Chain calculations
 Topic moved: from Random Banter to Dear Auntie BCF... by G (15 Feb 2014 - 20:39)
Nick 50
PostPosted: 18:27 - 15 Feb 2014    Post subject: Chain calculations Reply with quote
As part of a project at uni, we had to design a drive system to transmit from a Yasa400 for a formula student car.
Our lecturer allowed us to use gears, belt or chain, though he only guided through the gear choice. I decided to go down the chain and sprocket route.
Never having done something like this before, much googling was needed.
I came across:
https://chain-guide.com/
https://www.hpcgears.com/
But I used the very good:
https://www.iwis.de/uploads/tx_sbdownloader/KettenHandbuch_E.pdf
My parameters were to transmit 220Nm Torque, 150hp, with a speed of 1600rpm.
Like hell could I find a chain strong enough with the calculations involved.
So my question, is there a differing way of doing the calculations? MotoGP bikes use 1 chain and cope fine, but all the guides I used were coming out with that I had to use a triplex chain and have 3 rows of them to cope Confused
Anyone have any insight into chain calculations?
PostPosted: 18:48 - 15 Feb 2014    Post subject: Reply with quote
A 530 DiD VM grade x-ring chain such as one would find on a sportsbike has a tensile strength of 43.1 KN.
A 530 single pitch roller chain such as one would find running a coveyor belt has a tensile strength of 29.7KN.
Are your charts using the right sort of chain? Motorcycle final drive chain is NOT the same as industrial drive chain.
PostPosted: 18:57 - 15 Feb 2014    Post subject: Reply with quote
220Nm is a lot of torque, but at very low rpm. You will need very high gearing to get that to give you a reasonable top speed (assuming your tyres aren't from a tractor). If you were running a gearbox before the final drive then the torque at the chain will be a fraction of the figure you quote.
Nick 50
PostPosted: 19:28 - 15 Feb 2014    Post subject: Reply with quote
That was my thinking, but I can't find any charts for motorcycle standard chains. So it was very hard to prove that a chain would work.
I ended up selecting an AFAM 520RXX-GG chain.
To be honest I opted to turn the Torque down as it can push out 400Nm. I opted for a 3:1 ratio to the axle (all theoretical).
The load case was for a 75m acceleration run so not needing a big top end speed.
PostPosted: 19:33 - 15 Feb 2014    Post subject: Reply with quote
https://www.didchain.com/images/usaspecs2010b.jpg
https://www.oppracing.com/images/cmsuploads/Large_Images/ek%20chain%20comparison%20specifications%20from%20oppracing.jpg
PostPosted: 19:58 - 15 Feb 2014    Post subject: Re: Chain calculations Reply with quote
Have a look at what existing rear/mid bike engined kit car use - generally they'll use a chain drive. They can easily handle the sort of specs you mention.
PostPosted: 20:04 - 15 Feb 2014    Post subject: Reply with quote
DID chain specs (for some chains) are here:-
https://www.didchain.com/chainSpecs.html
As an aside, your 220Nm is just under double that of my 1200 Bandit but at about 1/5 of the rpm. So assuming the same size wheel and 1:3 gearing on the final drive sprockets, to do 53mph you would need about 5 times higher gearing compared to the Bandit in 1st gear (stock gearing puts peak torque at 53mph), which would give you about 1/3 of the torque on the chain.
swampy
PostPosted: 20:28 - 15 Feb 2014    Post subject: Reply with quote
How come this thread has been pretty much exclusively replied to by mods, but none of them have moved it to 'Dear Aunty BCF' ?
Thinking Tut Tut Wink
Edit: Thats better, but don't make me get all self righteous on your asses again Laughing
The last post was made 12 years, 277 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.37 - MySQL Queries: 16 - Page Size: 62 Kb
