| Nipedley |
 Nipedley Scooby Slapper
 Posted: 10:39 - 11 Feb 2014 Post subject: Fuel hose rotted through after 5 months |
Hi guys,
I fitted replacement fuel hose about 5, 5 and a half months ago. It was the 'Cotton overbraid nitrile rubber fuel hose' type that seems to be plastered all over eBay and Amazon
Came out to the bike yesterday morning to a strong smell of petrol, as soon as I moved the bike I saw petrol streaming down the side engine cover.
The fuel hose ends have split and the cracks you can see run all the way through the hose, even the end connected at the fuel tap under the clamp which hasn't been moved since it was fitted exhibits the same cracks
Is this a common thing with this type of fuel hose, and is there a different kind I should be fitting? My concern is that on my bike (a GS500) the tank petcock has two outlets that are very close together, a larger reinforced fuel hose wouldn't fit on both the two outlets unless I blanked one off, any idea how I would go about doing that also?
Thanks Glad I noticed this and didn't manage to start a fire. I think 5 months for a fuel hose to last is pretty shocking. |
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 10:51 - 11 Feb 2014 Post subject: |
I'm pretty sure you have used wrong hose OR extreme amount of ethanol.
Go to your local parts dealer and ask for a FUEL line/hose this time. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
| Nipedley |
| Aff |
 Aff World Chat Champion
 Posted: 10:57 - 11 Feb 2014 Post subject: |
Does it state what ISO/BS/DIN standard it is?
If it isn't the most recent then the high ethanol will kill it.
Or its just a cheap copy. ____________________ Current Bikes:Honda 929RR Fireblade, Honda CD200 Benly (Project), Stomp Z2 140
Electric Bike Project
| RhynoCZ |
 Posted: 10:58 - 11 Feb 2014 Post subject: |
I use these https://www.garance-slavicin.cz/fotky11666/fotos/_vyr_656P5250291.jpg Never had a problem. I can guarantee it worked 3 years in the GPz I had, 2 years in the NC27 and now I've got the same line in the ZXR. Just look at the picture and get the same hose.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| Nipedley |
| RhynoCZ |
 Posted: 11:05 - 11 Feb 2014 Post subject: |
| Nipedley wrote: | It says "Type B DIN 73379", is there a high ethanol content in regular unleaded fuel? Just this one listing for the size I need (7mm) has 1,200 sold on eBay, I'm wondering if I got a bad one or there will be a lot of rotted fuel pipes in the next year.
That fuel hose you linked the image of looks pretty sturdy, only thing is I don't think it'd fit onto both of my tank petcock outlets, any tips on how to blank one of the outlets off? |
Well it shouldn't be, are you sure you did not get E85 in it? N95 (normal fuel) = 10% of ethanol + 90% of petrol, E85 (I love dolphins fuel) = 85% of ethanol + 15% of petrol.
One outlet is fuel and the other vacuum hose (no petrol there). Me and my friend used these on various bikes with not problem.
By the way that ''premium stuff'' from shell is clean petrol with no ethanol in it.
EDIT: The hoses in the link are standard fuel lines, 110% sure it won't leak, even after years. It is stupposed to be ''thick''. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| wilz1234 |
 wilz1234 Trackday Trickster
| Nipedley |
| doggone |
 doggone World Chat Champion
| RhynoCZ |
| mentalboy |
 mentalboy World Chat Champion
 Posted: 11:20 - 11 Feb 2014 Post subject: |
That's what I've always used BUT two weeks ago had same problem as OP, bizarrely enough every hose from the tank as far as the fuel pump had perished in the same manner as OP described. All hoses between pump and carbs had no sign of perishing despite being the same type of rubber.
My supplier said it was an ever increasing problem due to Ethanol addition to petrol and supplied me with a hose that looked like it was some kind of plastic (sorry, I don't know what it's called) ____________________ Make mine a Corona. |
| YBR Ric |
 YBR Ric Spanner Monkey
| Nipedley |
| Nipedley |
 Posted: 16:13 - 11 Feb 2014 Post subject: |
I've found some decent looking fuel hose online but the outside diameter is way too big for me to fit two of them together on my GS500 (normal & reserve outlets)
Does anyone have any tips on how to blank off one of the tank's outlet's? I am removing the tank petcock anyway to give the tank a clean
https://store03.prostores.com/peakmoto/media/10/a2079171319c5ba5f646ab_m.JPG |
| jeddy11 |
 jeddy11 Traffic Copper
 Posted: 16:26 - 11 Feb 2014 Post subject: |
Temperatures can affect rubber fuel lines but i can't see our temperatures causing that as a bove ethonol or alchohols will cause that.. ____________________ Fuelly My Z1000SX
cbt 06/08/11 mod1 (second go) 01/08/12 mod2 21/09/12
Varadero Viking YBR125>Varadero125>ER6F>Z1000SX !!! |
| lihp |
 lihp World Chat Champion
 Posted: 17:27 - 11 Feb 2014 Post subject: |
Wow, all these scare mongering rumours with regards to ethanol are pretty inaccurate.
Unleaded pump fuel is only allowed to be up to 5% ethanol (E5) without being labelled, they're looking to bring in E10 to the UK, so 10% Ethanol, but it's still pretty uncommon.
Regardless, if the pump does not have the E# on it, then it is 5% or less Ethanol.
Still, despite this, people seem quick to blame ethanol for any fuel related issues, the fact that you replaced this hose and it has failed, and the fact that it is the ends that have failed, if this has been corroded then there will be evidence of this throughout the complete line.
My guess is that if the ends of your hose have split, they have been cut poorly, probably with pliers, or side cutters, or something blunt that has squashed the hose while cutting, causing small fractures, that over time have failed.
Use a proper hose/tube cutter, or a very sharp blade to do it without squashing the hose.
Sorry, but this is most likely installation error than OMGZ EU DESTROYED MY BIKEZZZZZZZZ issue. ____________________ covent.gardens: lihp is my most favourite member ever |
| Nipedley |
| lihp |
| Nipedley |
| Aff |
| mentalboy |
| stinkwheel |
The last post was made 12 years, 56 days ago. Instead of replying here, would creating a new thread be more useful? |
