Can/should I use Shell V Power Nitro,etc in my RD125LC
Learnatic
PostPosted: 20:37 - 18 Jan 2014    Post subject: Can/should I use Shell V Power Nitro,etc in my RD125LC Reply with quote
Hi there,
I've just bought myself a totally refurbished 1986 RD125LC mkII (YPVS & de-restricted), which I'm extremely chuffed with to say the least!
I know it will run fine on 'normal' unleaded but I was wondering if any of you might be able advise whether it's safe, or recommended, to use Shell V Power/BP Ultimate type fuels, or are they likely to do more harm than good?
Kind Regards
Chris
RD125LC Mk 2.5 1986 Full Power YPVS
TZR125 1992 Full Power YPVS
PostPosted: 20:51 - 18 Jan 2014    Post subject: Reply with quote
Super unleaded is just 98 RON fuel, but V Power and the like claim a few other things.
If it is safe to run on 95 RON fuel (standard they are, so unless someone has raised the compression it should be fine) then there is no gain from using higher octane fuel. Indeed possibly a very slight loss of power.
As to vpower, etc, they make a few claims but not sure useful they are.
One difference could be ethanol content, but finding out which (if any) fuels have high ethanol contents is difficult.
simonjb
PostPosted: 21:23 - 18 Jan 2014    Post subject: Reply with quote
It shouldn't make MUCH difference, unless as Kickstart said, the compression has be altered. If you're concered with long term cost go for standard unleaded, but if you notice any knocking or unusual engine vibration, change it to higher octane fuel such as Nitro+, BP Ultimate or any 97+ RON fuel. Whatever you do, make sure you don't go for cheap supermarket brands, the real difference is not between Shell (or BP) regular vs. super, but between cheap fuel and dedicated companies.
For my 4-stroke YBR I personally use nitro plus whenever I go to shell, because it has additives to help the engine stay healthy*, it gives me a hint more power, and ups my MPG by around 5-10 MPG (Difference between 115 and 125). As the price difference for a 10L fill up is not that much, it does seem worth it to me.
*Here's an article on the actual difference
Current Bike: 2008 Yamaha YBR 125
pdg
PostPosted: 21:50 - 18 Jan 2014    Post subject: Reply with quote
Because the supermarkets don't buy fuel on the open market from the exact same refineries as the 'big brands' (and small independent operators).
What supermarkets do is make their own fuels from liquidised owls, then add grit and wear accelerating additives.
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
Northern Monkey
PostPosted: 21:55 - 18 Jan 2014    Post subject: Reply with quote
and the tortured souls of murdered kittens
simonjb
PostPosted: 22:17 - 18 Jan 2014    Post subject: Reply with quote
Supermarket brands aren't "bad" as they all have to conform to EU standards, but they do differ quite significantly depending on where you go, there is a difference in quality. They do all come from the same base product, but the differences come from the different additives and final product RON. Fifth gear tested this - as well as many more reputable sources, whilst it won't damage an engine, it doesn't help with economy, power, or engine life.
PostPosted: 22:25 - 18 Jan 2014    Post subject: Reply with quote
simonjb wrote:
Aaa, so the lubricant in the fuel is doing a far better of job of lubricating the piston against the cylinder wall than the 4 off litres of oil sloshing around the engine at the same time (That's designed specifically for the job). This lube is also resistant to the 600 odd degrees of combustion temperature.
The article also mentions you could run an increased compression ratio, but doesn't touch on what this is, or how it could be altered.
PB ran an article on 95, 98 and 110 octane fuel a few years back. The conclusion was that it's not worth bothering unless you're racing or running a tuned engine that requires it. The test bike was a 2004 CBR600RR if I remember rightly on BSD's dyno.
PostPosted: 22:38 - 18 Jan 2014    Post subject: Reply with quote
The higher RON is pretty much irrelevant for anything without a knock sensor (so irrelevant for most non turbo engines), as it cannot be taken advantage of.
From memory the 5th gear test only got any noticeable change in performance from a couple of turbo cars.
I suspect the YBR min octane requirements are a long way below the normal unleadeds 95 RON rating.
Learnatic
PostPosted: 14:50 - 19 Jan 2014    Post subject: Reply with quote
Thanks for the replies guys. Wink
I'll stick with the BP regular unleaded then (or use Ultimate, if I have any pops/bangs/burps/farts).
Chris
The last post was made 12 years, 169 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.76 - MySQL Queries: 13 - Page Size: 65.94 Kb
