Fuel hose rotted through after 5 months
Nipedley
PostPosted: 10:39 - 11 Feb 2014    Post subject: Fuel hose rotted through after 5 months Reply with quote
Hi guys,
I fitted replacement fuel hose about 5, 5 and a half months ago. It was the 'Cotton overbraid nitrile rubber fuel hose' type that seems to be plastered all over eBay and Amazon
Came out to the bike yesterday morning to a strong smell of petrol, as soon as I moved the bike I saw petrol streaming down the side engine cover.
The fuel hose ends have split and the cracks you can see run all the way through the hose, even the end connected at the fuel tap under the clamp which hasn't been moved since it was fitted exhibits the same cracks
Is this a common thing with this type of fuel hose, and is there a different kind I should be fitting? My concern is that on my bike (a GS500) the tank petcock has two outlets that are very close together, a larger reinforced fuel hose wouldn't fit on both the two outlets unless I blanked one off, any idea how I would go about doing that also?
Thanks Smile Glad I noticed this and didn't manage to start a fire. I think 5 months for a fuel hose to last is pretty shocking.
RhynoCZ
PostPosted: 10:51 - 11 Feb 2014    Post subject: Reply with quote
I'm pretty sure you have used wrong hose OR extreme amount of ethanol. Thumbs Up
Go to your local parts dealer and ask for a FUEL line/hose this time.
Nipedley
PostPosted: 10:52 - 11 Feb 2014    Post subject: Reply with quote
Hey there,
I wish that were true but the hose was bought from a 'reputable ebay member', I'm looking at the listing right now, and this same hose is for sale everywhere on ebay - cotton braided fuel hose.
"Application:
Fuel hose Suitable for Unleaded Petrol, Leaded Petrol and Diesel Fuel
NOT FOR BIO FUEL.
Product Description:
POLYESTER OVERBRAIDED FUEL TUBING"
Only used regular fuel, this is only a little GS500, Tesco or Shell's regular unleaded, not the premium stuff
Aff
PostPosted: 10:57 - 11 Feb 2014    Post subject: Reply with quote
Does it state what ISO/BS/DIN standard it is?
If it isn't the most recent then the high ethanol will kill it.
Or its just a cheap copy.
Electric Bike Project
RhynoCZ
PostPosted: 10:58 - 11 Feb 2014    Post subject: Reply with quote
I use these https://www.garance-slavicin.cz/fotky11666/fotos/_vyr_656P5250291.jpg Never had a problem. I can guarantee it worked 3 years in the GPz I had, 2 years in the NC27 and now I've got the same line in the ZXR. Just look at the picture and get the same hose. Thumbs Up
Nipedley
PostPosted: 11:01 - 11 Feb 2014    Post subject: Reply with quote
It says "Type B DIN 73379", is there a high ethanol content in regular unleaded fuel? Just this one listing for the size I need (7mm) has 1,200 sold on eBay, I'm wondering if I got a bad one or there will be a lot of rotted fuel pipes in the next year.
That fuel hose you linked the image of looks pretty sturdy, only thing is I don't think it'd fit onto both of my tank petcock outlets, any tips on how to blank one of the outlets off?
RhynoCZ
PostPosted: 11:05 - 11 Feb 2014    Post subject: Reply with quote
Well it shouldn't be, are you sure you did not get E85 in it? N95 (normal fuel) = 10% of ethanol + 90% of petrol, E85 (I love dolphins fuel) = 85% of ethanol + 15% of petrol.
One outlet is fuel and the other vacuum hose (no petrol there). Me and my friend used these on various bikes with not problem.
By the way that ''premium stuff'' from shell is clean petrol with no ethanol in it. Thumbs Up
EDIT: The hoses in the link are standard fuel lines, 110% sure it won't leak, even after years. It is stupposed to be ''thick''.
wilz1234
PostPosted: 11:11 - 11 Feb 2014    Post subject: Reply with quote
Does anywhere in the uk sell E85? Thought the max in standard pumps was around 10% ethanol.
RS50 - ZXR400 - ZXR 400 - ZX7R - Bandit 600 - NTV 650
Nipedley
PostPosted: 11:13 - 11 Feb 2014    Post subject: Reply with quote
Hey there,
Not unless Tesco/Shell Regular Unleaded is E85, as that's literally the only places I've filled up in the last 5 or 6 months.
My bike is a GS500 and there is a tank petcock with the regular and reserve outlets on it which both run to a fuel tap which then has the vacuum line, the normal and reserve outlets are very close so thick fuel line doesn't fit onto both the outlets together as there's no clearance between them left. The braided fuel hose (the one in question) was a serious struggle to fit on and the listing says the OD is 12mm, I found a hose that looked similar to the one you linked which says the OD was 13mm, so no way it'd fit onto both outlets unfortunately unless I blanked one off
I'm happy to do that (If you don't fill up through reserve you're screwed anyway) but not sure how to go about it
doggone
PostPosted: 11:14 - 11 Feb 2014    Post subject: Reply with quote
It is a bit concerning if increased ethanol is doing nasty things to fuel lines up and down the land.
At least on bikes you usually see or smell something before you would in a car.
It reminded me of a landrover we had where the fuel pipes mysteriously rotted away at less than a year old - there is some rubbish out there.
RhynoCZ
PostPosted: 11:19 - 11 Feb 2014    Post subject: Reply with quote
You can get E85, Natural 95, 100+ octane fuel and Super 98 here in CZE. The E85 is EU thing so I assumed the whole EU provides the E85.
mentalboy
PostPosted: 11:20 - 11 Feb 2014    Post subject: Reply with quote
That's what I've always used BUT two weeks ago had same problem as OP, bizarrely enough every hose from the tank as far as the fuel pump had perished in the same manner as OP described. All hoses between pump and carbs had no sign of perishing despite being the same type of rubber.
My supplier said it was an ever increasing problem due to Ethanol addition to petrol and supplied me with a hose that looked like it was some kind of plastic (sorry, I don't know what it's called)
Make mine a Corona.
YBR Ric
PostPosted: 14:32 - 11 Feb 2014    Post subject: Reply with quote
NOT FOR BIO FUEL.
BIO FUEL = Ethanol
The ethanol in the fuel is the cause of the problem.
Unfortunately a lot of older motorcycles are going to start suffering intake/carb problems as O rings etc. start to shrink, swell or just simply melt away as the content is increased. Hopefully the more expensive bits (throttle slide diaphragms) will be immune.
Nipedley
PostPosted: 14:36 - 11 Feb 2014    Post subject: Reply with quote
Sounds like they should be marked 'not for road use' then if regular fuel has ethanol in :S The amount they've sold is worrying if they are all going to do this.
Literally two days before I noticed my starter motor cover bolts had come loose, if I hadn't fixed that, and hadn't noticed the fuel streaming down that side of the engine, well it's best not to think about.
I'm going to stop in my local Suzuki dealership/garage later and see what they have available
Nipedley
PostPosted: 16:13 - 11 Feb 2014    Post subject: Reply with quote
I've found some decent looking fuel hose online but the outside diameter is way too big for me to fit two of them together on my GS500 (normal & reserve outlets)
Does anyone have any tips on how to blank off one of the tank's outlet's? I am removing the tank petcock anyway to give the tank a clean
https://store03.prostores.com/peakmoto/media/10/a2079171319c5ba5f646ab_m.JPG
jeddy11
PostPosted: 16:26 - 11 Feb 2014    Post subject: Reply with quote
Temperatures can affect rubber fuel lines but i can't see our temperatures causing that as a bove ethonol or alchohols will cause that..
Fuelly My Z1000SX
cbt 06/08/11 mod1 (second go) 01/08/12 mod2 21/09/12
Varadero Viking YBR125>Varadero125>ER6F>Z1000SX !!!
lihp
PostPosted: 17:27 - 11 Feb 2014    Post subject: Reply with quote
Wow, all these scare mongering rumours with regards to ethanol are pretty inaccurate.
Unleaded pump fuel is only allowed to be up to 5% ethanol (E5) without being labelled, they're looking to bring in E10 to the UK, so 10% Ethanol, but it's still pretty uncommon.
Regardless, if the pump does not have the E# on it, then it is 5% or less Ethanol.
Still, despite this, people seem quick to blame ethanol for any fuel related issues, the fact that you replaced this hose and it has failed, and the fact that it is the ends that have failed, if this has been corroded then there will be evidence of this throughout the complete line.
My guess is that if the ends of your hose have split, they have been cut poorly, probably with pliers, or side cutters, or something blunt that has squashed the hose while cutting, causing small fractures, that over time have failed.
Use a proper hose/tube cutter, or a very sharp blade to do it without squashing the hose.
Sorry, but this is most likely installation error than OMGZ EU DESTROYED MY BIKEZZZZZZZZ issue.
Nipedley
PostPosted: 17:32 - 11 Feb 2014    Post subject: Reply with quote
Sorry but I said in my first posts that the cracks were evident throughout the whole fuel line. I cut the lines with a sharp blade, slicing through them cleanly and not squashing.
Just picked up some OEM hose from the local Suzuki dealer, hopefully sort this out for good. I'm going to buy some SAE J30 R9 hose for my other bike as I also replaced that one's hose with one from the same seller of the same type as this one that failed on me
lihp
PostPosted: 17:45 - 11 Feb 2014    Post subject: Reply with quote
My apologies, I skim read the posts and didn't look at the photos.
It looks like a poor quality hose/poorly stored too, rather than ethanol being at play.
Nipedley
PostPosted: 18:05 - 11 Feb 2014    Post subject: Reply with quote
It sounds like this hose is just cheap tat, I emailed the supplier (again, the supposedly reputable British company) and all they were interested in was whether I was going to buy a better hose from them to replace it, so they won't be getting my business again
Aff
PostPosted: 18:46 - 11 Feb 2014    Post subject: Reply with quote
I'm not sure what the "Type B" means, but I'm pretty sure that DIN 73379 is equivalent to SAE J30R9 which I think is tested upto 50% Ethanol.
So if it actually is DIN 73379, and not a copy, it should have been fine. Could well have been a bad batch, but iI think most likely a cheap Chinese copy..
mentalboy
PostPosted: 22:15 - 11 Feb 2014    Post subject: Reply with quote
Too right, I wouldn't trust a word those lying toerags at the DFT have to say (especially when they've lifted the data from the Australians who, as we all know, will be affected to the same extent by the hygroscopic properties of Ethanol in their oft flood stricken country!!!)
'All the carburettored cars in the study were judged to contain materials that had doubtful material compatibility with E5. Of particular concern was tarnishing and corrosion of carburettor components manufactured from brass and used to meter fuel'
Make mine a Corona.
PostPosted: 00:47 - 12 Feb 2014    Post subject: Reply with quote
The solution is silicone hose. It wont melt either.
The last post was made 12 years, 58 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 123.27 Kb
