Would you keep riding on this tyre?
Ride or replace
Keep riding on the tyre
27%
 27%  [ 20 ]
Replace the trye
72%
 72%  [ 54 ]
Total Votes : 74
Vracktal
PostPosted: 10:44 - 05 Feb 2014    Post subject: Would you keep riding on this tyre? Reply with quote
So, after a blowout on the A3 on Monday, I decided to swap both my tyres for a pair of brand new Continental Road Attack 2 tyres.
However, by Wednesday...
https://farm6.staticflickr.com/5523/12319154634_3042e9d793_b.jpg
Just noticed this at work. The culprit this time:
https://farm3.staticflickr.com/2836/12319157974_18f7efe7b5_b.jpg
My question is, although the blade has gone through the tread, the shallow angle means it doesn't seem to have gone all the way into the tyre- it's still holding air (for now, anyway)
My question is, should I replace the tyre, or should I just keep riding on it? My commute is generally 15 miles city riding followed by 15 miles motorway (80-90mph stuff)
I'm worried the tread will rip further and eventually delaminate, but on the other hand I can't afford a new rear to replace one that's only literally two days old.
2007 BMW R1200R: On road
2009 BMW G650X Challenge: On road
1975 Norton Commando 850: Off road, awaiting recommissioning
Benjums
PostPosted: 10:53 - 05 Feb 2014    Post subject: Reply with quote
Can't see the pics mate, although by your description I would replace the tyre because that is a week spot and if you have a blow out at 80-90 on the motorway then your going to be doing one hell of a superman impression but I don't think you will get the landing right.
Can see the pics now.
Musketeer
PostPosted: 10:56 - 05 Feb 2014    Post subject: Reply with quote
If it was me I would change the tyre. Shame it happened to a new tyre but it's f00ked now. But that's just my opinion.
If it was just a nail puncture I would plug it.
Rob W
PostPosted: 10:58 - 05 Feb 2014    Post subject: Reply with quote
I personally wouldn't be going mad on that. That must of penetrated a fair way through the tread, albeit at a shallow angle, and although the thing's holding air at the moment, I wouldn't fancy having a possible weakness in a tyre when doing 80-90mph on a motorway.
I know how it feels though to have that happen, I once had a new rear boot put on my K4, and came home to see a screw buried in it, literally less than 10 miles old.
Easter Bunny
PostPosted: 11:01 - 05 Feb 2014    Post subject: Reply with quote
The difference between the amount of blade visible and the picture of it in your hand is quite worrying so I would possibly change it, and that's coming from someone who plugs their punctures from the outside and rides on them til they are done!
PostPosted: 11:06 - 05 Feb 2014    Post subject: Reply with quote
Replace with a part worn. Thumbs Up
c-m
PostPosted: 11:11 - 05 Feb 2014    Post subject: Reply with quote
I enjoyed a front blow out on the autoroute at over 80mph. Nothing much happened other than the steering got heavy and the bike wobbled a little. It was easy to come of the throttle slowly and pull over.
The tyre had a hole large enough to fit four fingers in.
Rizzix
PostPosted: 11:17 - 05 Feb 2014    Post subject: Reply with quote
*childish snigger*
PostPosted: 11:27 - 05 Feb 2014    Post subject: Reply with quote
I'd ride that bitch.
recman
PostPosted: 11:37 - 05 Feb 2014    Post subject: Reply with quote
And only that bitch with the front wheel up?
For piece of mind, change the tyre.
c_dug
PostPosted: 11:39 - 05 Feb 2014    Post subject: Reply with quote
I've ridden on worse and at higher speeds, your life to risk though not mine.
chickenstrip
PostPosted: 11:45 - 05 Feb 2014    Post subject: Reply with quote
For me, it's always a case of, certain things you can let go to a degree on a bike, but when it's tyres or brakes, don't mess about. I'd replace it.
-Matt-
PostPosted: 11:49 - 05 Feb 2014    Post subject: Reply with quote
Same as this for me, especially considering you do a lot of motorway miles - I wouldn't want to find out it should of been replaced afterall mid-commute at 90mph Shifty
One of those inevitable ironies that when you get something nice and new something comes along and does it in shortly after.
Benjums
PostPosted: 11:55 - 05 Feb 2014    Post subject: Reply with quote
Rizzix wrote:
*childish snigger*
Twisted Evil
woo
PostPosted: 13:26 - 05 Feb 2014    Post subject: Reply with quote
i would buy punctureseal and put that in your tyre, punctureseal has done me fine on three different puntures so far
Elen sila lummen omentielvo!
PostPosted: 13:52 - 05 Feb 2014    Post subject: Reply with quote
Depends how far it went in.
If it didn't go deeper than the deepest bit of tread, I'd ride on it without giving a single fuck.
If it went deeper than that, I'd be a bit wary of it.
ViniH
PostPosted: 13:59 - 05 Feb 2014    Post subject: Re: Would you keep riding on this tyre? Reply with quote
Get the damaged area vulcanised. We have a guy in the area that comes out and fixes punctures properly, I am sure there will be a similar service in your area.
No need for a new tyre, but I wouldn't feel safe on that myself without getting it repaired.
Currently Riding: MT-07 Previous: XJ 600 N
garth
PostPosted: 15:23 - 05 Feb 2014    Post subject: Reply with quote
I'd ride on it, but if it was a big gash (...never good) then I'd get my fingers and stuff some vulcanising glue in it. I'd probably make tennis noises at the same time. You should do too.
Vracktal
PostPosted: 15:35 - 05 Feb 2014    Post subject: Reply with quote
I'm trying to work out how deep it went, I think it went deeper than the tread though, based on how fuckoff massive the blade is. The tyre is still holding air but I can peel a chunk of the rubber almost a half centimeter thick away from the main carcass.
https://farm8.staticflickr.com/7409/12322904213_24120c1d0d_b.jpg
covent.gardens
World Clap Champion
PostPosted: 15:41 - 05 Feb 2014    Post subject: Reply with quote
I rode for months with no effective front brake... but I wouldn't ride with that tyre, not unless it's looked at/fixed anyway.
Looks like it's gone in too far IMO, problem is too bad to ignore.
TT_Man
PostPosted: 15:45 - 05 Feb 2014    Post subject: Reply with quote
I would change it, although shallow it went deep enough to damage the strengthening chords. Could fail catastrophically under load.
chickenstrip
PostPosted: 16:14 - 05 Feb 2014    Post subject: Reply with quote
That seems really odd to me. Maybe I'd put up with an ineffective rear brake for a short while, if I had no alternative transport. But at this time of year, when you might favour the rear a bit more due to slippery conditions, I'd still sort it ASAP. No front brake? No way.
Is there any kind of repair that would guarantee that tyre? I doubt it. You'll be forever wondering if you don't replace it.
devojunior
PostPosted: 16:19 - 05 Feb 2014    Post subject: Reply with quote
just ride it, but if you do go for the gay option and finning anew tyre make sur eto post vids of rolling burnouts and stuff yeah .
iooi
PostPosted: 16:36 - 05 Feb 2014    Post subject: Reply with quote
Take a trip back to the garage that supplied the tyre. Get them to take it off and have a proper look at the damage from the inside.
Do they not have a guarantee on things like this. Avon do.
Islander
PostPosted: 17:17 - 05 Feb 2014    Post subject: Reply with quote
If you suspect that it's penetrated the carcass then I'd say replace it. If it's been ridden then who knows what damage it may have inflicted. It's a tough call.
The last post was made 12 years, 239 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.52 - MySQL Queries: 15 - Page Size: 129.95 Kb
