Chain come undone at split link
TaeKwon125
PostPosted: 10:00 - 18 Feb 2014    Post subject: Chain come undone at split link Reply with quote
Hey,
I was riding home last night and my chain came undone.
On inspection it has come apart at the split link. What usually causes this? I lubricated the chain and checked the tension about 2 months ago, the chain and sprockets were new less than a year ago.
I am currently intending to inspect the chain and sprockets and if there is no damage then refit the split link and use again. Unless there is a reason that I should not.
The bike is a 200 cg125 W.
Thanks very much, Olli
anthony_r6
PostPosted: 10:16 - 18 Feb 2014    Post subject: Reply with quote
I had one come off my NSR, though the chain stayed on. I would rather add a riveted link to make sure it's not gonna come off in that manner again.
Was it possibly put on the wrong way? I'd probably order a new one if you're going to use the split link again.
Islander
PostPosted: 10:55 - 18 Feb 2014    Post subject: Reply with quote
If the chain and sprockets are in good condition then fit a new split link and make sure that the closed end points in the direction of chain travel.
TaeKwon125
PostPosted: 11:08 - 18 Feb 2014    Post subject: Reply with quote
Thanks for the replies, looks like the consensus is that the split link may have been on the wrong way.
If the chain and sprockets are in good nick still I will fit a new split link the right way around and take it easy for the first few miles.
Thanks very much.
PostPosted: 11:45 - 18 Feb 2014    Post subject: Re: Chain come undone at split link Reply with quote
Er? Laughing Is this not a weekly, even 2 or 3 day check for you Shocked
TaeKwon125
PostPosted: 11:59 - 18 Feb 2014    Post subject: Reply with quote
Nope, I ride about 20-40 miles a week. Should it still be?
PostPosted: 12:33 - 18 Feb 2014    Post subject: Reply with quote
I check mine weekly at the longest. Shocked
PostPosted: 12:37 - 18 Feb 2014    Post subject: Reply with quote
If it was put on the wrong way round a year ago, it would have come off by now.
It came off because it's a splitlink and they do that. People on here are very quick to blame the user. Yes you should have checked your chain more frequently but in my experience, splitliks are prone to failure. They are a definate weak point and any chain will always fail at the weakest link.
I've had several splitlinks either come off or fail altogether over the years and they most certainly were put on correctly (Unless anyone is suggesting that having had two fail, I didn't make absolutely certain the third and fourth ones were fitted and seated correctly).
The last one failed after less than 1,000 miles and within a week of fitting it on my KLE500. I simply refuse to use them now.
PostPosted: 13:59 - 18 Feb 2014    Post subject: Reply with quote
Some people lock wire split links for the this reason.
It may be a quality issue - a bottom of the range cheap Chinese chain is presumably much more likely to have issues than a decent brand name one you might see on a drag bike and the like.
Commuter_Tim
PostPosted: 20:56 - 18 Feb 2014    Post subject: Reply with quote
Could you elaborate on what lock wire is for a noob please?
or were you just advocating the use of riveted?
I ride a Bandit 600... badly.
PostPosted: 21:52 - 18 Feb 2014    Post subject: Reply with quote
Lock wire is used to prevent things vibrating off and so on - for instance on race bikes you have to lock wire the sump bolt.
You drill a hole through the head of the bolt, then put the wire through the hole, attach it to another part of the bike and twist the wire to tighten it - this way even if the bolt comes loose, it can't turn more than a quarter turn or so.
You can also use it on a chain split link - generally wrapped around the link I believe.
TaeKwon125
PostPosted: 15:48 - 07 Mar 2014    Post subject: Reply with quote
I got a new split link, fitted it but the chain wasn't running quite right by my eye.
So I subsequently bought a new set of chain and sprockets, fitted them, double checked the orientation of the split link and all appears well. I didn't lock wire the split link as I was a little worried it would rub on the chain guard or the sprockets.
Thanks again for all your help. Thumbs Up
bikenut
PostPosted: 11:34 - 08 Mar 2014    Post subject: link Reply with quote
:D i had a link plate go once, a ticking noise, so stopped and looked at chain, a link plate ( not the split link but an outer link plate ) had broken across tween the pins, just where it was stamped EK530!!
it has broken in line with the k from memory.........will find and post a pic....
the chain had done about 14k miles, with regular tlc and was in adjustment...........good sprockets also.
rode home ( 7 miles ) very slowly with my heart in my mouth all the way......... :karma:
never had an ek chain since, nor will i!
nuts about bikes
The last post was made 12 years, 258 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.11 Sec - Server Load: 0.82 - MySQL Queries: 15 - Page Size: 92.61 Kb
