
I cut the old inner seal to check if they were square which they were so went ahead and did the rest.
Managed to clean and fit new seals. One by one, what a pain. Wedged the pliers between two opposite each other and clamped one whilst pumping air in the union bole hole.
They needed a proper good cleaning. The groves were covered in dried salt, brake dust and god knows what else behind the dust seals for the bottom pistons. Just because of the oily mess I'd rather pay someone to do forks and brakes.
Have bleed the system but there were millions of tiny bubbles in the end. So now I have tied the brake lever to the bar and left it. Will bleed again after those tiny ones have got together to make big ones. Job should be done then I guess.
Dot4 is even cheaper on eurocarparts. 500 for 2.40 i think. ____________________ yzf 600r  |
The last post was made 12 years, 288 days ago. Instead of replying here, would creating a new thread be more useful? |
