| Git |
 Git Brolly Dolly
 Posted: 14:43 - 29 Dec 2004 Post subject: datatool , veto evo tweaks |
Would anyone know the wire colours that allow me to tweak the sensitivity on this device or turn the movement sensor off? The wind only has to blow and it's off, and certain young hands like to poke as they walk past in the garage, driving me nuts, I believe there are a few options into configuration by grounding certain colour wires?
Any info will reduce headache  |
| freestyler_onli |
 freestyler_onli World Chat Champion
 Posted: 16:59 - 29 Dec 2004 Post subject: |
Same problem here. Only thing is-i dont have the ignition power to turn the bugger off. The oval button disable the movement sensor don't it??
Actually-ignore me.  |
| SW Motech Shop UK |
 SW Motech Shop UK Scooby Slapper
| Git |
 Git Brolly Dolly
| G |
 G The Voice of Reason
| Git |
 Git Brolly Dolly
 Posted: 14:17 - 03 Jan 2005 Post subject: |
yes, have a manual that says the changes can be made but there is no referance of how to do it like what wires, just the usual, consult a datatool service centre blah blah.  |
| G |
| Git |
 Git Brolly Dolly
 Posted: 14:29 - 03 Jan 2005 Post subject: |
thanks, in that case I will have another scan through but am almost certain I did not see it, just a sheet of paper that said where the installer had fitted the ignition cut out wires and battery and ignition feed, poxy alarms  |
| SW Motech Shop UK |
 Posted: 16:46 - 04 Jan 2005 Post subject: |
You cannot completly turn off a datatool. Only put it in service mode, turn of the movement sensor or take it off completly. If you could it cannot be classed as an immobiliser and insurance compnanies would not give discount. It is a feature of the alarm. I think the newer Datatools have the movement sensor inside the box rather than seperate like the old models and from memory of putting them on Ducati's you can re position the box to decrease the sensitivity. Or maybe im taking rubbish, its been a few years since i've done one. ____________________ https://www.motorcycle-road-and-race.co.uk and https://www.sw-motech-shop.co.uk/ and https://www.motorcycle-luggage.co.uk/ |
| MarJay |
 MarJay But it's British!
 Posted: 17:29 - 04 Jan 2005 Post subject: |
I have a Triumph Datatool Veto Evo manual somewhere which is reputed to be quite in depth. I'll see if I can dig it out.  ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
| dandit |
 dandit Nearly there...
| dandit |
| Git |
 Git Brolly Dolly
 Posted: 13:26 - 08 Jan 2005 Post subject: |
Hi, no not sorted yet but it's on my list of endless things to do, will more than likely have a gander on Monday when I have all my tools back here.
Had another look through the alarm books/guides I have and can now see that an isolated yellow arms movement detection, grounded yellow manual arming of movement, isolated blue pre-alert mode, grounded blue instant trigger mode, so with them I can turn it off or at least have to manually arm the movement sensor if needed so thanks all thus far
How about that actual sensitivity now, at the moment all that's needed is a little brush past it and it goes off, could I tweak so it doesn't go off till you give it a big kick or at least get it off the sidestand before it goes off? Is this adjusted by wires or do I tweak a screw somewhere? |
| dandit |
 Posted: 01:08 - 09 Jan 2005 Post subject: |
as long as the brown wire is isolated it will be set to least sensitive but I think that is in instant trigger mode u could try grounding the blue and yellow but if its to sensitive it will go off straight away so you will have to isolate the blue  ____________________ WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE I STILL HAD 3 GEARS TO GO OFFICER. Currently riding a naked cbr 600 and driving a 52 plate 2litre tdci mondeo |
The last post was made 21 years, 295 days ago. Instead of replying here, would creating a new thread be more useful? |
