squats
Bike Chat Forums Index -> Dear Auntie BCF... Goto page 1, 2, 3  Next
mic
PostPosted: 19:55 - 29 Jan 2014    Post subject: squats Reply with quote
Hit the 100kg the other day Very Happy did 105kg yesterday and going for 110kg tomorrow (5x5) aiming to build up to 150kg by end of march. Is that realistic?? It's take 3 months to get this far from almost empty bar and can obviously feel the weight now Laughing can't imagine another 45kg extra!
zzr600
thepuma
PostPosted: 20:26 - 29 Jan 2014    Post subject: Reply with quote
Well Done
765 RS
effit
PostPosted: 21:16 - 29 Jan 2014    Post subject: Reply with quote
Well done. Been readingup on this 5x5 idea. What are you doing 5x5? Ie squats, bench press etc etc
mic
PostPosted: 21:21 - 29 Jan 2014    Post subject: Reply with quote
https://stronglifts.com/
squats, deadlifts, overhead press, barbell rows, and bench press all in rotation as listed in the stronglifts website
starts off easy but now leave the gym knackered everytime. definantly worth trying, even if only for 12 weeks.
zzr600
effit
PostPosted: 21:27 - 29 Jan 2014    Post subject: Reply with quote
cheers for that! Are you noticing a big difference in strength?
mic
PostPosted: 21:34 - 29 Jan 2014    Post subject: Reply with quote
tbh i dont follow it strictly, but my weights go up every session and i havent dropped yet. main noticable difference is the top of my legs which are now quite chunky. but i dont follow a strict diet as such which might help more too.
theres also a stronglifts app for iphone and android to help keep track Cool but i have a crap blackberry so log it on a laminated chart i printed out.
zzr600
effit
PostPosted: 21:37 - 29 Jan 2014    Post subject: Reply with quote
Gonnacheck those apps out, thanks again. Joined back at gym for first time infkn years. Gonna try 5x5 as never tried before and mainly positive reports.
good luck with your progress Thumbs Up
mic
PostPosted: 21:44 - 29 Jan 2014    Post subject: Reply with quote
you too Karma
zzr600
drbaig
PostPosted: 22:15 - 29 Jan 2014    Post subject: Reply with quote
you will hit a plateau at some point. Then you will have to change your routine to try and break that. What you are experiencing are called noob gains. Strength shoots up in the beginning and then starts slowing down then stagnates.
If you're into power lifting then you want constant gains, but if you are just looking to improve your physique then the strength program will only work on certain parts. You will have to change your workout routine at some point anyway as you will stop seeing much benefit from your current setup.
Keep doing what you are till you stop seeing gains and then try incorporating more exercises to isolate certain muscle groups. Its a trial and error thing. Thumbs Up
yzf 600r Very Happy
mic
PostPosted: 22:47 - 29 Jan 2014    Post subject: Reply with quote
must admit i have thought about sticking at 100kg but changing to 8x4 to work on physique rather than powerlift. can always add more weight later if need be.
zzr600
drbaig
PostPosted: 23:09 - 29 Jan 2014    Post subject: Reply with quote
Stick to the strength program until you stop seeing progress. 2bh you are already lifting respectable weight i.e. if it is true and not estats.
then you can try incorporating, front squats, hack squats, lunges. If you use the gym then you could use the leg press, isolate it even further with quad and hammy extensions. Do calf lifts and etc.
One thing that does wonders is a lifting partner who can push you. My best gym sessions were when one of my friend used to lift with me regularly and I moved a lot of weight. Working out alone just doesn't have the same intensity.
If you want a good physique, then you will be moving moderate weight at high reps and doing a lot of cardio and isolation to reduce body fat. If you just want to be big then stick to the big 5 and push as much weight as you can.
It depends on what you are looking to achieve.
yzf 600r Very Happy
mic
PostPosted: 23:15 - 29 Jan 2014    Post subject: Reply with quote
When i joined the gym the intention was to loose the gut and aim for good physique. I found Stronglifts by Google and stuck to it. Stepped up in 5kg each time and go 2-3 times a week, weights are correct Smile
Now I've made such progress with 5x5 it would be a shame to stop if the weight keeps going up. But it's not exactly a high rep plan for building physique.
I'm gonna keep going with target of 150kg, then once there try change reps rather than weight.
zzr600
mysterious_rider
PostPosted: 10:48 - 30 Jan 2014    Post subject: Reply with quote
are you gaining muscle? Or doing it just to get strength? I weight 14st ish and I recently started doing squats. I started with 90kg but found 80kg better as I can get down lower. I'll up to 85-90 next time as my thighs are in pain Laughing
I wonder if the 5x5 thing works on other stuff, I may try it with dumbell presses. My goal is the 2x 30kg's. I've done them before... But its a mission!
KAWASAKIIIII
mic
PostPosted: 10:56 - 30 Jan 2014    Post subject: Reply with quote
Get strong for now see where it takes me Smile
Idea of starting with low weight is to practise with good form. Best squat is to break parallel - when you go down, arse goes lower than the knees. For you, it might be worth sticking at something like 60kg and get used to doing it that way so your ready when the weight piles on Smile
I try squat 2-3 times a week, if i leave it too long then I really struggle with it. And get some carbs down your neck before you go! Works for me anyway.
For everything do 5x5 and add 2.5kg (or 5 for squats) every time you go. If you can't do 5x5 then don't add the weight untill you can. Then move up.
zzr600
Aspire
PostPosted: 18:23 - 02 Feb 2014    Post subject: Reply with quote
On squats form is more important then weight. Some people think they are squatting right but there form is awful.
Motorhate
PostPosted: 20:36 - 02 Feb 2014    Post subject: Reply with quote
Be really careful with squats, as mentioned good form is everything otherwise some serious long-term injuries to back and knees can result. I'd concentrate on form rather than weight for now - oh and always use a good spotter too. Undoubtedly they are the best exercises for building strength and size but I'd advise a quality back support and knee wraps too.
Current - Harley Davidson FXDB Street Bob | Harley Davidson FLTR Road Glide | Harley Davidson Road King
GONE - Honda CB500 Ratbike | Yamaha FZ750 | Yamaha XVS1100 | Kawasaki VN2000 | Kawasaki ER-6 F | Harley Davidson XL883L Sportster
mic
PostPosted: 20:40 - 02 Feb 2014    Post subject: Reply with quote
Motorhate wrote:
Be really careful with squats, good form is everything otherwise some serious long-term injuries to back and knees can result. Undoubtedly they are the best exercises for building strength and size but I'd advise a quality back support and knee wraps too.
What sorta weight warrants a belt for squats?!
For what it's worth, I attempted 110kg. Managed 2 sets of 5 but only managed half the 3rd set on 3 reps so went back to 100kg which felt so lighter. Think I'm gonna deload back to 80kg and concentrate on form again for a week or so rather than increase weight as it'll only end in tears.
zzr600
Motorhate
PostPosted: 20:46 - 02 Feb 2014    Post subject: Reply with quote
There is no set weight to use a belt - if you've got a weak back then you should use one all the time, regardless. Believe me, I use to squat 130kg at 5' 6" and 10.5 stone when I was younger but I'm paying for it now, believe me. Back is dodgy at times and knees are starting to feel painful now too which I can attribute to squats. It got to the point where I had to use a Smith machine rather than free weights to ease the stress on my back.
Its also a sound idea to cut back on the weight and concentrate on form. You'll benefit from it so much more than by just simply piling the plates on and attempting to lift them (I'd recommend raising your heels by about 2 inches too when you lift as well.
Also consider incorporating deadlifts into your routine too but again, always use a belt for any excercise that puts strain on your lower back.
mic
PostPosted: 20:51 - 02 Feb 2014    Post subject: Reply with quote
I'm not overly keen on deadlifts mainly because it's something I haven't done until now and my sides/back hurts/aches for hours after. I've had the trainers check my form several times and I know it's good specially as they arnt heavy weights so probably is a good pain from muscles not usually being used. But i should do them more. Also noticed a good time for bench press is when back pain is rife as you don't think about arm pain Laughing
zzr600
Chalky.
PostPosted: 21:02 - 02 Feb 2014    Post subject: Reply with quote
Never used a belt or knee wraps and i go fairly heavy, but if you have a problem it might not be such a bad idea. You'll be fine around 100kg I'd have thought.
hellkat
PostPosted: 23:16 - 02 Feb 2014    Post subject: Reply with quote
<<<< saw "squats", visualized "squits"
Brick Wall
Robster
PostPosted: 09:37 - 03 Feb 2014    Post subject: Reply with quote
Mark Rippetoe would be proud!
Sload
PostPosted: 09:39 - 03 Feb 2014    Post subject: Reply with quote
The only thing I would suggest is stick to the program. Some of the advice you have received and some of your own ideas actually go against what the program you are doing suggests.
Honda Varadero >> Triumph Speed Four >> Honda CBR1100xx
TomReilly
PostPosted: 09:45 - 03 Feb 2014    Post subject: Reply with quote
I'm classed as an over weight chunk with my body weight of 10st at 5'5 tall.
Done training since I was 5 years old, nearing 18 now, it's great being different Twisted Evil
Motorcycle riding can be really cozy. If you want to be a little closer to your passenger, brake a little quicker for the next stop. Wink
mic
PostPosted: 11:49 - 03 Feb 2014    Post subject: Reply with quote
True but there's no point going forward if form is bad or if i just can't physically lift it. Program does actually say to deload if needed so it's not all that bad.
Anyway there's no rush I'd rather take my time and if that means straying a little so be it
zzr600
The last post was made 12 years, 289 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.21 - MySQL Queries: 13 - Page Size: 128.24 Kb
