70cc kit
Dam_buster
PostPosted: 12:16 - 30 Dec 2004    Post subject: 70cc kit Reply with quote
right should i have gotten a bigger carburettor? or should i just leave it, with an up jetted standard carb?
just talkin 2 a mate and he said i should have gotten a bigger carb!
so naturally i started to worry!
Jim
Yamaha R6 5EB, BMW 328i Touring, BMW 328i Coupe
PostPosted: 12:27 - 30 Dec 2004    Post subject: Reply with quote
Depends what is on there already. Chances are that you would probably get a power gain from a larger carb as well (after all you have increased the engine capacity by 40%, so the chances are the stock carb will now be a touch restrictive).
Dam_buster
PostPosted: 12:42 - 30 Dec 2004    Post subject: Reply with quote
ah ok well ill see if i can get one from a brokers yard... IE EBAY lol
divuk83
PostPosted: 15:39 - 30 Dec 2004    Post subject: Reply with quote
A 19mm carb is fine for an MHR rep kit.
Dave
Kye
PostPosted: 08:32 - 31 Dec 2004    Post subject: Reply with quote
You don't NEED a bigger carb, just it will give you more power, anything around / above 17.5mm works well on a 70cc kit, considering the full race ones only use a 19mm normally.
DM
PostPosted: 19:20 - 31 Dec 2004    Post subject: Reply with quote
A 17.5 mm would be horrible with a 70cc kit. That's a Gilera Runner 50's stock carb size and definitely too small for a kit. I'd go for at least a 19mm, preferably a 21mm. Heck, my friend's brother has a 28mm with his 70cc kit on a Motorhispania RX-50, recommended by the manufacturer (though I admit that's gotta be a special case).
binge
Emo Kiddy
PostPosted: 19:45 - 31 Dec 2004    Post subject: Reply with quote
Mine has got a 21mm carb on Confused
Was on there when I bought it.
<|Binge|>
ts50x0
PostPosted: 19:50 - 31 Dec 2004    Post subject: Reply with quote
considering the whole idea of more cc's is to burn more fuel/air then it will make a hell of a difference.
Dam_buster
PostPosted: 13:22 - 01 Jan 2005    Post subject: Reply with quote
off to shops with cash...
"hello id like to buy a 19mm carburettor please.....
divuk83
PostPosted: 14:12 - 01 Jan 2005    Post subject: Reply with quote
You already have one don't you?
Dave
Dam_buster
PostPosted: 15:27 - 01 Jan 2005    Post subject: Reply with quote
how do u mean ,,,, i have an upjetted carburettor, which the garage did
JIM
Dom_
Points Mean Prizes
PostPosted: 16:05 - 01 Jan 2005    Post subject: Reply with quote
Personally i would get a 21mm carb, that's what most people with big-bore kits seem to go for.
divuk83
PostPosted: 17:30 - 01 Jan 2005    Post subject: Reply with quote
Dam_buster: Your profile says you have a 19mm carb.
Dave
binge
Emo Kiddy
PostPosted: 21:13 - 01 Jan 2005    Post subject: Reply with quote
Hahaaaa! BUSTED!
Lying about your set up Jim? Wink
<|Binge|>
(Yeh, my speedfight has a Nexus 500cc V-twin Lump in it Laughing )
K!K @
PostPosted: 23:29 - 01 Jan 2005    Post subject: Reply with quote
What tends to happen if you dont have the right size carb it the power dilivery isnt there as quick as it should be.
So you dont need 1 but its better if you do.
Good Luck with it Thumbs Up
Suzuki AY50 Katana
~Elite~Knights~
graeme
PostPosted: 01:27 - 02 Jan 2005    Post subject: Reply with quote
i have got a malossi 70cc big bore kit on my speedfight an it is alot better if you get a bigger carb, i am running a malossi carb, 21mm i think
The last post was made 21 years, 261 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 2 - MySQL Queries: 13 - Page Size: 86.24 Kb
