After calliper rebuild, squishy brakes
rehmh05
PostPosted: 20:15 - 07 Feb 2014    Post subject: After calliper rebuild, squishy brakes Reply with quote
Finished rebuilding front calliper of my bandit 600 SK1 (mk2) (new pads inserted aswell). After rebuild, accidentally let the master cylinder get drained under gravity as I was putting the brake line onto the callipers.
I filled the master cylinder up with new fluid and tried to get the fluid into callipers. Now i pumped it a few hundred times literally but the brakes are squishy. What surprised me more is that the front wheel drags but brakes do not work. I roll the bike forward and there is a very small force in the braking.
My questions are; how do i rid the squishyness and the wheel drag?
P.S I am most certain I put pressure seals in the right way.
- CBT 31/10/12 - CBR 125 bought 01/11/12
- Theory: 07/11/12 - Mod 1: 19/11/12 - Mod 2: 28/11/12
- 24/08/13 - Bandit 600
Nobby the Bastard
Harley Gaydar
PostPosted: 20:34 - 07 Feb 2014    Post subject: Reply with quote
Have you actually attempted to bleed the brakes?
Triumph Sprint ST 1050
zapmole
PostPosted: 20:43 - 07 Feb 2014    Post subject: Reply with quote
Sounds like there is air in the system. Bleed the brakes first and it should solve the problem . If they are only slightly catching that will soon wear down. Long as they release after pulling them.
Honda CG 125 red 1991
evilbond
PostPosted: 22:41 - 07 Feb 2014    Post subject: Re: After calliper rebuild, squishy brakes Reply with quote
As said above bleed the brakes.
Aslong as you have the oil seal in first and the dust seal in second you should be fine.
The oil seal is square so doesnt matter which way round you put it in, i thought they went in one way with a lipped edge making the seal, but these ones apparently are not lipped.
Bike: K2 Bandit 600S
Car: Astra GTC
BillyJ
PostPosted: 23:55 - 07 Feb 2014    Post subject: Reply with quote
https://www.therevcounter.co.uk/motorbike-articles/34369-motorbike-brakes-beginners-information-bleeding-guide.html
Had: '06 CBR125R + '01 GSF600 + '07 SPRINT ST 1050 + '80 CB250 RSA + '93 Ducati 900SS
Have: '13 GSXR-1000 + '01 CB500S
"The aryan confuser"
Major Doss
PostPosted: 00:05 - 08 Feb 2014    Post subject: Reply with quote
front wheel drags= bound piston(s). are you sure that the pistons are pukka/clean? ineffective brakes when you have not bled=air in system. either is no good, strip and redo as per. Thumbs Up sometimes can be a drag (sic) depending on system, some are easier than others. as far as lips go, this will be the fluid seal, this is innermost of the two seals, and the narrowest bit goes towards the back of relevant piston. flat square seal is pad side, just a dust seal. start by trying to bleed for now, this will determine if the M cylinder seal is carp, before you strip all else.
soz about grammar, poxy thing won't auto whatever, im playing darts with beer!
Antisocial phucker.
Nobby the Bastard
Harley Gaydar
PostPosted: 00:07 - 08 Feb 2014    Post subject: Reply with quote
Not necessarily. It could be fucked bearings. It wouldn't be the first time that the repair attempt has focused on the wrong cause or a second problem has arisen when fixing the first.
Did you use red grease on the the piston/seals when you put them in? You should have got some with the seals.
Major Doss
bugger. BillyJ beat me up! karma, dude! Thumbs Up
Antisocial phucker.
Major Doss
PostPosted: 00:09 - 08 Feb 2014    Post subject: Reply with quote
could be, Nobby, could be. Doubt it. but could be.
Antisocial phucker.
PostPosted: 00:13 - 08 Feb 2014    Post subject: Re: After calliper rebuild, squishy brakes Reply with quote
What they said, you can pump away all day long, but unless you twist the nipple, you'll never get really hard.
If you tell us exactly what you have and haven't done, you can get detailed, helpful advice.
exuptoy
PostPosted: 00:43 - 08 Feb 2014    Post subject: Reply with quote
Either reverse bleed them with a big syringe or when you've bled the calliper, put a rubber tube from the bleed nipple into an old pot of brake fluid and pump until no more bubbles appear through the tube.
Brakes could be dragging if the seal is in backwards.
Chaos, panic, destruction....my work here is done
Major Doss
PostPosted: 00:45 - 08 Feb 2014    Post subject: Reply with quote
A simple clean up and bleed, turned into a £200 rebuild. My customer quite rightly would not pay for the entire amount. His insistance on knackered bearings should not of swayed me when I suggested a £20 SH set of discs we had lying about and £20 labour. More fool me. I were right, yet cost my pocket. Go for the easy stuff. ONCE you have all the info. Thumbs Up Use your noodle, eh? We all learn. Wink
Antisocial phucker.
Major Doss
PostPosted: 00:47 - 08 Feb 2014    Post subject: Reply with quote
the seal backwards will piss fluid. Shocked
But you are spot on re; bleeding.
Antisocial phucker.
bladerunner
PostPosted: 00:56 - 08 Feb 2014    Post subject: Reply with quote
If your bleeding the brakes...do the M/C first or you'll never win! Pump the lever a few times and undo the banjo bolt ...you'll hear if any air escapes or see bubbles. Once that's bled then your good to do the calipers.
Nobby the Bastard
Harley Gaydar
Jesus, the echo in here is fucking deafening....
Major Doss
PostPosted: 00:58 - 08 Feb 2014    Post subject: Reply with quote
Antisocial phucker.
Major Doss
PostPosted: 00:59 - 08 Feb 2014    Post subject: Reply with quote
Antisocial phucker.
Major Doss
Antisocial phucker.
rehmh05
PostPosted: 01:59 - 08 Feb 2014    Post subject: Reply with quote
sorry for the late reply guys, cant use the bike, so was on foot all over the place. got back recently.
Well, as i said i rebuild it correctly to the best of my knowledge and ability. I do believe i put the seals in the right way. most certain meaning there is a slight chance of human error.... apart from that i had let the M/C drain accidental as i tried to bolt the calliper to the brake line.
I was planning on bleeding the brakes after they got stiff which never happened..... I suppose that is the mistake i am making? Confused
The bleeding is to be done first? I am advised to bleed the master cylinder? How is that done, can you elaborate? And i thought the master cylinder pushed everything down,incl. the air bubbles?
And then I should bleed the callipers 2nd should I? I have the tube thing but only a small 10 ml syringe atm ....
Major Doss
PostPosted: 02:01 - 08 Feb 2014    Post subject: Reply with quote
See BillyJ's link. Thumbs Up
Antisocial phucker.
rehmh05
PostPosted: 02:03 - 08 Feb 2014    Post subject: Reply with quote
ok
rehmh05
PostPosted: 02:15 - 08 Feb 2014    Post subject: Reply with quote
can someone confirm if the RH calliper is bled first or the LH (as i sit on it?) I have seen otherwise ....?
Also, will master cylinder need bleeding aswell if the whole brake line system is bled?
Major Doss
PostPosted: 04:43 - 08 Feb 2014    Post subject: Reply with quote
God man, read the damn link kindly given by BillyJ! Brick Wall Left/right, I have usually found it necessary to do both sides a few times to get a solid feel on my lever. It is vital to keep a good rhythm with your 8mm nut. This is your bleed screw. Keep on pumping, pump until you are fainting from cramp, not forgetting to twiddle your nut, top up your fluids, mind, dehydration is your enemy. Then pump some more. If fatigue becomes too much of an issue, do NOT let the pressure up! Swap hands! Sometimes a friendly neighbour may be of help. Keep pumping. Twiddle your nuts. When you think it is getting hard, NOW is the time to get busy with her other caliper. Repeat until hard/exhausted/out of DOT4. Go to clinic/bike shop.
HTH. Thumbs Up
I am sure I have missed something, Bearings, cockrings or something.
Antisocial phucker.
bladerunner
PostPosted: 12:10 - 08 Feb 2014    Post subject: Reply with quote
Do the MC first like I said before.....not included in the link! Your brake line is a tube of liquid and thus air bubbles will rise to the top. If air is in the top as you let the fluid drain out of the MC then it will compress making the MC ineffective at pressurising the system and the air bubbles will keep rising faster than you can pump them the length of the brake line.good luck with bleeding that! Your just wasting brake fluid and not removing the air......it's more of an issue on bikes that have the top banjo bolt higher than the lower part of the MC piston travel.
I've explained how to do it already. Once you know that's done your ready to bleed the calipers.........once you get the air out of them...job done. Then you can look at what's causing your other issues. I've known new seals and pistons take a bit of bedding in to get the best out of them.
mogstar
PostPosted: 12:14 - 08 Feb 2014    Post subject: Reply with quote
and don't over-tighten the bleed nipple unless you want more grief
plenty of brake bleeding vids on youtube too
The last post was made 12 years, 247 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 127.38 Kb
