| cbrtrxtdmvfrD... |
 cbrtrxtdmvfrD... Borekit Bruiser
 Posted: 11:47 - 27 Jan 2014 Post subject: Speedo requirement for MOT (sorry if this is a repeat) |
I have been reading this - https://www.transportoffice.gov.uk/crt/doitonline/bl/mottestingmanualsandguides/mottestingmanualsandguides.htm
and i just cannot see for looking the part about speedo requirement for MOT. My speedo on a CBR125 no longer works, it is not the drive or the cable but the speedo itself, the MOT is due next week and was wondering if i need to replace it with a second hand one before then or if it is not covered by the current 2014 MOT test specification ____________________ Right' O |
| chris-red |
| P.addy |
 P.addy Red Rocket
 Posted: 11:50 - 27 Jan 2014 Post subject: |
Present but not tested.
Illegal on the road if its not working... but who would know  |
| wr6133 |
 wr6133 World Chat Champion
| beardface |
 beardface Spanner Monkey
 Posted: 12:04 - 27 Jan 2014 Post subject: |
On a similar note: indicators are not required for mot but if you still have the switch/button and they don't work you will be failed even if there are no indicators on the bike, we had to split the controls and remove the button then it sailed through  ____________________ www.soundcloud.com/bodren |
| P.addy |
 P.addy Red Rocket
| davebike |
 davebike World Chat Champion
 Posted: 12:12 - 27 Jan 2014 Post subject: |
Indicators are required fro a normal MOT on a bike post 1982
Dave ____________________ Dave
NC750Xdct + others at work !
[email protected] |
| chris-red |
| P.addy |
 P.addy Red Rocket
 Posted: 12:38 - 27 Jan 2014 Post subject: |
My KTM is exempt from indicators, despite having front/rear lamps. It also doesn't have a front brake switch which I believe "should" be a fail.  |
| truslack |
 truslack World Chat Champion
| beardface |
| chris-red |
| truslack |
 Posted: 13:16 - 27 Jan 2014 Post subject: |
| chris-red wrote: |
| Quote: | 1.5 Direction Indicators
This inspection applies to: all machines except those which either have no front or rear position lamps or have such lamps permanently disconnected, painted over or masked that are:
. only used during daylight hours, and
. not used at times of seriously reduced visibility
If this situation occurs the machine presenter should be issued with a VT32 (advisory notice) recording the above. |
Read the next section of the MOT testers book (Labelled 1.5 Exemptions)
If direction indicators are fitted they must meet the requirements of this inspection, but need not be fitted to a machine which:
. cannot exceed 30mph / 50kph, or
. was first used before 1 August 1986, or
. 'off road' machines which are designed
to carry only the rider.
. 'off road' machines with side car designed to carry the rider and one passenger in the side car.
off road machines are constructed or adapted primarily for use off roads (whether by reason of its tyres, suspension, ground clearance or otherwise). ____________________ Current: Suzuki RG 125 Gamma, Honda H100, Triumph Tiger 800XC, Suzuki SV650 (minitwin) |
| weasley |
 weasley World Chat Champion
| chris-red |
 Posted: 13:27 - 27 Jan 2014 Post subject: |
It's contradictory IMO...
Information This inspection applies to: all motor bicycles except those which either have no front or rear position lamps or have such lamps permanently disconnected, painted over or masked that are
• only used during daylight hours, and
• not used at times of seriously reduced visibility. If this situation occurs the machine presenter should be issued with a VT32 (advisory notice) recording the above.
Exemptions If direction indicators are fitted they must meet the requirements of this inspection, but need not be fitted to a machine which cannot exceed 30mph / 50kph, or was first used before 1 August 1986, or ‘off road’ motor bicycles that are designed to carry only the rider ‘off road’ motor bicycles with side car designed to carry the rider and one passenger in the side car. ‘Off road’ motor bicycles are constructed or adapted primarily for use off road (whether by reason of its tyres, suspension, ground clearance or otherwise).
In the main body it states they need not be fitted that in exemptions states they need not be fitted to certain bikes. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
WANTED:- Fujinon (Fuji) M42 (Screw on) lenses, let me know if you have anything. |
| weasley |
| truslack |
 Posted: 13:36 - 27 Jan 2014 Post subject: |
| chris-red wrote: | It's contradictory IMO...
That's how tests are listed in the manual, another example is stop lights
| Quote: | This inspection applies to; all machines except those which have neither front nor rear position lamps, or has such lamps permanently disconnected, painted over or masked that are
If this situation occurs the vehicle presenter should be issued with a VT32 (advisory notice) recording the above.
Exemptions
For this test if a stop lamp is fitted, it must meet the requirements of this inspection, but need not be fitted to a machine which:
a. cannot exceed 25mph, or
b. was first used before 1 January I936.or
c. was first used before 1 April 1986 and which has an engine capacity of less than 50cc.
Machines first used before 1 April 1986 must have a stop lamp that operates from at least one brake control.
Machines first used on or after 1 April 1986 must have a stop lamp that operates from both brake controls.
However, a small number of machines first used from this date were approved with the stop lamp operated by only one control. A machine should only be failed if you are certain that it was originally manufactured to operate from both controls
On machines without a battery or with an insufficiently charged battery, it will be necessary to run the engine. |
The last post was made 12 years, 242 days ago. Instead of replying here, would creating a new thread be more useful? |
