Caliper piston installation tips please
Yamahardon
PostPosted: 22:27 - 12 Feb 2014    Post subject: Caliper piston installation tips please Reply with quote
Generally thinking,
slightly wet the oil seal with brake fluid and then install,
do the same with the dust seal except with RRG rather than brake fluid,
smear the circumference of the piston in RRG and insert.
Any tips on this?
Thanks
PostPosted: 22:31 - 12 Feb 2014    Post subject: Reply with quote
I've only ever used brake fluid to coat things in prior to reassembly. Not saying that's best practice but not had any problems so far.
Just make sure the piston goes in square, a bit at a time.
Islander
PostPosted: 23:31 - 12 Feb 2014    Post subject: Reply with quote
I use red rubber grease for both seals and the piston - it won't hurt brake fluid.
Make sure you clean out the grooves that the seals seat in before you refit them. Any oxide here may cause problems refitting the piston. Insert the piston squarely and it should go in with thumb pressure. Thumbs Up
delsol
PostPosted: 23:44 - 12 Feb 2014    Post subject: Reply with quote
Very much this, and, unless the pistons are perfect, a few minutes on each piston using Autosol makes a difference such that you can see it was needed.
The last post was made 12 years, 245 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 39.46 Kb
