Cinema Speaker - Sub Woofer help
Bubbs
PostPosted: 20:07 - 05 Feb 2014    Post subject: Cinema Speaker - Sub Woofer help Reply with quote
Hi guys,
Hope you can help. I have a subwoofer that uses the wire connections as show in the picture, them ones that you press a toggle and insert a copper wire and leave go so it holds it.
https://encrypted-tbn2.gstatic.com/images?q=tbn:ANd9GcQEYSDsMtS1esMd2t8WmydLFjMax7ADWwLtpheLqhytRUfoxQDH
But my amp only takes this kind of cable connection.
https://ep.yimg.com/ay/yhst-25967117716530/subwoofer-cables-5.gif
How do I make it work?
T1z3R
PostPosted: 22:01 - 05 Feb 2014    Post subject: Reply with quote
sounds like you have a passive sub (non amplified) and are trying to connect it to a 5/7/9.1 amplifier?
duck my sick!
prawny1
PostPosted: 22:08 - 05 Feb 2014    Post subject: Reply with quote
you can buy wire with a phono on one end and loose wires on the other but I find these adaptors to be much neater
https://www.ebay.co.uk/itm/10x-UTP-CAT5-CAT6-Speaker-Wire-to-Audio-Video-Phono-Male-RCA-Connector-Jack-Plug-/390644683976?pt=UK_Computing_Sound_Vision_Audio_Cables_Adapters&hash=item5af43cd4c8
Just make sure you wire them up in the correct polarity to your speaker
If your amplifier only has a single phono out for the sub then chances are it is set up for a single voice coil speaker, how many pairs of wires are on the sub 1 or 2?
hellkat wrote:
Rowey
PostPosted: 00:36 - 06 Feb 2014    Post subject: Reply with quote
Is your sub powered/active? Does it have it's own mains power plug? Then it will normally take one or two of the co-ax connectors shown in your second picture. These pre-amp connections only output an audio signal and the amplifier in the sub will "push" the speaker.
If there is no built in amplifier in the sub (passive) then you will need the specific powered outputs for the sub, like you have for your speakers. Most AVRs wont. Those will put out a powered AC current to move the speaker.
You can get sub-woofer amplifiers that you would chain AVR > sub amplifier > subwoofer. But you'll get better sound and save money getting a decent powered sub. Most people will agree that active subs will beat passive any day.
ZX6R C6F.
Bubbs
PostPosted: 10:53 - 06 Feb 2014    Post subject: Reply with quote
Pretty sure it doesn't have a power cable. I do have a pretty decent amp though... would that not power the sub quite well?
Thanks for the info.
T1z3R
PostPosted: 16:58 - 06 Feb 2014    Post subject: Reply with quote
your amp wont power the sub at all as its expecting you to have an active one.
duck my sick!
Bubbs
PostPosted: 17:00 - 06 Feb 2014    Post subject: Reply with quote
Ah right ok. Cool.
Bit of a N00b when it comes to this stuff.
Karma
The last post was made 12 years, 246 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 53.21 Kb
