diedel geeks not starting when cold
dransy
PostPosted: 10:07 - 20 Jan 2014    Post subject: diedel geeks not starting when cold Reply with quote
Are lasses 1.9 soda fabia sdi isn't starting when its cold out , it did this last year so u got a battery from my mates Renault espace a year later this cold morning was about minus 2 and it won't start again .
I know for a fact when I get home and its a few degree warmer it will start straight up .
Can anyone tell me what's going on.as it makes her late.for.work quite often .
Islander
PostPosted: 10:08 - 20 Jan 2014    Post subject: Reply with quote
Glow plugs?
Shaft
PostPosted: 10:09 - 20 Jan 2014    Post subject: Reply with quote
Glow plugs, multiple or total failure.
Could be the plugs or the control unit, needs a diagnostic ideally.
dransy
Don't know much about diesels should I just change them ? I presume you change em like spark plugs ?
Islander
PostPosted: 10:17 - 20 Jan 2014    Post subject: Reply with quote
I'd check that the glow plugs are getting 12v from cold initially. It's not unknown for the control relay to fail. You can do a resistance check on them - it may only be one or two that have failed although checking current flow is the approved way.
This may help:
https://www.ngk.de/en/technology-in-detail/glow-plugs/maintenance/testing-glow-plugs-the-right-way/
dransy
PostPosted: 10:34 - 20 Jan 2014    Post subject: Reply with quote
thank you sir , what do I set my multi meter to ? I've only used it to check the power of batteries Smile
Islander
PostPosted: 10:50 - 20 Jan 2014    Post subject: Reply with quote
To check whether they're getting voltage, use the same as you use for battery checks. Remember they're only active when the engine is cold though. If they aren't getting voltage then check the relay.
To do a resistance check, you'll need to use one of the resistance ranges (ohms) it'll be a very low resistance typically somewhere between 0.1 ohms and, say, 8 ohms. A high resistance indicates a failed plug.
WD Forte
PostPosted: 11:09 - 20 Jan 2014    Post subject: Reply with quote
Yep
As above, sounds like glow plugs, thats the most common reason.
Some indirect injection lumps ( like in my van) just wont play unless the glow plugs are AOK.
Just to add to the testing tip
Each one should have a low resistance in the range Islander mentioned but be aware thats each plug on its own
and not connected to any other
so to test each one, you'll need to remove the heavy cable connecting them together.
just in case you dont know.
Most deisels have a yellow light on the dash that glows
when the relay is providing power to the glow plugs.
This shortish period is when you can do the voltage test on the supply cable to check the relay is working
bikers smell of wee
Wabby
PostPosted: 20:55 - 20 Jan 2014    Post subject: Reply with quote
Faulty CTS if plugs check out OK.
Moder diesels rely on them far too much.
What restriction?
dransy
PostPosted: 07:47 - 21 Jan 2014    Post subject: Reply with quote
Replaced all the plugs yesterday 3 of them looked knackered juiced up the battery and it started like a champ this morning Smile
The last post was made 12 years, 266 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.98 - MySQL Queries: 13 - Page Size: 65.42 Kb
