| mic |
 mic Brolly Dolly
 Posted: 19:55 - 29 Jan 2014 Post subject: squats |
Hit the 100kg the other day did 105kg yesterday and going for 110kg tomorrow (5x5) aiming to build up to 150kg by end of march. Is that realistic?? It's take 3 months to get this far from almost empty bar and can obviously feel the weight now can't imagine another 45kg extra! ____________________ zzr600 |
| thepuma |
 thepuma World Chat Champion
| effit |
 effit Scooby Slapper
| mic |
 mic Brolly Dolly
| effit |
| mic |
 mic Brolly Dolly
| effit |
 Posted: 21:37 - 29 Jan 2014 Post subject: |
Gonnacheck those apps out, thanks again. Joined back at gym for first time infkn years. Gonna try 5x5 as never tried before and mainly positive reports.
good luck with your progress  |
| mic |
 mic Brolly Dolly
| drbaig |
 drbaig Crazy Courier
 Posted: 22:15 - 29 Jan 2014 Post subject: |
you will hit a plateau at some point. Then you will have to change your routine to try and break that. What you are experiencing are called noob gains. Strength shoots up in the beginning and then starts slowing down then stagnates.
If you're into power lifting then you want constant gains, but if you are just looking to improve your physique then the strength program will only work on certain parts. You will have to change your workout routine at some point anyway as you will stop seeing much benefit from your current setup.
Keep doing what you are till you stop seeing gains and then try incorporating more exercises to isolate certain muscle groups. Its a trial and error thing.  ____________________ yzf 600r  |
| mic |
 mic Brolly Dolly
| drbaig |
 Posted: 23:09 - 29 Jan 2014 Post subject: |
Stick to the strength program until you stop seeing progress. 2bh you are already lifting respectable weight i.e. if it is true and not estats.
then you can try incorporating, front squats, hack squats, lunges. If you use the gym then you could use the leg press, isolate it even further with quad and hammy extensions. Do calf lifts and etc.
One thing that does wonders is a lifting partner who can push you. My best gym sessions were when one of my friend used to lift with me regularly and I moved a lot of weight. Working out alone just doesn't have the same intensity.
If you want a good physique, then you will be moving moderate weight at high reps and doing a lot of cardio and isolation to reduce body fat. If you just want to be big then stick to the big 5 and push as much weight as you can.
It depends on what you are looking to achieve. ____________________ yzf 600r  |
| mic |
 mic Brolly Dolly
 Posted: 23:15 - 29 Jan 2014 Post subject: |
When i joined the gym the intention was to loose the gut and aim for good physique. I found Stronglifts by Google and stuck to it. Stepped up in 5kg each time and go 2-3 times a week, weights are correct
Now I've made such progress with 5x5 it would be a shame to stop if the weight keeps going up. But it's not exactly a high rep plan for building physique.
I'm gonna keep going with target of 150kg, then once there try change reps rather than weight. ____________________ zzr600 |
| mysterious_rider |
 mysterious_rider World Chat Champion
 Posted: 10:48 - 30 Jan 2014 Post subject: |
are you gaining muscle? Or doing it just to get strength? I weight 14st ish and I recently started doing squats. I started with 90kg but found 80kg better as I can get down lower. I'll up to 85-90 next time as my thighs are in pain
I wonder if the 5x5 thing works on other stuff, I may try it with dumbell presses. My goal is the 2x 30kg's. I've done them before... But its a mission! ____________________ KAWASAKIIIII |
| mic |
 mic Brolly Dolly
 Posted: 10:56 - 30 Jan 2014 Post subject: |
Get strong for now see where it takes me
Idea of starting with low weight is to practise with good form. Best squat is to break parallel - when you go down, arse goes lower than the knees. For you, it might be worth sticking at something like 60kg and get used to doing it that way so your ready when the weight piles on
I try squat 2-3 times a week, if i leave it too long then I really struggle with it. And get some carbs down your neck before you go! Works for me anyway.
For everything do 5x5 and add 2.5kg (or 5 for squats) every time you go. If you can't do 5x5 then don't add the weight untill you can. Then move up. ____________________ zzr600 |
| Aspire |
 Aspire Scooby Slapper
| Motorhate |
 Motorhate Nearly there...
| mic |
 mic Brolly Dolly
| Motorhate |
| mic |
 mic Brolly Dolly
 Posted: 20:51 - 02 Feb 2014 Post subject: |
I'm not overly keen on deadlifts mainly because it's something I haven't done until now and my sides/back hurts/aches for hours after. I've had the trainers check my form several times and I know it's good specially as they arnt heavy weights so probably is a good pain from muscles not usually being used. But i should do them more. Also noticed a good time for bench press is when back pain is rife as you don't think about arm pain  ____________________ zzr600 |
| Chalky. |
 Chalky. World Chat Champion
| hellkat |
 hellkat Super Spammer
 Posted: 23:16 - 02 Feb 2014 Post subject: |
<<<< saw "squats", visualized "squits"
 ____________________ Not nearly as interesting in real life. |
| Robster |
 Robster World Chat Champion
| Sload |
 Sload World Chat Champion
| TomReilly |
 TomReilly Traffic Copper
 Posted: 09:45 - 03 Feb 2014 Post subject: |
I'm classed as an over weight chunk with my body weight of 10st at 5'5 tall.
Done training since I was 5 years old, nearing 18 now, it's great being different  ____________________ Motorcycle riding can be really cozy. If you want to be a little closer to your passenger, brake a little quicker for the next stop.  |
| mic |
 mic Brolly Dolly
The last post was made 12 years, 289 days ago. Instead of replying here, would creating a new thread be more useful? |
