RAM and Graphics update help
dransy
PostPosted: 19:51 - 27 Jan 2014    Post subject: RAM and Graphics update help Reply with quote
Need some help , i only really play wow tbh but would like to be able to run it on full settings with a decent fps at the minute i can run it on good.
Heres what i have at the moment and whats recommended. Should i go with whats recommended or better?
https://cdn.bikechatforums.com/files/comps_159.jpg
Im after second hand and cheap Very Happy ha and id rather not have to upgrade my psu but can do if i really have to Very Happy
My Mobo can take up to 8gb and it has two slots for ram
MObo is asus m4a78L-m LE
Cheers flowers!
RhynoCZ
PostPosted: 20:13 - 27 Jan 2014    Post subject: Reply with quote
Is it 32bit system?
By the way, get modern GPU to get better game performance. Any modern GPU around 100 pounds would be alright. Thumbs Up
I've got ATi HD6790, with ancient Q6600 and 8gb DDR2 and games are still alright. Thumbs Up
EDIT: Sorry, just noticed it's 64bit, you had 3.1 so I assumed, anyway, get definitely more ram. The speed of the RAM does not matter at all. Only APU's profit from fast RAM.
EDIT 2: What PSU do you use?
TUG
PostPosted: 20:19 - 27 Jan 2014    Post subject: Reply with quote
Going off those specs you had a similar set up to my old pc world piece of crap.
I take it you have no cash at all or just want to upgrade on the cheap?
You can pick up ram cheap as chips from scan.co.uk or other vendors. you can also pick up a cheap 2nd hand AMD HD6870 for around £60-£100 depending on how hard you look which should run anything fine should you choose to upgrade in the future.
The mobo your using is spec'd for DDR2 memory at 1200 OC'd apparently. To be honest your trying to play a modern game on an old PC and you might find that although you can get it within reccomended settings, it might be laggy or slow on full settings, i've not played WoW so don't quote me on that.
Haz ER-5, innit!
andys675
PostPosted: 02:25 - 28 Jan 2014    Post subject: Reply with quote
buy some more ram, it's cheap anyway
you can pick up a GTX460 for under £50 used, miles better than a 8800gtx
CaNsA
PostPosted: 03:00 - 28 Jan 2014    Post subject: Reply with quote
buy phildawson's gtx650 for 50 quid.
https://www.bikechatforums.com/viewtopic.php?t=284301
dransy
PostPosted: 12:16 - 28 Jan 2014    Post subject: Reply with quote
He's already sold it Sad
CaNsA
PostPosted: 12:32 - 28 Jan 2014    Post subject: Reply with quote
Bad times Sad
RhynoCZ
PostPosted: 12:55 - 28 Jan 2014    Post subject: Reply with quote
ATi HD6670 is about 50 pounds, needs 400w PSU. Thumbs Up
Get some very very very cheap EVOLVEO Zeppelin RAM, alright enough and you're good to go.
Shinigami
PostPosted: 12:58 - 28 Jan 2014    Post subject: Reply with quote
I still have a XFX Radeon HD4870 512 for sale aboot £40
RhynoCZ
PostPosted: 13:04 - 28 Jan 2014    Post subject: Reply with quote
Good choice, if you've got atleast 500w+ PSU. Thumbs Up
T1z3R
PostPosted: 16:11 - 28 Jan 2014    Post subject: Reply with quote
i dont mean to turn this into a flaunt-what-you-got-for-sale thread Thumbs Up but...
1 x Gigabyte AMD Radeon 7870 2GB OC - £110 delivered
1 x MSI AMD Radeon 7850 1GB OC - £80 delivered
either of those will kill in your machine with the right PSU Mr. Green
duck my sick!
dransy
PostPosted: 18:25 - 28 Jan 2014    Post subject: Reply with quote
Think my psu is only 350 w Very Happy
dransy
PostPosted: 18:42 - 28 Jan 2014    Post subject: Reply with quote
https://www.ebay.co.uk/itm/NVIDIA-GeForce-8800-GTX-768-MB-Graphics-Card-/231146676489?pt=UK_Computing_Computer_Components_Graphics_Video_TV_Cards_TW&hash=item35d16a6109
How much better is that than my current 8500 gt?
dransy
PostPosted: 18:48 - 28 Jan 2014    Post subject: Reply with quote
found this for 20 quid apparantly that can run wow on max?
https://www.ebay.co.uk/itm/nVidia-GeForce-GT520-DDR3-1GB-HDMI-DVI-VGA-Graphic-Card-/111266678190?pt=UK_Computing_Computer_Components_Graphics_Video_TV_Cards_TW&hash=item19e802c5ae
Very Happy
dransy
PostPosted: 18:52 - 28 Jan 2014    Post subject: Reply with quote
https://www.ebay.co.uk/itm/Biostar-TA790GX-A3-AMD-Athlon-II-X4-Motherboard-Bundle-/261383023024?pt=UK_Computing_LaptopMotherboards_CPUs_CA&hash=item3cdba469b0 found taht going for 50 at the mo hows about it?
CaNsA
PostPosted: 19:27 - 28 Jan 2014    Post subject: Reply with quote
Get a GTX, not a GT
lihp
PostPosted: 19:47 - 28 Jan 2014    Post subject: Reply with quote
As Cansa says, GT is really not suited to game, although the numbers may seem like they're the same performance there's a massive difference.
dransy
PostPosted: 23:48 - 28 Jan 2014    Post subject: Reply with quote
RhynoCZ
PostPosted: 23:59 - 28 Jan 2014    Post subject: Reply with quote
350w PSU, we're talking about a new PSU or something like ATi HD5450. Thumbs Up
Derivative
PostPosted: 00:26 - 29 Jan 2014    Post subject: Reply with quote
Full settings with decent FPS will probably need far higher than you expect. The 'Recommended' stats there are hilarious. 8800GT? Laughing
There is a huge difference between 'lowest 60fps' and 'highest 60fps' especially if it's at 1920x1080 or higher.
My laptop has a GTX660M (2GB) and i7 quad, and that was enough to do nearly max everything at 1920x1080. Just. In 25 mans I'd have to turn it off.
If you want to be safe for the next expansion then you probably want more. WoW might look like it has 'bad' graphics but with draw distance turned up and effects on it still needs decent hardware.
Basically I'd get the best you can afford, or just settle for Medium or something.
The last post was made 12 years, 272 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 107 Kb
