| rehmh05 |
 rehmh05 Nova Slayer
| Nobby the Bastard |
| zapmole |
 zapmole Borekit Bruiser
| evilbond |
 evilbond Two Stroke Sniffer
| BillyJ |
 BillyJ Nearly there...
| Major Doss |
 Major Doss Traffic Copper
 Posted: 00:05 - 08 Feb 2014 Post subject: |
front wheel drags= bound piston(s). are you sure that the pistons are pukka/clean? ineffective brakes when you have not bled=air in system. either is no good, strip and redo as per. sometimes can be a drag (sic) depending on system, some are easier than others. as far as lips go, this will be the fluid seal, this is innermost of the two seals, and the narrowest bit goes towards the back of relevant piston. flat square seal is pad side, just a dust seal. start by trying to bleed for now, this will determine if the M cylinder seal is carp, before you strip all else.
soz about grammar, poxy thing won't auto whatever, im playing darts with beer! ____________________ Antisocial phucker. |
| Nobby the Bastard |
| Major Doss |
 Posted: 00:07 - 08 Feb 2014 Post subject: |
bugger. BillyJ beat me up! karma, dude!  ____________________ Antisocial phucker. |
| Major Doss |
| Rogerborg |
 Rogerborg nimbA
 Posted: 00:13 - 08 Feb 2014 Post subject: Re: After calliper rebuild, squishy brakes |
What they said, you can pump away all day long, but unless you twist the nipple, you'll never get really hard.
If you tell us exactly what you have and haven't done, you can get detailed, helpful advice. ____________________ Biking is 1/20th as dangerous as horse riding.
| exuptoy |
 exuptoy Borekit Bruiser
| Major Doss |
 Posted: 00:45 - 08 Feb 2014 Post subject: |
A simple clean up and bleed, turned into a £200 rebuild. My customer quite rightly would not pay for the entire amount. His insistance on knackered bearings should not of swayed me when I suggested a £20 SH set of discs we had lying about and £20 labour. More fool me. I were right, yet cost my pocket. Go for the easy stuff. ONCE you have all the info. Use your noodle, eh? We all learn.  ____________________ Antisocial phucker. |
| Major Doss |
| bladerunner |
 bladerunner World Chat Champion
| Nobby the Bastard |
| Major Doss |
| Major Doss |
| Major Doss |
| rehmh05 |
 rehmh05 Nova Slayer
 Posted: 01:59 - 08 Feb 2014 Post subject: |
sorry for the late reply guys, cant use the bike, so was on foot all over the place. got back recently.
Well, as i said i rebuild it correctly to the best of my knowledge and ability. I do believe i put the seals in the right way. most certain meaning there is a slight chance of human error.... apart from that i had let the M/C drain accidental as i tried to bolt the calliper to the brake line.
I was planning on bleeding the brakes after they got stiff which never happened..... I suppose that is the mistake i am making?
The bleeding is to be done first? I am advised to bleed the master cylinder? How is that done, can you elaborate? And i thought the master cylinder pushed everything down,incl. the air bubbles?
And then I should bleed the callipers 2nd should I? I have the tube thing but only a small 10 ml syringe atm .... ____________________ - CBT 31/10/12 - CBR 125 bought 01/11/12
- Theory: 07/11/12 - Mod 1: 19/11/12 - Mod 2: 28/11/12
- 24/08/13 - Bandit 600 |
| Major Doss |
 Posted: 02:01 - 08 Feb 2014 Post subject: |
See BillyJ's link.  ____________________ Antisocial phucker. |
| rehmh05 |
 rehmh05 Nova Slayer
| rehmh05 |
 rehmh05 Nova Slayer
| Major Doss |
 Posted: 04:43 - 08 Feb 2014 Post subject: |
| bern wrote: | | Nobby the chihuahua wrote: | Jesus, the echo in here is fucking deafening.... |
God man, read the damn link kindly given by BillyJ! Left/right, I have usually found it necessary to do both sides a few times to get a solid feel on my lever. It is vital to keep a good rhythm with your 8mm nut. This is your bleed screw. Keep on pumping, pump until you are fainting from cramp, not forgetting to twiddle your nut, top up your fluids, mind, dehydration is your enemy. Then pump some more. If fatigue becomes too much of an issue, do NOT let the pressure up! Swap hands! Sometimes a friendly neighbour may be of help. Keep pumping. Twiddle your nuts. When you think it is getting hard, NOW is the time to get busy with her other caliper. Repeat until hard/exhausted/out of DOT4. Go to clinic/bike shop.
HTH.
I am sure I have missed something, Bearings, cockrings or something. ____________________ Antisocial phucker. |
| bladerunner |
| mogstar |
 mogstar Nova Slayer
The last post was made 12 years, 247 days ago. Instead of replying here, would creating a new thread be more useful? |
