| BenchWench |
 BenchWench Nitrous Nuisance
| mudcow007 |
 mudcow007 World Chat Champion
| Clutchy |
 Clutchy World Chat Champion
 Posted: 16:58 - 07 Feb 2014 Post subject: |
I just stick to chain lube, works fine. ____________________ Malaguti F12 Phantom-Dead, Suzuki AY50- Dead, NRG power DD LQ, CBR125.
Guide to pass your test with no lessons! |
| Skudd |
 Skudd Super Spammer
| wr6133 |
 wr6133 World Chat Champion
| WD Forte |
 WD Forte World Chat Champion
| lorus |
 lorus Two Stroke Sniffer
| Pete. |
 Pete. Super Spammer
 Posted: 20:25 - 07 Feb 2014 Post subject: |
I don't like that wax at all. Lube all the way for me  ____________________ a.k.a 'Geri'
| -Matt- |
 -Matt- World Chat Champion
 Posted: 20:41 - 07 Feb 2014 Post subject: |
I've been using dry wax [wurth] the last year as I got fed up of chain flick going everywhere.
It seems okay to be honest, although its quite temperamental with its application. If you get your chain dry and nicely warmed up with a quick run after cleaning it will apply well. Spraying it on when the chains cold though seems to just lead to it accumulating in a thick layer on the outside and not really penetrating anything, then subsequently most of it gets flicked off on your next ride.
I'm planning to get a new chain soon and to be honest may just revert to oil again, perhaps a scotoiler or similar to aid my lazyness  |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 08:01 - 08 Feb 2014 Post subject: |
Lube is abbreviation of lubricant; hence we should presume it gets to and lubricated the moving bits of a chain, if it says 'lube' on the can.
General lubricants are either liquid oil, or more solid, grease.
Liquid oil has a habbit of being flung off the chain and making a mess; more solid grease, unless you 'hot-dip', melt the grease in a tin to get it liquid then dip the chain in it to get it to flow into all the crannies, tends not to get into those crannies.
Modern chain-lube in a can, tends to contain a heavy semi greasy oil, in a solvent, so you spray it onto the chain as a liquid, that flows into the crannies; solvent evaporates, leaves more greasy lubricant that's less likely to be flung off, and more likely to be where needed to do its thing.
EXCEPT... modern seal-ring, O-Ring or X-Ring chains..... have a SEAL, which, if its doing its job, shouldn't let bugger all get into them 'crannies' that need most lube..... them should have been packed with grease at the factory, and the rings should be keeping the factory packed grease where it oughta.
Which means, that anything you chuck at a ring-seal chain, is going to be doing little more than cover the outside of the rollers that bear on the sprocket teeth, which may, save them a little wear, or may, if it lets grit stick better to the surfaces, help them wear out faster... other wise, just coating the metal and stopping it going red rusty...
So at a guess, 'Wax' is merely Marketing men for the GQ-Generation, realising that 'Grease' evokes images of John Travolta In skin tight jeans and a quiff; Lay-By bacon Butties and three day old congealed curry.... 'Oil' evokes images of traditionally clad Arabs, rubbing thier hands with glee and putting prices up at petrol stations, and 'lube' just sets of all our homophobit paranoias.
'Wax' on the other hand evokes images of nubile women in skimpy bikini's, and is there-fore so much more saleable to Blokes, and probably puts 30% on the price of the can, while in no way implying that the stuff WILL actually do anything useful as far as providing 'lubrication' for your motorcycle; keeping the 'styling Wax' GQ Lawyers happy, when some-one complains that it dont do nowt to 'lube' thier chain....... ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Fizzer Thou |
| Copycat73 |
 Copycat73 World Chat Champion
| temeluchus |
| BenchWench |
| Teflon-Mike |
 Teflon-Mike tl;dr
| MarJay |
 MarJay But it's British!
The last post was made 12 years, 52 days ago. Instead of replying here, would creating a new thread be more useful? |
