| stunthamster |
 stunthamster Two Stroke Sniffer
| Shreeve |
 Shreeve Scooby Slapper
 Posted: 08:46 - 04 Feb 2014 Post subject: |
Well you already stated you're confident/comfortable with the commute itself.
As for the YBR, they're considered one of the most reliable 125's. If it's going to be your workhorse then ideally you want to be giving it a good clean/service every week (I did it on Saturday mornings with my CBF). Alternatively you can do it more sparingly but it's entirely your prerogative.
For maintenance it's just the standard stuff like checking the chain for wear and lube, give it a clean, check oil, make sure the tyres look ok etc. 2-3 months of it should be fine with enough care and you'll find they hold value quite well. On that note, you're going to want to get some ACF50 and keep that applied to anything that could rust.
Worst thing I found about commuting on a 125 was my backside going numb, absolute killer... ____________________ Current: Suzuki GSX650F (2010), Suzuki GSXR1000 K7, Suzuki GS250T (1980) currently restoring: Clicky.
Previous: Honda CBF 125 (2011), Suzuki GSXR750 K4 |
| esullivan |
 esullivan Could Be A Chat Bot
 Posted: 09:02 - 04 Feb 2014 Post subject: Re: Advice for long commute |
So 160 miles of mostly city riding, every day? On a 125? That's almost courier mileage. It's doable and the weather should start to improve, slightly, over the next couple of months, but that's a hard slog. I do 35-40 miles a day and find it tough going some days.
At that sort of pace, I would be giving the chain a wipe down and lube at least every other day, or every day in rainy periods (i.e., usually). Give the tyres a good looking over for bits of glass/screws at end of the ride as well. And you'll probably be changing the oil about twice a month. The service interval on a YBR is 3,500 miles, so every four or five weeks for you. If it's a new bike (and thus has to be done at the dealer for warranty), that can get expensive.
The bike can take it. The real question is whether you can. Pass your test and get a more comfortable bike, one that can eat miles with ease. ____________________ Current: '14 VFR800X Test passed 31/10/12.
Previous: '12 NC700S, '11 CBF 125, '04 SH 125. |
| stunthamster |
 Posted: 09:10 - 04 Feb 2014 Post subject: Re: Advice for long commute |
| esullivan wrote: |
That's fantastic advice; I hadn't really given much thought to any crap that might end up on the tires, thinking about some of the detritus I rode through in London that's probably something I should be wary of. In terms of expense, it's around £640 for the train per month at the moment, so I figure at worst it's break even, especially as I only plan to be on this until I pass my tests.
| Shreeve wrote: |
Worst thing I found about commuting on a 125 was my backside going numb, absolute killer... |
Yeah, I was hoping the combination of the relatively padded trousers, OK seat and ample arse cheeks would mitigate the numbness, but was absolutely no use whatsoever. After forty minutes the only reason I knew I still had an arse was because it was still attached to the bike!
| esullivan wrote: |
I guess time will tell if I can manage it or not, thankfully I only have to do it three days a week. I'm hoping to get my test under my belt next month, and from there I'm thinking along the lines of an XJ6 Diversion F - I kind of figure that fairing will be a nice to have on the long haul.
Cheers for the advice chaps, much appreciated. |
| Rogerborg |
 Rogerborg nimbA
 Posted: 09:46 - 04 Feb 2014 Post subject: |
What's that, 4 hours a day? £640 a month on trains? Move closer.
If you want to do it the hard way, I'd be looking at:
Chain oiler.
Gel / inflatable / sheepskin seat cover.
Weather protection. A big screen, muffs, and if you value substance over style, Tucano Gaucho leg covers.
After you're passed, I'd suggest that you look at shaft drive bikes, e.g. Honda Deauville or Diversion 900. ____________________ Biking is 1/20th as dangerous as horse riding.
| iooi |
 iooi Super Spammer
| stunthamster |
| Rogerborg |
 Rogerborg nimbA
| Shreeve |
| Andy_Pagin |
 Andy_Pagin World Chat Champion
 Posted: 11:48 - 04 Feb 2014 Post subject: |
IIRC on my YBR125:
Oil change every 4000 miles
'Proper' service every 7000 miles.
Chain adjust every 600 miles, not from the owners manual, that's how often the slack reached the limit.
Tyres do about 8000 miles a piece,maybe 10,000 from the front.
So OP is doing a ballpark 36,000 miles per annum.
Nine oil changes a year (plus topping up)
Four or fives services a year (ok not much more than a new spark plug).
Sixty chain adjusts a year.
About four SETS of tyres a year.
Brake pads & shoes?
OP really needs to factor in the costs at that sort of mileage. ____________________ They're coming to take me away, ho-ho, hee-hee, ha-haaa, hey-hey,
Yamaha Vity -> YBR125 -> FZS600 Fazer -> FZ1-S Fazer |
| Polarbear |
 Polarbear Super Spammer
| barrkel |
 barrkel World Chat Champion
 Posted: 14:22 - 04 Feb 2014 Post subject: |
Make sure you wear earplugs, especially after you move up to a bigger bike. You'll be doing most of it on high speeds dual carriageways / motorway depending on your route.
This is a reasonably decent price on 1000 earplugs: https://www.cromwell.co.uk/TFF9589020K
Personally I think wasting 4 hours a day on commute is not worth it. It wouldn't be awful in summer if you're not in a rush as you could do country roads, but commutes tend to turn into a bit of a rush as you try to maximize non-work life. ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
Best road ever ridden: www.youtube.com/watch?v=s2MhNxUEYtQ |
| stunthamster |
| stevo as b4 |
| Andy_Pagin |
| Pigeon |
 Pigeon World Chat Champion
 Posted: 23:05 - 04 Feb 2014 Post subject: |
Did 200-250 mile a day rides every weekend from May to September on a 125 that's similar to yours. Yes a numb butt at the start, but after a couple of months I could happily go 4 hours without stopping.
Actually, the relaxed riding position and super light weight makes your kind of commute more than doable! But get some earplugs and waterproofs!
Service manual for mine states oil change every 3,000km
As others have said, for much of your journey the throttle will be pinned. So I'd go nearer the Jianshe Oil change limit that the Yamaha one. Maybe every 2,000 miles for you max. You will notice gear changes get clunky and false neutrals, usually a sign the oil is passed its best.
Repeating others advice. Lube chain every couple of days, eyeball the slack. Check tyre pressures + oil level + lights.
Consider getting breakdown cover, or know a mate with a van.
Your going to use circa 33ltrs of fuel a week. Or around £40-£45/week.
Even with Tyres, chains+sprockets, pads+shoes, oil etc You should save a small fortune (all things being equal ie you don't stack it) compared to the train.
Bottom line, you don't have to stick to it if it doesn't pan out. |
| Northern Monkey |
 Northern Monkey World Chat Champion
| iooi |
 iooi Super Spammer
| Clutchy |
 Clutchy World Chat Champion
 Posted: 17:20 - 05 Feb 2014 Post subject: |
During winter I'd go for the train option, at least then you can get some work done or go on Facebook/Youtube/BCF (whatever you'd be doing on a boring day at home) so that you don't go home and then waste hours doing that.
Start reading books on the train etc, I personally wouldn't do 4 hours a day on a boring bike. ____________________ Malaguti F12 Phantom-Dead, Suzuki AY50- Dead, NRG power DD LQ, CBR125.
Guide to pass your test with no lessons! |
| Clutchy |
 Posted: 17:24 - 05 Feb 2014 Post subject: |
Then again I'd probably pay £20 and spend the night in a travelodge, you'd certainly be saving money! ____________________ Malaguti F12 Phantom-Dead, Suzuki AY50- Dead, NRG power DD LQ, CBR125.
| stevo as b4 |
 Posted: 19:56 - 05 Feb 2014 Post subject: |
| iooi wrote: |
I think that point is pretty moot....
When semi/Full sync oils were 1st sold. Their sales pitch was longer intervals between changes....
NOT SHORTER.....
Do you think that Manufactures would sell bikes with extended oil limits if they had not tested them out....
As who would be picking up the warranty claims....
As well as people moaning that engines are failing at low milage.
I think its pretty well proven that 3.5K miles is Ok. In fact I would guess that many do far more than that between changes.
Why do people waste their money changing oil too soon.  |
Mate, I have no knowledge of whatever test program Yamaha carried out on say the YBR motor's and to what degree they were tested for wear and oil degradation in extreme conditions.
ideally like you say, the manufacturer should know best, but history sometimes tells us otherwise. Of course modern semi and fully synth oil's should be more advanced and allow longer oil change intervals in theory, depending on the application and useage.
lots of short cold engine rides for example are worse for oil than long fast rides with a hot engine. I think you know this, and also that you cannot just give a blanket XXXX mile oil change interval irrespective of use.
For example with certain vehicles used hard on a track day, it's quite possible to get oil temperatures to a level way about what is considered sensible or safe, and thus oil can be badly degraded after just one track day.
A lot of bike owners are fairly technically minded and also like to care for their bike's as well as they can. therefore they often do more frequent oil changes than manufacturer specific recommendations.
Honda used to specify reasonably long oil change intervals (longer than they could cope with in reality) for it's small air cooled singles. As you also know air cooled bikes will work the oil far harder as they are using it for cooling purposes as well as lubrication.
The OP is free to do whatever he likes, but on a decent condition small air cooled single that runs nicely and is used pretty hard, I would be in the 1000mile-1500mile oil change club and cleaning out the less than perfect simple gauze filter screen if a proper full flow cartridge element is not used. |
| stunthamster |
| Pete. |
 Pete. Super Spammer
 Posted: 21:23 - 05 Feb 2014 Post subject: |
I say don't do it, that's a nightmare commute on a full sized bike - on a 125 doing 40k miles a year in all weathers your bike will be scrap before the first year is out. What little life the commute doesn't suck out of you will be spent servicing and changing parts. If you're hell-bent on it I say find a good secure place to park the bike every day, get the train in to London and then ride the bike across town. ____________________ a.k.a 'Geri'
| trevor saxe-coburg-gotha |
 trevor saxe-coburg-gotha World Chat Champion
The last post was made 12 years, 224 days ago. Instead of replying here, would creating a new thread be more useful? |
