will the mileage of my derbi be in KMs??
TomC
PostPosted: 12:23 - 31 Dec 2004    Post subject: will the mileage of my derbi be in KMs?? Reply with quote
Hello, i have recently bought a Derbi Senda R under the impression that that it has 15000 miles on the clock, this is what the counter reads, but is this actually in KM? Is there anyway this could have been changed so it was in miles?
The reason i am wondering was because i was thinking of doing an engine rebuild to replace piston rings but cant really afford it now with all the costs of starting out and if i can get away with it i would rather leave it for a while, as i would think it would be alrite if it has just done under 10000 miles.
nick.h
PostPosted: 12:58 - 31 Dec 2004    Post subject: Reply with quote
is the speedo in mph or kmph?
[Italjet MM5A] ll [Rieju RS1 Evolution] ll [Suzuki GS500e] ll [Suzuki GSX600F] ll [Honda CG125] ll [Pug Elyseo 125] ll [Yamaha YZF750R] ll [Yamaha Thunderace] ll [Yamaha R6] ll [Triumph 955i] ll [Hayabusa RZK3] ll [Suzuki RGV250] ll
TomC
PostPosted: 13:04 - 31 Dec 2004    Post subject: Reply with quote
It has both...
PostPosted: 13:06 - 31 Dec 2004    Post subject: Reply with quote
Which is the speedo in, they all have it on both normally with MPH on the outside with small KMPH markings on it as well.
It'll be whatever the speedo is in.
meyrick
PostPosted: 13:09 - 31 Dec 2004    Post subject: Reply with quote
I've been wondering this about my CB125T. It has kph on the outside and mph in smaller print on the inside of the speedo, so I'm assuming the odo is in km.
An easy way to tell is to clock a route on some other vehicle that records miles and do the same on the bike. Should be obvious pretty soon which it is.
Paul Smile
PostPosted: 17:03 - 31 Dec 2004    Post subject: Reply with quote
Chances are, the main face is in KM/s because 90% of Derbi's are.
If its in miles, then the bike is well overdue a new set of rings as they need replacing at 10,000. If its in kilometers, you'll be coming up to the 10,000 mile pretty soon.
Either way, it wont hurt to replace the rings. The bottom end should be fine for a long time though, wont need a rebuild unless something nasty happens down there.
As Ste said, you'll have to check what the main indicated speed is on your clocks (whats on outside, whats on the inside), then you'll know.
Aprilia RSV Mille R Edwards Replica - Aprilia RS250 - Suzuki GSXR600 Supersport Race Bike
mchaggis
PostPosted: 03:23 - 01 Jan 2005    Post subject: Reply with quote
Don't rely on the main speedo units to tell you the units for the odomoter. If it's a (grey) import, it might have only had the kph face replaced with a face with mph instead. The best way to tell is simply to make a journey of which you know the length of, 20+ miles to be sure.
I must not be a troll...
Mmmm, Guinness
superchoward
PostPosted: 15:05 - 01 Jan 2005    Post subject: Reply with quote
My Speedfight has the mileage in KM's and the main units shown are KM/ph on the speedo. With MPH underneath in smaller numbers. Prefer MPH myself and was rather pissed off at this.
Hope This Helps
Chris
binge
Emo Kiddy
PostPosted: 00:03 - 02 Jan 2005    Post subject: Reply with quote
Its pretty easy to do...
Ride at 30mph for 1 mile/km (whatever it is on the clock)
and time yourself, When you do 1 mile/km just do the maths and you know...
<|Binge|>
(its more than likley in KMph
TomC
PostPosted: 00:28 - 02 Jan 2005    Post subject: Reply with quote
yup will do that on monday once im out on the roads after my cbt, cheers all.
The last post was made 21 years, 277 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 63.35 Kb
