Unstable after hitting pothole
DickVanWinkle
PostPosted: 16:29 - 18 Jan 2014    Post subject: Unstable after hitting pothole Reply with quote
Hi people, I think I've got a problem.
See, about a week ago, I tried to avoid a pothole in a corner, but the rear wheel still went in and I nearly came off.
Since then, the bike has felt unstable, especially in right-hand corners. I think it may also be pulling to the left, but that could just be my poor balance.
I've tried fiddling with the wheel alignment, but other than that I don't know what else it can be.
So, any suggestions?
Current Steed: Kawasaki GPX 250R
ukguy This post is not being displayed because the poster is banned. Unhide this post / all posts.
Alpha-9
PostPosted: 17:32 - 18 Jan 2014    Post subject: Reply with quote
check rear wheel alignment
Fzr-600 1999
Clutchy
PostPosted: 18:37 - 18 Jan 2014    Post subject: Reply with quote
Is the rear wheel buckled?
TheCatSatOnTh...
PostPosted: 19:38 - 18 Jan 2014    Post subject: Reply with quote
Have you tried checking your tyre pressures too.
PostPosted: 02:41 - 19 Jan 2014    Post subject: Reply with quote
I'd be checking the alignment and also checking the tyre bead is sitting fully on the rim all the way round.
Front wheel didn't go in? Because the forks can twist in the yokes after a hard bash too.
poleposition
PostPosted: 12:45 - 19 Jan 2014    Post subject: Reply with quote
If it feels unstable after hitting a pothole then you've clearly done damage somewhere...dont ride it...get it checked properly if your not sure what your looking for.
my guess is either the wheel is badly buckled..or its been forced to one side in the swinging arm..possibly both. if its been forced to one side then clearly it wasnt tight enough..but that alone would just cause the bike to crab..obviously the chain would be misaligned too..
Ride it like you stole it!
daffy
PostPosted: 13:15 - 19 Jan 2014    Post subject: Reply with quote
get it on a paddock stand and give the wheel a spin.
2000 zx6r
a b be b1 c ce c1 c1e f k p 10m swimming
Islander
PostPosted: 13:41 - 19 Jan 2014    Post subject: Reply with quote
Simple stuff first, check the tyre pressures. Wheel alignment is straightforward. Measure the distance between the centre of the swingarm pivot and the centre of the rear wheel spindle on each side of the bike and make sure they're exactly the same, Check that, then check the front end to make sure the forks haven't twisted in the clamps.
DickVanWinkle
PostPosted: 13:58 - 19 Jan 2014    Post subject: Reply with quote
Well, I have tried to align the wheel using the markings on the swingarm, but it still didn't feel right.
But I've just used the String Method, and it turns out the markings are at least a half off - that probably didn't help.
Anyway, just taken it for a quick spin, and all feels fine again.
Also, I think the bead is seated fully, and the pressures were correct.
I don't think so, but I don't suppose there's a way I can check that by myself, is there?
Checked that yesterday - slackened off all the relevant bolts and re-tightened again.
Anyway, thanks for all your help
Eddie Hitler
PostPosted: 18:21 - 19 Jan 2014    Post subject: Reply with quote
Yeh, you can spin it. Laughing .
DickVanWinkle
PostPosted: 21:24 - 19 Jan 2014    Post subject: Reply with quote
Funnily enough I had that idea myself Laughing . I was just wondering if there was a more accurate way of telling if it was buckled - seems to be fine though.
Anyway, went for a longer ride earlier and it's much better after a 'proper' alignment.
Thanks for all the help, Gents.
kramdra
PostPosted: 22:27 - 19 Jan 2014    Post subject: Reply with quote
Im not sure what kind of abuse it takes to kill wheel bearings. I would expect them to be damaged before alignment became a problem?
Alpha-9
PostPosted: 11:41 - 20 Jan 2014    Post subject: Reply with quote
Where d'you get that logic? Easier to knock something out of alignment than deform metal parts, i'd imagine
He already said alignment solved it anyway, i'm a weeeenerrr!
Fzr-600 1999
dydey90
PostPosted: 12:07 - 20 Jan 2014    Post subject: Reply with quote
Stick a clock on it?
Islander
PostPosted: 12:27 - 20 Jan 2014    Post subject: Reply with quote
Easier still use a stick of chalk held firm against the swingarm and not quite touching the rim, then spin and see if it marks the rim anywhere or if the gap obviously increases. Smile
dydey90
PostPosted: 12:31 - 20 Jan 2014    Post subject: Reply with quote
https://static.fjcdn.com/gifs/yao+ming+meme+cowboy+laughing.+yao+ming+meme+cowboy+laughing_04d36d_3638880.gif
Islander
PostPosted: 12:34 - 20 Jan 2014    Post subject: Reply with quote
A lot cheaper than buying a dial test indicator (if you don't already have one) that you're unlikely to use that often and quite effective. Razz
iooi
PostPosted: 13:12 - 20 Jan 2014    Post subject: Reply with quote
So it was all right before the crunch.
So we take it that OP was using markings on swinging arm before and matching up.
With no handing problems.
Since crunch it is now 1/2 a mark out....
That would say to me that swinging arm may have a issue of being broken/cracked or pulled out of alignment (bearings)
So this needs further investigation. Before something snaps.....
Alpha-9
PostPosted: 21:35 - 20 Jan 2014    Post subject: Reply with quote
Insightful Thumbs Up Karma
Seems weird anyway, having off centre alignment has never caused me any serious instability on my shitty 125s at least
Fzr-600 1999
The last post was made 12 years, 265 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 107.3 Kb
