| Learnatic |
 Learnatic Derestricted Danger
 Posted: 20:51 - 18 Jan 2014 Post subject: |
Super unleaded is just 98 RON fuel, but V Power and the like claim a few other things.
If it is safe to run on 95 RON fuel (standard they are, so unless someone has raised the compression it should be fine) then there is no gain from using higher octane fuel. Indeed possibly a very slight loss of power.
As to vpower, etc, they make a few claims but not sure useful they are.
One difference could be ethanol content, but finding out which (if any) fuels have high ethanol contents is difficult.
| simonjb |
 simonjb Nova Slayer
 Posted: 21:23 - 18 Jan 2014 Post subject: |
It shouldn't make MUCH difference, unless as Kickstart said, the compression has be altered. If you're concered with long term cost go for standard unleaded, but if you notice any knocking or unusual engine vibration, change it to higher octane fuel such as Nitro+, BP Ultimate or any 97+ RON fuel. Whatever you do, make sure you don't go for cheap supermarket brands, the real difference is not between Shell (or BP) regular vs. super, but between cheap fuel and dedicated companies.
For my 4-stroke YBR I personally use nitro plus whenever I go to shell, because it has additives to help the engine stay healthy*, it gives me a hint more power, and ups my MPG by around 5-10 MPG (Difference between 115 and 125). As the price difference for a 10L fill up is not that much, it does seem worth it to me.
*Here's an article on the actual difference ____________________ Current Bike: 2008 Yamaha YBR 125 |
| pdg |
 pdg World Chat Champion
| Northern Monkey |
 Northern Monkey World Chat Champion
| simonjb |
 simonjb Nova Slayer
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 22:25 - 18 Jan 2014 Post subject: |
Aaa, so the lubricant in the fuel is doing a far better of job of lubricating the piston against the cylinder wall than the 4 off litres of oil sloshing around the engine at the same time (That's designed specifically for the job). This lube is also resistant to the 600 odd degrees of combustion temperature.
The article also mentions you could run an increased compression ratio, but doesn't touch on what this is, or how it could be altered.
PB ran an article on 95, 98 and 110 octane fuel a few years back. The conclusion was that it's not worth bothering unless you're racing or running a tuned engine that requires it. The test bike was a 2004 CBR600RR if I remember rightly on BSD's dyno. ____________________ My Flickr |
| Learnatic |
 Posted: 14:50 - 19 Jan 2014 Post subject: |
Thanks for the replies guys.
I'll stick with the BP regular unleaded then (or use Ultimate, if I have any pops/bangs/burps/farts).
Chris ____________________ RD125LC Mk 2.5 1986 Full Power YPVS
TZR125 1992 Full Power YPVS |
The last post was made 12 years, 167 days ago. Instead of replying here, would creating a new thread be more useful? |
