Honda XR 125 Won't start suddenly
adam2013
PostPosted: 20:41 - 07 Feb 2014    Post subject: Honda XR 125 Won't start suddenly Reply with quote
Hi, I changed my chain and sprocket today(working top notch before)
just did the normal change quick and easy then when i was finished i gave the chain a good spray of gt85 while i had the sprocket cover off
(please bare in mind that their are wires behind the sprocket cover, may have got some gt85 on the connections but gt85 is a water displacer so should not affect wires.)
Then when it was back on the ground and ready to go out, turned the key and nothing no power at all.
I checked the solenoid as I replaced this 2 weeks ago because the old one failed. I don't know how to explain this but this is how I see it
The solenoid has a B and a M( the B connects directly to the battery and M to the wires to everywhere else)
The B is 12.8v as is the battery and the M is 0.00v and all connections are clean and new
Thanks for any help in advance Very Happy
Current: '04 Honda XR 125L
Project: '86 Yamaha DT 125LC
zapmole
PostPosted: 20:50 - 07 Feb 2014    Post subject: Reply with quote
Is the solenoid for the starter motor? If so then when the ignition is on your m connection should show voltage while your pressing the starter button down. Ad nothing when it's not pressed. Also you should be able to hear the solenoid click when you do it.
Honda CG 125 red 1991
adam2013
PostPosted: 20:57 - 07 Feb 2014    Post subject: Reply with quote
hi thanks for replying there is no power to the bike at all so if I press the starter button there is not sound no nothing. the bike is completely dead atm Sad
zapmole
PostPosted: 21:03 - 07 Feb 2014    Post subject: Reply with quote
No power at the key but the battery is showing voltage ? I would check the connections at where ever they go follow your loom double check everything. I'm only on a Honda cg and know that most of the wiring is behind the headlight. Might be similar ? Trace the power supply making sure it goes from your battery to the ignition key. Also have you checked the fuse ?
adam2013
PostPosted: 21:06 - 07 Feb 2014    Post subject: Reply with quote
All the fuses are fine and nearly new and I cant check the connections now but i can in the morning however i don't know how it could be the connections behind the head light are any main connections in fact as all i did was change the chain and sprocket never touched anything else.
zapmole
PostPosted: 21:19 - 07 Feb 2014    Post subject: Reply with quote
If you have 12v at the battery but nothing else then there's a break in a connection or the battery has been drained but normally if that happens you should still be able to bump start it. Not an awful lot to it without doing some tests with a multi meter
adam2013
PostPosted: 21:26 - 07 Feb 2014    Post subject: Reply with quote
Ok thanks will do some diagnostics tomorrow as i have a night shift tonight Sad
The last post was made 12 years, 259 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 53.03 Kb
