HDMI Switch confusion
dydey90
PostPosted: 11:47 - 18 Feb 2014    Post subject: HDMI Switch confusion Reply with quote
My setup consists of a PC, under a desk with an old tv used as a monitor, which runs at 720p-ish (1366x768)
I also have a tv at the end of my bed, for watching illegally downloaded films and tv shows, so it runs at 1080p.
At the moment I'm having to manually switch over the cables, which then automatically adjusts the resolution.
This is causing something to wear though, causing picture loss on my desk screen every now and again.
Solution1:
HDMI switch. I need to find a single input, double output HDMI switch with a button, not an auto-switch on it. These are proving illusive.
Solution 2: Stick both of them into my graphics card at the same time and find some way of programming in a resolution change between what I want. I don't want to just extend the desktop because that means about 95% of the time, the 50/50 chance means whatever program I want will open in the wrong screen.
Thoughts? Advice? Experience? Abuse?
lihp
PostPosted: 12:03 - 18 Feb 2014    Post subject: Re: HDMI Switch confusion Reply with quote
dydey90 wrote:
Solution1:
Could use a 2 input 1 output with switch on it, and use it in reverse?
TomReilly
PostPosted: 12:08 - 18 Feb 2014    Post subject: Reply with quote
Use your control center to scale the picture down.
Motorcycle riding can be really cozy. If you want to be a little closer to your passenger, brake a little quicker for the next stop. Wink
dydey90
PostPosted: 12:21 - 18 Feb 2014    Post subject: Reply with quote
I thought of using a switch in reverse, but I don't want to buy one, only to discover it doesn't work. I assume that they label the output simply as the common side of the switch, but I don't know for sure.
I don't want to scale down the resolution, it looks terrible. No point in forking out for a snazzy tv and then watching stuff in 720, right?
The last post was made 12 years, 275 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Geek Zone All times are GMT
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 40.18 Kb
