Moped not starting
Bike Chat Forums Index -> Biking News & Rumours
Boza53
PostPosted: 20:29 - 12 Feb 2014    Post subject: Moped not starting Reply with quote
I have a Peugeot jetforce 50cc and when you put the key in and turn it on nothing is happening. A light comes up but is very faint which is the diagnostic light. I've charge the battery up and it is now fully charged but still nothing is happening. When you connect the wires to the battery one of them is making a noise and the other one isn't where as before when the bike was running both of them made a different noise. Any one have any suggestions?
Hborrow
panrider_uk
PostPosted: 20:45 - 12 Feb 2014    Post subject: Reply with quote
Is it completely dead? Do any of the lights/horn work?
Have you checked the fuse?
If you ask this in the Workshop section you'll probably get more replies.
Mark
Boza53
PostPosted: 21:03 - 12 Feb 2014    Post subject: Reply with quote
Well when I first tried turning it on all the lights on the speedo came on then they went off, and now when you try start it all that happens is the injection diagnostic light comes on slightly it's not coming on very bright.
Hborrow
symonh2000
PostPosted: 15:42 - 13 Feb 2014    Post subject: Reply with quote
Sounds like your battery is shagged.
Four strokes is two strokes too many.
Boza53
PostPosted: 20:47 - 13 Feb 2014    Post subject: Reply with quote
Do you recon it is the battery? Nothing serious just need a new one?
Hborrow
symonh2000
PostPosted: 21:48 - 13 Feb 2014    Post subject: Reply with quote
Either that or you have a very poor earth somewhere, possibly from the battery to the frame.
How old is the battery?
Also does the bike have a kickstart?
Boza53
PostPosted: 21:55 - 13 Feb 2014    Post subject: Reply with quote
There is no kick start, not sure how old the batty is. I charges it up and checked the acid levels but still nothing happening apart from the diagnostic light coming on?
Hborrow
symonh2000
PostPosted: 23:19 - 13 Feb 2014    Post subject: Reply with quote
For what they cost I would be looking at changing the battery, as IMO that is number one suspect.
It could be that it appears to be charging ok, but as soon as power is required from it it just cannot produce any.
Andy_Pagin
PostPosted: 11:50 - 14 Feb 2014    Post subject: Reply with quote
What voltage is the battery giving out?
Boza53
PostPosted: 18:40 - 14 Feb 2014    Post subject: Reply with quote
It's a 12volt, but I don't kow how much it is giving out
Hborrow
andyscooter
PostPosted: 10:43 - 15 Feb 2014    Post subject: Reply with quote
how do you know its charged then ?
may only be charging to 8 volts if its knackered
also what charger are you using
not a car one as they will fry the battery anyway as they charge too quick and put too high an ampage in
Boza53
PostPosted: 12:22 - 15 Feb 2014    Post subject: Reply with quote
It's a motorbike charger, it came up with the green light meaning it's charged. How would I know it's only giving out low volts
Hborrow
panrider_uk
PostPosted: 16:11 - 15 Feb 2014    Post subject: Reply with quote
Assuming you've not got a multimeter do you have a 12V bulb (car or one from the bike).
Connect a wire from each terminal of the battery to the terminals on the bulb and see if it glows brightly (and constantly) or is dim or starts bright and then dims.
A good battery will give you a bright light for ages.
Andy_Pagin
PostPosted: 17:24 - 15 Feb 2014    Post subject: Reply with quote
Take the battery to a garage and ask them to check it. Not Halfords obviously. Even your local Ford/Vauxhall etc. dealers will probably check it free, good PR. to a potential future customer.
The last post was made 12 years, 243 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 77.78 Kb
