datatool , veto evo tweaks
Git
PostPosted: 14:43 - 29 Dec 2004    Post subject: datatool , veto evo tweaks Reply with quote
Would anyone know the wire colours that allow me to tweak the sensitivity on this device or turn the movement sensor off? The wind only has to blow and it's off, and certain young hands like to poke as they walk past in the garage, driving me nuts, I believe there are a few options into configuration by grounding certain colour wires?
Any info will reduce headache Thumbs Up
freestyler_onli
PostPosted: 16:59 - 29 Dec 2004    Post subject: Reply with quote
Same problem here. Only thing is-i dont have the ignition power to turn the bugger off. The oval button disable the movement sensor don't it??
Actually-ignore me. Razz
SW Motech Shop UK
PostPosted: 11:36 - 30 Dec 2004    Post subject: Reply with quote
I think it's the triangle button to turn off the movement sensor, after the alarm has armed.
https://www.motorcycle-road-and-race.co.uk and https://www.sw-motech-shop.co.uk/ and https://www.motorcycle-luggage.co.uk/
Git
PostPosted: 13:49 - 03 Jan 2005    Post subject: Reply with quote
Yes, the triangle button disables it.
But, I want to either turn it off permanantly as I am not always there to do it and do not want to rely on other household members
or adjust the sensitivity.
PostPosted: 13:56 - 03 Jan 2005    Post subject: Reply with quote
It should show you in the manual if you have it.
Git
PostPosted: 14:17 - 03 Jan 2005    Post subject: Reply with quote
yes, have a manual that says the changes can be made but there is no referance of how to do it like what wires, just the usual, consult a datatool service centre blah blah. Sad
PostPosted: 14:19 - 03 Jan 2005    Post subject: Reply with quote
I did this on my datatool evo and I'm pretty sure I read the details from a manual that came with it.
Git
PostPosted: 14:29 - 03 Jan 2005    Post subject: Reply with quote
thanks, in that case I will have another scan through but am almost certain I did not see it, just a sheet of paper that said where the installer had fitted the ignition cut out wires and battery and ignition feed, poxy alarms Laughing
SW Motech Shop UK
PostPosted: 16:46 - 04 Jan 2005    Post subject: Reply with quote
You cannot completly turn off a datatool. Only put it in service mode, turn of the movement sensor or take it off completly. If you could it cannot be classed as an immobiliser and insurance compnanies would not give discount. It is a feature of the alarm. I think the newer Datatools have the movement sensor inside the box rather than seperate like the old models and from memory of putting them on Ducati's you can re position the box to decrease the sensitivity. Or maybe im taking rubbish, its been a few years since i've done one.
PostPosted: 17:29 - 04 Jan 2005    Post subject: Reply with quote
I have a Triumph Datatool Veto Evo manual somewhere which is reputed to be quite in depth. I'll see if I can dig it out. Smile
dandit
PostPosted: 18:13 - 04 Jan 2005    Post subject: Reply with quote
i will have a look when I get in from work you can have less sensitive or if you want the movement sensor off hold on I will go and lok I have set my movement sensor manualy I think its yellow but will have a look then the alarm activates but not movement sensor
WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE I STILL HAD 3 GEARS TO GO OFFICER. Currently riding a naked cbr 600 and driving a 52 plate 2litre tdci mondeo
dandit
PostPosted: 22:26 - 07 Jan 2005    Post subject: Reply with quote
did you get it sorted
Git
PostPosted: 13:26 - 08 Jan 2005    Post subject: Reply with quote
Hi, no not sorted yet but it's on my list of endless things to do, will more than likely have a gander on Monday when I have all my tools back here.
Had another look through the alarm books/guides I have and can now see that an isolated yellow arms movement detection, grounded yellow manual arming of movement, isolated blue pre-alert mode, grounded blue instant trigger mode, so with them I can turn it off or at least have to manually arm the movement sensor if needed so thanks all thus far Thumbs Up
How about that actual sensitivity now, at the moment all that's needed is a little brush past it and it goes off, could I tweak so it doesn't go off till you give it a big kick or at least get it off the sidestand before it goes off? Is this adjusted by wires or do I tweak a screw somewhere?
dandit
PostPosted: 01:08 - 09 Jan 2005    Post subject: Reply with quote
as long as the brown wire is isolated it will be set to least sensitive but I think that is in instant trigger mode u could try grounding the blue and yellow but if its to sensitive it will go off straight away so you will have to isolate the blue Thumbs Up
The last post was made 21 years, 292 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 80.26 Kb
