| pdg |
 pdg World Chat Champion
 Posted: 19:21 - 30 Jan 2014 Post subject: Car -- Guess the fault... (now just talk about crap) |
See if anyone can:
1. Identify the parts.
2. Identify what is wrong with the parts.
3. Identify what caused the problem.
Car is a '98 Discovery 300tdi.
First to get all 3 gets
https://i834.photobucket.com/albums/zz267/pdg555/PICT0968_zps10c63312.jpg ____________________ Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
| Marmalade |
 Marmalade World Chat Champion
 Posted: 19:22 - 30 Jan 2014 Post subject: |
push rods
bent
cam belt ____________________ Nobby the Bastard: How yo tell the difference between the actual japanese and her just screaming because she's had live fish stuck up her arse? [url=https://www.nicks-shop.co.uk/bcf-goodies-15-c.aspGet BCF stickers and things here[/url] Reflective helmet stickers - Legal requirement in france - Clicky |
| pdg |
 Posted: 19:24 - 30 Jan 2014 Post subject: |
Marmalade 3 for 3.
That was quicker than I thought  ____________________ Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you. |
| andyscooter |
 andyscooter World Chat Champion
 Posted: 19:26 - 30 Jan 2014 Post subject: |
got two was thinking somthing else caused it  ____________________ gilera runner vxr200 (chavped)
if its spelt wrong its my fat fingers and daft auto correct on my tablet |
| Ariel Badger |
 Ariel Badger Super Spammer
| pdg |
| billytwomirro... |
 billytwomirro... Nova Slayer
| pdg |
| Nobby the Bastard |
| pdg |
 Posted: 20:44 - 30 Jan 2014 Post subject: |
No, the point of a cambelt is thus:
So the manufacturers have yet another 'service item'.
Fine, they dress it up as "ooh, it's quieter than a camchain, it uses less power so makes the engine more efficient blah blah."
No, what it actually does is let them sell another consumable item and every now and again a buttload of parts when it snaps. It's pretty easy to design a valve safe engine, but they don't bother because then you don't need to buy a bucket of parts if the belt fails.
Cynical? Moi? Nooooooooo
Looks like the series 3 is going back into service  ____________________ Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you. |
| Nobby the Bastard |
 Posted: 21:22 - 30 Jan 2014 Post subject: |
I can't think of any crank that has integral cams. Pushrods are used when the camshaft is mounted in the block rather than in the head, still needs to be driven. ____________________ a.k.a 'Geri'
| pdg |
 Posted: 21:29 - 30 Jan 2014 Post subject: |
Buuuuuuuuuuuuuut...
The cams aren't on the crank, they are on the camshaft. The camshaft has to turn at 1/2 crank speed on a 4 stroke engine.
Using a belt doesn't mean the camshaft is moved above the valves - having an overhead cam engine moves the camshaft above the valves...
Some single overhead cam engines still use rockers. I have seen overhead cam engines where the camshaft is driven by a chain (i.e. most OHC bike engines), and others where the camshaft is driven by gears.
What I have is a side cam engine - 'usually' a side cam engine use a chain (or gears) to drive the camshaft, but this one has a belt.
In actuality, a side cam engine is 'better' than an overhead cam due to the pushrods and layout of the valvetrain. In an overhead cam engine there is no 'weak point' in the valvetrain so in the event of belt failure the valves are driven straight through the piston crowns - at least in this design of engine the pushrods bend and in most cases the valves, pistons, camshaft and followers remain serviceable. ____________________ Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you. |
 Posted: 21:57 - 30 Jan 2014 Post subject: |
Big-ends take a beating though. ____________________ a.k.a 'Geri'
| Nobby the Bastard |
 Posted: 22:00 - 30 Jan 2014 Post subject: |
An engineer would never use a blunt spoon. It would be sharpened first - probably to 4 thou. ____________________ a.k.a 'Geri'
| pdg |
| JonB |
 JonB Afraid of Mileage
| Polarbear |
 Polarbear Super Spammer
 Posted: 23:32 - 30 Jan 2014 Post subject: |
Nissan said that when they made the 2nd shape micra. Trouble is they put a chocolate cam chain in it, and it was an engine out job to repair it.
AFAIK Nissan never acknowledged it or did a recall either.
I think I'd rather have a belt and change it every 50000 miles or so. ____________________ Triumph Trophy Launch Edition |
| lihp |
 lihp World Chat Champion
 - Super Spammer
 Posted: 00:03 - 31 Jan 2014 Post subject: |
Pushrods? I thought only archaic British engines used them.
Oh...., it's a Land Rover. A bit like Harleys really - crap old technology, adored by mid life crisis cases with a false belief that old technology is better!  |
| Polarbear |
| pdg |
| map |
 map Mr Calendar
The last post was made 12 years, 76 days ago. Instead of replying here, would creating a new thread be more useful? |
