my rocket broke down while overtaking .
stuartt
PostPosted: 00:16 - 25 Feb 2014    Post subject: my rocket broke down while overtaking . Reply with quote
i went to start my rocket today & it took about 10 attempts to start it .
after i went about 200 meters it stalled & again it took about 5 attempts to start it , sometimes when i pressed the start button not a thing & other times when i press the button it would turn over for a second or two but not start as if the battery was low .
when it did start it seemed ok apart from the engine management light staying on .
the bike was ok for about 6-7 miles till i stopped at a shop then once again it was hard to start , when it did start the engine management light went off & i thought it was back to normal .
after another mile or so i was on a dual carriageway & i thought i'd open it up , i passed 3 cars & it died at 5000 rpm ( clutch in & i got back in to the left lane & luckily there was a slip road i could use )
again got the bike going & it chucked it on a small roundabout .
i phoned the aa & the guy checked some relays & connections but it was much the same running sometimes & missing a bit .
at 1 point the aa guy offered to follow me home till it chucked it again & we both decided to get it picked up , its a bloody heavy bike to handle when it cuts out on a corner .
the bike is 2 years old & had a new ecu & wiring loom fitted by triumph a few months ago .
does anyone have any idea what could be up with the bike ?
thanks
Clutchy
PostPosted: 00:23 - 25 Feb 2014    Post subject: Reply with quote
What manufacturer makes this rocket that you speak of...
stuartt
PostPosted: 00:34 - 25 Feb 2014    Post subject: Reply with quote
its a triumph rocket 111 roadster 2012
PostPosted: 00:45 - 25 Feb 2014    Post subject: Reply with quote
Given the weather conditions recently. I'd go with water in the loom or in the fuel being near the top of the list.
Why was the whole wiring loom and ECU replaced? Smacks of a despairation move by a fitter attempting to track down an electrical fault by replacing bits until it works instead of actually finding the fault. I wonder if it actually fixed the problem?
Shaft
PostPosted: 00:48 - 25 Feb 2014    Post subject: Reply with quote
My instant thought is reg/rec and/or battery showing early signs of imminent total failure.
But why did you have a complete loom and ECU replacement?
That's a pretty drastic fix, is there a chance it could've all gone wrong again?
Clutchy
PostPosted: 00:53 - 25 Feb 2014    Post subject: Reply with quote
Take it back to the dealers Thumbs Up
stuartt
PostPosted: 01:01 - 25 Feb 2014    Post subject: Reply with quote
before the loom was fitted the revs went up & down themselves , the odd backfire at traffic lights , engine cutting out ...
the pins on the ecu were black ( a few of the pins fell off ! ) , the wiring was starting to corrode at the multi point connector . when they were changing the loom the wiring fell apart at the rear abs !
as far as i know theres loads of rockets with bad wiring ( an expensive bike made cheaply )
i don't think its water as it was dry today , although we've had a bit of bad weather i nearly always use my busa as its a much better bike so the rockets not seen much rain .
stuartt
PostPosted: 01:02 - 25 Feb 2014    Post subject: Reply with quote
i can't take it back as it was 2 years old last month .
PostPosted: 01:52 - 25 Feb 2014    Post subject: Reply with quote
My older 675 had an OBD2 connector, so yours might have one.
If it does, either find someone with one or buy a reader - you can get ones that work through bluetooth with free phone software - should give you a good idea of where to start looking.
andyscooter
PostPosted: 08:31 - 25 Feb 2014    Post subject: Reply with quote
the work that was done a few months ago will have a warrenty so take it back
also cant believe that a triumph only has a two year warrenty
my honda comes with three and it was only 2400 quid
Robby
Dirty Old Man
PostPosted: 08:59 - 25 Feb 2014    Post subject: Reply with quote
It's a complex, modern bike which has had some kind of serious electrical problem in the past. You're not going to get an accurate diagnosis on this forum.
The symptoms are concurrent with a failing rec/reg causing the battery to discharge, but it could well be something more complex. You need to at least connect a code reader and see if it can tell you the problem.
Very simple check - plug in a decent charger, if it takes more than half an hour before showing you lots of green lights, the battery is discharged. If it quickly shows you lots of green lights, the battery is good, which means your charging system is good, which means the problem lies in fuelling or ignition.
Monkeypony
PostPosted: 09:31 - 25 Feb 2014    Post subject: Reply with quote
Surely the loom and ECU replacement is covered by warrantee. If this work was done only a few months ago, and your new problem is a related fault, you should still be covered.
Take it back to Triumph.
Current bike - 2018 H2-SX, 2004 SV1000s, 2016 Aprilia RSV4 RF, 2017 Sherco SERF 300, 2003 Suzuki DRZ400 (stolen - AY53 JUU)
stuartt
PostPosted: 09:36 - 25 Feb 2014    Post subject: Reply with quote
thanks for the reply's , i'll pop by triumph this afternoon & see what they've got to say .
bladerunner
PostPosted: 11:08 - 25 Feb 2014    Post subject: Reply with quote
You may well find that they will help even if it's out of warranty given you've had problems already
andys675
PostPosted: 11:18 - 25 Feb 2014    Post subject: Reply with quote
don't assume they won't help
if the dealer is no help call them directly
there is no way they want to upset somebody who has spent a lot of money with them and put you off buying another bike from them in future, besides this you have got an ongoing problem that wasn't sorted when they had it last time
PostPosted: 12:55 - 25 Feb 2014    Post subject: Reply with quote
You mean, like Victory? Thinking
Diagnosis: OP is cursed, should have bought some lucky heather from that gypsy.
Alternatively, riding cruisers through a Scotch winter is not a winning strategy. Sad
andys675
PostPosted: 14:53 - 25 Feb 2014    Post subject: Reply with quote
that guy who owned the victory with all the problems now owns a rocket 3
stuartt
PostPosted: 16:32 - 25 Feb 2014    Post subject: Reply with quote
thats it fixed i think Very Happy
i lifted the tank & disconnected a few multi point connectors & re connected them .
the aa guy said sometimes to much electrical grease on connectors can cause a bad connection .
the dealer that changed the wiring said triumph often don't use enough causing water to get where it shouldn't get to , the dealer used loads of the electrical grease on every multi point connector & relay , i'd say they did a pretty good job of getting all the wiring as water tight as poss .
i bought the bike second hand when it was 9 months old , i don't know if the last owner jet washed it all the time leading to water getting to were it shouldn't get to .
the bikes not done many winter miles as i prefer my busa ( bought the rocket without even sitting on one before ! )
i'm in two minds whether to sell it as i've decided to get a gas gas ec300r before i'm to old for a bike like that Very Happy
PostPosted: 17:37 - 25 Feb 2014    Post subject: Reply with quote
Phew, good news. Thumbs Up
Rocket III to a Gas Gas, that'd be some difference. Very Happy
PostPosted: 17:47 - 25 Feb 2014    Post subject: Reply with quote
You can get an EC300 from about £1k for an older one.
A newer one will feel nicer - but the older one is perfectly fine for starting out.
stuartt
PostPosted: 18:20 - 25 Feb 2014    Post subject: Reply with quote
i'll get a new one , £6600 i think for the racing one .
at least buying new i know it will be perfect & if i look after it it will last for many years .
i've not been off road since 85 when i had a shot of palls 123 montesa Very Happy
PostPosted: 20:35 - 25 Feb 2014    Post subject: Reply with quote
I bet you said the about all the bikes Thumbs Up Victory included Laughing
PostPosted: 21:18 - 25 Feb 2014    Post subject: Reply with quote
They are all 'racing' ones Smile.
If you're getting such a bike to 'look after', don't bother.
Think I crashed my bike about 10 times when I first did off roading. Definitely crashed Korn's bike a few times, including once where I over shot a jump and landed in a nose-first heap, twisting the forks in the yolks (thankfully no permanent damage - loosen and reset.)
When I was riding regularly, I crashed less often generally, but often at higher speed then.
If you end up doing hare and hounds, often expect no more than one minute's warm up.
These bikes do need regular maintenance if you want them, to run properly. So you'll end up with a bike running just as well if you buy secondhand and get someone to go over it.
Personally, I'd say even if you do decide to stay for going new, at least buy a second hand one first to make sure you do enjoy it etc.
You've got pretty much nothing to lose (unless it gets stolen - in which case you're much better off than having a brand new bike nicked anyway.)
stuartt
PostPosted: 22:39 - 25 Feb 2014    Post subject: Reply with quote
my busa is the second new bike i've had & its been faultless & its coming on 5 yr old .
my 1st new bike was a mtx 125 , it got stolen at 40 days old back in 88 so i don't know how it would of ended up !
i should really borrow a off road bike for a few hours to see if i like it i suppose Very Happy
if i do get a new gas gas i don't plan on going mental off road the last thing i need is a broken bone !
anyway i headed out at tea time & my rocket conked out by the time i got to the bottom of my street & once more on the way back to my house !
i'll pop over to the dealers tomorrow & see what they say , either way the rockets going to have be plugged in to a computer to see whats up with it .
PostPosted: 22:57 - 25 Feb 2014    Post subject: Reply with quote
Just had a look at the map - you're welcome to have a play on my KTM, however it's in Kent at the moment, so not ideally placed for you!
No need to break bones, but you do tend to end up crashing.
Only time I've broken anything off roading and first time I'd broken a proper bit of bone (had my nose broken a couple of times) was when I was really tired AND getting faster and faster. Took a double-gap a bit too fast and rarther landing in the middle, plouged in to the far up-slope. Still rode the bike back and was at work for a couple of days before getting it checked out - just a bit of a chip, so still managed to run a training course at the other end of the country a couple of days later!
However, it's not just crashing. By nature stuff is going is going to get thrown up at. 2 stroke pipes tend to be considered consumable. Sure, you can get an expensive guard, but that won't save it from everything and adds weight.
The last post was made 12 years, 268 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.10 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 130.12 Kb
