Excel help needed! Filtering data and nice dropdowns
metalangel
PostPosted: 17:06 - 06 Feb 2014    Post subject: Excel help needed! Filtering data and nice dropdowns Reply with quote
Excel wizards, please help!
I’ve been given a list of vendors. Each covers one or more of our three regions: West, Central and East.
What I’m trying to do is have a nice little drop down box at the top spreadsheet where I can tick whether I want some or all of the vendors to show based on their region – complicated because some cover more than one region.
I don’t have a clue how to do this, and once I’ve figured it out I’ll need to do it again to narrow the results even further based on which of three departments here they work with.
Thank you!
Aff
PostPosted: 17:08 - 06 Feb 2014    Post subject: Re: Excel help needed! Filtering data and nice dropdowns Reply with quote
Can you send an example of the Spreadsheet?
If not it depends how the multiple locations are set up.
If they are in separate rows then its easy.
Just make a pivot table with the vendor as the column and the different location rows as separate report filters.
Electric Bike Project
metalangel
PostPosted: 17:30 - 06 Feb 2014    Post subject: Reply with quote
At the moment it's divided by columns, vendor name, address (this isn't something I am going to let them search by) and then region.
I had the idea of making a separate column for west, central and east and putting an X in if that region is covered by that vendor, because I don't have a clue what I'm doing.
metalangel
PostPosted: 17:47 - 06 Feb 2014    Post subject: Reply with quote
Made a Pivot Table, seems halfway there - how would you set it so you can have multiple words in the Regions column (for example, Central and West) but be able to pick either just one or both?
PostPosted: 17:55 - 06 Feb 2014    Post subject: Reply with quote
https://www.wikihow.com/Use-AutoFilter-in-MS-Excel
Aff
PostPosted: 18:27 - 06 Feb 2014    Post subject: Reply with quote
Highlight all the region cells and click Data>Text to Columns. then choose Delimited and select what they are separated by (comma, space, tab, ect).
Then you can either do a Pivot table or a filter, I think pivot table are a bit tidier.
metalangel
PostPosted: 18:44 - 06 Feb 2014    Post subject: Reply with quote
That doesn't seem to solve the issue. I want to have multiple words in the same column, but not have those show up as separate options. As it stands when I make a table now, I can sort the data by:
West
West Central
West East
East
What I want to show up is:
West
Central
East
So that if I select West, I get all stuff that is West only as well as everything that is West Central and West East. Likewise if I were to tick both West and Central then I would only get stuff that fulfills both those criteria.
This is why I wondered if having separate columns for each region with a tick mark would help as that could basically work as a flag when it searches - if Column E has an X then it shows up in a search for West. I am just confusing things further by doing that, I think.
PostPosted: 18:51 - 06 Feb 2014    Post subject: Reply with quote
Have you tried the auto filter yet?
metalangel
PostPosted: 19:06 - 06 Feb 2014    Post subject: Reply with quote
That sort of does what I want, but I had hoped to have three tick boxes to set the filter as opposed to having to type it in. As it stands if I tick West it filters precisely that value only while if I type it, it does what I want and gives me all the results that contain West, including those that also contain East and Central.
PostPosted: 19:08 - 06 Feb 2014    Post subject: Reply with quote
Can't you click on "custom", then select "contains" and set it to "West"?
What version of Excel are you using?
PostPosted: 19:30 - 06 Feb 2014    Post subject: Reply with quote
Is this close to what you're after?
metalangel
PostPosted: 19:34 - 06 Feb 2014    Post subject: Reply with quote
I can do that, but that doesn't let me add a specific "Central" tick box to the filter nor does it let me remove the tick boxes that combine values.
Excel 2010. Section of the file (with company names changed, obv) is here:
https://skydrive.live.com/redir?resid=705BF3A6F7ED7E60!167&authkey=!AJYJjTqKxCVqiJU&ithint=file%2c.xlsx
metalangel
PostPosted: 00:20 - 07 Feb 2014    Post subject: Reply with quote
Now that I'm home and can look at the file... you're at the same stage I'm in, in that you need to type in a search for something, you can't define one of those tickboxes to mean the same as a 'contains' search, only an 'equals' search.
Thanks for trying, I think tomorrow I'll just move on to the next stage which is combining the data from another two spreadsheets in. The main reason this is being done is because an exec asked three departments to list all their vendors, and each one did it differently. He's picked the format he likes best and is asking that I change the data from the other two to fit its arrangement. That 'text to columns' thing is new to me and might come in very handy if I can figure out a way to make it split company names and office locations out given they aren't all in the same cities... Karma
el_oso
PostPosted: 22:31 - 07 Feb 2014    Post subject: Reply with quote
open vba and define your own filters.
you could also have two rows for a particular company
Duke 390
Car: Jeep Wrangler 4.0L
D O G
PostPosted: 00:17 - 08 Feb 2014    Post subject: Reply with quote
You are creating a lot of aids for yourself and ongoing confusion for the company by fudging the shit out of the data yourself.
Furthermore, by taking on the responsibility of assigning the regions to the vendors yourself, when the exec starts questioning the departments about their vendors, they will be able to point the finger at you for dicking about with the region assignment.
Your solution for this is nothing to do with Excel.
What you need to do is define the regions with the exec, communicate these to the departments, and have them assign the vendors appropriately.
That at least will avoid you getting any shit, and is a perfectly reasonable thing to request, now that the exec has made a decision as to how he wants it. Make it clear it is his wish, if they don't comply, they have to answer to him.
Now. If there are vendors who cover multiple regions, then have THREE columns, one central, one east, one west. Use a drop down list to have a 'Yes' in these columns for the depts to select whether that vendor covers (or is based in?) that region, or leave blank/use 'No'. Then you can filter using these columns easily, or more nicely, a simple pivywiv table of joy will sort you out.
So yeah, properly define the requirement, then give the buggers a template to fill out which fits your purpose.
metalangel
PostPosted: 16:26 - 08 Feb 2014    Post subject: Reply with quote
What the fuck are you on about?
D O G
PostPosted: 00:54 - 09 Feb 2014    Post subject: Reply with quote
I'm trying to help you do your job better, rather than fucking around because you lack the balls to go back to the departments now that you actually know the requirement.
metalangel
PostPosted: 01:32 - 09 Feb 2014    Post subject: Reply with quote
If you saw the extent information I'd already been provided with and the full details of what I've been asked to do with it, rather than second guessing, you'd see what a load of nonsense you'd just talked.
Probably the most crucial thing is that all of the vendors came on lists specifically saying what regions they service. I have everything I need already to get this done as requested, and just wanted to make it a bit nicer looking in Excel, hence that being the only thing I asked for help on.
D O G
PostPosted: 10:48 - 09 Feb 2014    Post subject: Reply with quote
Three columns to the right of the data.
One titled 'West', one titled 'Central', one titled 'East'.
Use logic formula to populate these columns with 'Yes' if that vendor services that area (or you can do it manually for the ambiguous ones).
Some vendors will have 'Yes' in only one, some in two, and some in all three.
Then whack it into the pivot. Use the region columns as filter fields on the pivot. To select West vendors only, set the west column to 'Yes', and have the other two unfiltered. To find those which service west and east but not Central, set West column to 'Yes', Central to '(blanks)' and East column to 'Yes'.
By adding further columns to the right, you can use those to populate which departments they work with - which should be a piece of piss to populate as you will be able to use the list the department sent you as a data source for a logic formula using a vlookup to give a 'Yes/no' determination for any vendor. Probably take you an hour or two at most, including time for ironing out any issues with naming consistency.
el_oso
PostPosted: 10:57 - 09 Feb 2014    Post subject: Reply with quote
you obviously don't work with large datasets that often. What D O G suggested is perfectly reasonable. If it really is that large of a dataset and you want it to look pretty do it in access and design a form.
Duke 390
The last post was made 12 years, 240 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 115.29 Kb
