DT125 INDICATORS WON'T FLASH
ben_121_uk
PostPosted: 23:36 - 28 Dec 2004    Post subject: DT125 INDICATORS WON'T FLASH Reply with quote
I hope someone can help me out with some advise. I have just purchased a set of mini indicators for my 1997 DT125R. When i'd finished fitting them they wouldn't flash. Then i re-fitted my standard ones and hey presto..............they flash!!! Quite obviously a compatibility issue. Does anyone have a fix for this????
Lone-Wolf
PostPosted: 23:56 - 28 Dec 2004    Post subject: Reply with quote
Wotcha.
Check the wattage, it's stamped on the bulb somewhere.
Standard ones will be rated at 21 watts, the mini ones will be about 10 watts or less.
Cheers.
L.W. - www.moonshiners.org.uk
ben_121_uk
PostPosted: 00:46 - 29 Dec 2004    Post subject: Reply with quote
Thanks for that. will changing the bulbs cure the problem?
Git
PostPosted: 08:23 - 29 Dec 2004    Post subject: Reply with quote
Said in Lone-Wolf styleee wrote:
Wotcha
They should do
When you say they do not flash do you mean they do not illuminate at all or they are permanently on, but just not flashing, if the latter then a bulb change will do the trick, if the former, I do not know.
satans_BIG_helper
PostPosted: 13:00 - 29 Dec 2004    Post subject: Reply with quote
Most mini indicators... have crap bulbs in them and are 10 w and usually dont work on a bike straight off i would personally change the bulbs and then it should work with no problems...
ben_121_uk
PostPosted: 14:37 - 29 Dec 2004    Post subject: Reply with quote
unfortunatley i can't get bulbs of this size in 21w the nearest i can get is 5w the actual bayonet end is quite small. Brick Wall Does anyone know of any other ideas. flasher unit maybe?
daz|n00by
The Internet
PostPosted: 15:07 - 29 Dec 2004    Post subject: Reply with quote
just get a uprated flasher unit i had the same prob and it cost me £3.50 for a upgraded flasher unit m8 takes 2 mins to swop over,
infact when i bought the mini flashers the shop asked me if i wanted the flasher unit aswell as the said it would be needed easy fix Smile
hope it helps you
ben_121_uk
PostPosted: 15:11 - 29 Dec 2004    Post subject: Reply with quote
Any idea where i can get an uprated flasher unit from? i live in dudley in the midlands?
daz|n00by
The Internet
PostPosted: 15:17 - 29 Dec 2004    Post subject: Reply with quote
strretbike or speedaway m8 i got mine from speedaway as i only live 2 mins from the shop Smile speedaway is in blackheath and streetbike is at the top of mucklows hill
Git
PostPosted: 15:20 - 29 Dec 2004    Post subject: Reply with quote
You could always go up a size in bulb, maybe 23w depending on the bulb type, I have some old minis here with 23w ba9s in them, worked well from memory.
https://www.vehicle-wiring-products.co.uk/VWPweb2000/lights-3/lights-3.html
ben_121_uk
PostPosted: 18:36 - 29 Dec 2004    Post subject: Reply with quote
Thanks to everyone for the advise. I went to speedaway but they had sold out of flasher units but luckily they had some 23w bulbs and they work a treat. so once again many thanks to everyone. Laughing
daz|n00by
The Internet
PostPosted: 22:17 - 29 Dec 2004    Post subject: Reply with quote
were in dudley r u ben ? i may see u about some time and show us a pic of your bike so i can look out for you while i wait to get mine uk registered
Lone-Wolf
PostPosted: 00:00 - 30 Dec 2004    Post subject: Reply with quote
Wotcha.
Looks like they did you a favour - bulbs are cheaper and easier to replace than the flasher unit Laughing besides, a brighter (23 Watt as opposed to a 5 Watt ) is a definite bonus too.
Cheers.
daz|n00by
The Internet
PostPosted: 00:59 - 30 Dec 2004    Post subject: Reply with quote
£3.50 is to much ??? hmmm ok easy to change bulbs than a flasher unit ? hmm ok again personely i would rather pull 2 wires of a flasher unit than unscrew 4 sets of indicators of and change the bulbs then put them back together buts trhats my opinion
ben_121_uk
PostPosted: 11:16 - 30 Dec 2004    Post subject: Reply with quote
Daz, as requested pics of my bike. If you follow this link you can have look. Post some of yours on there so we can all have a look. What bike have you got?
ben_121_uk
PostPosted: 11:17 - 30 Dec 2004    Post subject: Reply with quote
ooops forgot the link!!!
Here it is
https://www.bikepics.com/members/warrenbennison/97dt125r/
Try that
daz|n00by
The Internet
PostPosted: 18:30 - 30 Dec 2004    Post subject: Reply with quote
nice looking bike Thumbs Up i gotta sort some piccys out for my bikes i got 1 project atm thats the tuerag i gotta get uk register (thats the tuerag wind the big one thats like the paris dakar style)and i got the tuerag rally that my son uses there is also the scoot that my youngest had of santa Razz btw nice to see your in the same age bracket as me i dont feel like Victor Meldew half as much now i know their are 30 year olds plus on here
Lone-Wolf
PostPosted: 20:09 - 30 Dec 2004    Post subject: Reply with quote
Wotcha.
That depends on where you buy the unit from. A normal flasher unit may only be a few quid, but most bike shops like to take advantage and charge a lot more for a 'special' flasher unit that can cope with low wattage bulbs.
To someone who knows what they are doing, electrical-wise, then maybe it is easier to change the flasher, but if you don't know where / what the thing looks like, then changing bulbs would be the best option.
Cheers.
ben_121_uk
PostPosted: 21:45 - 30 Dec 2004    Post subject: Reply with quote
Daz, I know what you mean. When i posted on here regarding a 125 i expected replies from 17 year olds but it seems everyone is more mature like ourselves (old gits). Anyway i bought the DT a couple of months ago to do a bit of green laning, as of yet its only seen tarmac. All the tracks we used to use when we were 17 have now turned into housing developments or been blocked off. I can see you are into that sort of bike aswell, any ideas where to go for a bit of off road fun??
daz|n00by
The Internet
PostPosted: 01:56 - 31 Dec 2004    Post subject: Reply with quote
lone wolf your point is taken m8.
ben i dont think their is to many places left for green laning m8 but i was going to try and find some routes up on clent hills in the spring maybe some of the old mountain bike tracks are still left with a bit of luck, if not looks like going a bit further out maybe we can both go and look fools getting shouted at by some angry farmer Wink [/i]
"Its Better To Burn Out Than Fade Away!!!!!!" "Lifes a bitch and then you Die"
"I`m a tool, one with just enough intelligence to know it, just enough spirit to resent it...but not enough backbone to do anything about it. " Siggi 2006 pure class. Smile
ben_121_uk
PostPosted: 11:35 - 31 Dec 2004    Post subject: Reply with quote
Daz, Sounds good. stay intouch....
The last post was made 21 years, 322 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 109.99 Kb
