Yamaha ybr125 aftermarket exhaust
markrolls88
PostPosted: 20:38 - 21 Jan 2014    Post subject: Yamaha ybr125 aftermarket exhaust Reply with quote
Hi I have a 2010 yamaha ybr and I'm wanting to buy this exhaust for it which I know it will fit my bike but on the original exhaust there is a pipe that comes out of the silencer part of the exhaust but this dosnt have that so what do I do with that
sparky
Az
PostPosted: 20:50 - 21 Jan 2014    Post subject: Reply with quote
Pictures?
Your description's pretty poor tbh, from what I can make out it sounds like you're describing a removeable db killer. I doubt a YBR would have a removable db killer in the standard exhaust though.
Edit: Did you possibly mean that your new aftermarket exhaust has a "pipe that comes out of the silencer part of the exhaust" ?
markrolls88
PostPosted: 21:07 - 21 Jan 2014    Post subject: Ybr Reply with quote
Sorry the picture is a eBay item number you'll see what I mean look at a standard Yamaha 2010 exhaust they have a pipe coming out of them the Leo Vince one dosn't so what do I do with that pipe but I have checked the specs of that pipe and they fit 2010 ybr 125's so I don't get it
sparky
flumpy7
PostPosted: 21:45 - 21 Jan 2014    Post subject: Reply with quote
Still no picture.....no offence but you're not making a lot of sense
2012 Sinnis apache
YBR Ric
PostPosted: 22:23 - 21 Jan 2014    Post subject: Reply with quote
Remove side panels to access seat bolts, remove seat.
Remove all SAI pipework exiting from the top of the air box and seal up the open spigot with a suitable bung.
Refit seat and side panels and ride bike.
markrolls88
PostPosted: 09:11 - 22 Jan 2014    Post subject: ybr Reply with quote
this first one is the same as my exhaust you can see there is a pipe coming out of it https://www.ebay.co.uk/itm/2010-Yamaha-YBR125-YBR-125-Complete-Exhaust-System-Cheap-Needs-Repair-Breaking-/321295893990?pt=UK_Motorcycle_Parts_13&hash=item4aceba45e6
and this one is the one i want to buy so what do i do with that pipe cos if that pipe goes back into the engine there will be a hole
https://www.ebay.co.uk/itm/Yamah-ybr-Leovince-cobra-race-exhaust-/181306931143?pt=UK_Motorcycle_Parts_13&hash=item2a36bc37c7
sparky
pdg
PostPosted: 09:36 - 22 Jan 2014    Post subject: Reply with quote
If you don't know - or can't be bothered to find out - how to bypass an EGR system (or whatever yamaha call it this week) then you should consider sticking with the standard exhaust. Why are you wanting to replace it anyway, is it rusty/broken or just 'because race bike'?
To be fair, putting a 'race' pipe on without other work will likely only achieve 4 things - 5mph lower top speed, slower acceleration, more noise, you'll look like a twat.
There is a lot you can do to a 125 to improve matters somewhat, but if you're stumped by a scavenge pipe then it's probably over your head.
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
markrolls88
PostPosted: 09:51 - 22 Jan 2014    Post subject: ybr Reply with quote
the exhaust on mine has split open and its £300+ for an original and only £100 for the after market exhaust i just dont understand what i would do with that pipe will i be able to get instructions any where or should i take it to a garage will they know how to do it and will it still run the same with that pipe missing
sparky
pdg
PostPosted: 10:04 - 22 Jan 2014    Post subject: Reply with quote
Following a 30 second search I found out that it's not actually an EGR, but the removal is very similar. I really can't be bothered to do any more research into a bike I'll never have.
Back in the old days we had a system.
Read the manual.
Look at the parts.
Assess the possible implications.
Experiment.
Not always in that order, and quite frankly the 'read the manual' section didn't always happen (sometimes the library didn't have the right manual in stock).
Of course, 'the old days' were before the internet, so we knew what a library and a manual were and I suppose the lack of spoon holders meant we had to think about things for ourselves...
markrolls88
PostPosted: 14:13 - 22 Jan 2014    Post subject: ybr Reply with quote
isnt the pipe going in at the diagram at no 18 will it 100% fit and if i just take it to a garage will they be able to do it and without having that pipe will it cause any damage to the engine or bike in any way
sparky
PostPosted: 15:58 - 22 Jan 2014    Post subject: Re: ybr Reply with quote
Is English your first language?
YBR Ric
PostPosted: 09:41 - 23 Jan 2014    Post subject: Reply with quote
This exhaust ???
https://www.ebay.co.uk/itm/leovince-exhaust-yamaha-ybr-new-/181290499523
https://www.ebay.co.uk/itm/leovince-exhaust-for-yamaha-ybr-new-/181290499523?clk_rvr_id=576863820921&nma=true&si=WC%252BU21CAhTBrbLNnfsc571Mo7bM%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
dansidi
PostPosted: 14:06 - 23 Jan 2014    Post subject: Reply with quote
Hi Mark,
It's a breather pipe, apparently and is not required for a functioning exhaust system. From what I have been told, it is required to comply with some Euro emission standards. I know don't know any more than that, sorry.
I looked into getting a Leo Vince for my 2010 YBR, but found it a bit too pricey. I ended up just cleaning up my original exhaust - grinding off the rust and re-spraying with UHT paint.
Hope that helps, mate.
current bike to first bike: SV650s K3, YBR125, Vespa GT125, Vespa ET4-125, Suzuki CS-50 (!!)
Mod 1 passed 02-11-2012
Mod 2 passed 05-12-2-12
There is a gap of 242 days between these two posts...
chilloutdude
PostPosted: 08:04 - 23 Sep 2014    Post subject: Yamaha YBR 125 Aftermarket Exhaust Reply with quote
Hi Guys,
I realise the last response to this thread was in January but was hoping one of you could help clear up an issue I'm having.
I have just ordered an after-market exhaust from a website called www.motorcycleproducts.co.uk for a 2009 model. Everything looked fine after researching the company and had prompt delivery. However, after looking closely at the exhaust I've noticed the logo reads 'YAMANA'. Is this a counterfeit product or a cheap knock-off? Will it be reliable enough to install on the bike? I can upload pics if that helps (new to this forum).
From looking more into the current ebay listings for YBR exhausts- nearly all appear to have this fake logo. Any help is much appreciated!
PostPosted: 08:49 - 23 Sep 2014    Post subject: Re: Yamaha YBR 125 Aftermarket Exhaust Reply with quote
No, it's probably a genuine 'YAMANA'.
If you wanted a Yamaha branded part, you get those from Yamaha.
You bought the cheapest one that you could find, right?
Is it E marked? Does it say "not for road use"? If it includes the downpipe, does it have a hole for your O2 sensor?
If yes, no and yes, I'd use it.
Bear in mind that your "Yamaha" bike is a Jianshe JS125-6 with fuel injection. I wouldn't get too fussy over branding.
Wonko The Sane
PostPosted: 08:57 - 23 Sep 2014    Post subject: Re: Yamaha YBR 125 Aftermarket Exhaust Reply with quote
chilloutdude wrote:
Hi Guys,
Heh,
After market exhaust, not made by Yamaha but they've put a branding on there that looks similar enough that when someone is admiring your bike they think it is a Yamaha exhaust.
As Rogerborg says, if it's E marked then it's approved for use
if it doesn't say 'track only' then you can use it on the road
if it's got the ability to fit your O2 sensor then your bike's FI system should work fine with the exhaust.
chilloutdude
PostPosted: 11:09 - 23 Sep 2014    Post subject: Reply with quote
Thanks for the quick and detailed responses- much appreciated!
Had another look at the exhaust- no e-markings are present but the seller claims these are not needed on MOT's anymore.
No labels to say it is not fit for road use.
There does not appear to be a hole for O2 sensor to fit.
Tried to use a website which seemed more legitimate than Ebay but obviously backfired. Seems like the best bet is to get a refund on this exhaust and try to find a spare from a scrap bike elsewhere.
Thanks again.
PostPosted: 11:48 - 23 Sep 2014    Post subject: Reply with quote
Hmm. I can see YBR 125 oxygen sensors being sold, but I suppose it could be open loop.
Have you had a look at your current exhaust? Does it have an oxygen sensor or not?
PostPosted: 14:09 - 23 Sep 2014    Post subject: Reply with quote
Clearly stated on the website.
Most parts are pattern or aftermarket although some will be genuine but are not always stated as being so.
The use of motorcycle manufacturers logo and brand names are for reference purposes only. We do not imply that the products we sell are made by or with the permission of the brands listed.
You also got it for less than 1/4 of the price of a genuine exhaust.
https://www.yamahamotorcyclespares.co.uk/genuineparts/11328/7/yamaha%20ybr125/exhaust?uID=0
And you still thought it was OEM?
Want to buy these 100% genuine Adidas?
https://www.mentalfloss.com/wp-content/uploads/2008/03/adidas.jpg
chilloutdude
PostPosted: 14:19 - 23 Sep 2014    Post subject: Reply with quote
This does seem to be an inherent problem across Ebay listings as well. Most list exhausts stating they are fit for 08-09 models but do not have the ability to work with the bikes O2 sensor or any of the relevant markings.
Chris- Would you genuinely pay £350 for a new exhaust which is over a third of the bikes value?
PostPosted: 14:21 - 23 Sep 2014    Post subject: Reply with quote
No, I also wouldn't expect an £85 one to be genuine.
The last post was made 11 years, 151 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.24 - MySQL Queries: 13 - Page Size: 135.88 Kb
