Would you buy this used engine?
PostPosted: 09:33 - 25 Feb 2014    Post subject: Reply with quote
Second hand two stroke engines are rarely worth it as you need to strip them down and inspect them anyway. By the time you do that you might as well rebuild it, or have rebuilt the original motor.
It does look clean, but it's the crank that you need to worry about. The bores also look like they need a hone, they are far too smooth. {edit} There is also a fair bit of scoring there... definitely compression test it!{edit} If you leave a two stroke engine in a damp garage over the winter, water vapour will get into the bottom end via the transfer ports and exhaust port and causes the roller bearings to rust. This makes the bottom end scrap in very short order, especially when run after being stood for a long time. This is really why a second hand two stroke is such a difficult proposition.
skatefreak
PostPosted: 15:36 - 25 Feb 2014    Post subject: Reply with quote
I recently rebuilt a 125 2stroke NSR engine that was left in a bin bag in a garden for god knows how long...
The bottom end big bearings were pantsed so replaced thoes and seals and got a new crank in there however the gearbox seem's decent.
Threw a piston kit in there as it was apart and happy days!
-Jvr
PostPosted: 18:41 - 25 Feb 2014    Post subject: Reply with quote
Piston has a granular appearance, which could be the samera but looks suspiciously like minor detonation damage. Looks like th episton has been picking up on the bore too. I reckon the cylinder could possibly be serviceable but the piston is most likely an iffy proposition for re-use. At the very least check the rings aren't tight in the grooves - another sure sign of detonation.
Shaft
PostPosted: 19:59 - 25 Feb 2014    Post subject: Reply with quote
I'm not understanding.
Why would you buy an engine with the wrong gearbox for your bike, knowing you will need to totally rebuild it?
You already have an engine that needs rebuilding, all you're doing is spunking money for nothing.
PostPosted: 10:07 - 26 Feb 2014    Post subject: Reply with quote
Turn up, view engine before handing over cash, spend the 30 secs whipping the head off Wink
To be fair, I'd have given up when you asked me to strip the engine, even if its minor parts because I have other things to do rather than drag out an engine that has been sat in the garage for 6 months init. Business is business Laughing
stevo as b4
PostPosted: 12:57 - 26 Feb 2014    Post subject: Reply with quote
Totally agree here with Marjay.
But as you have explained that it's not just bearings, gaskets and seals you need to re-build the old engine, then all you need is a decent gearbox with all the gears in good condition, the selector forks and shafts and particulary the output shaft in good condition.
The top end is irrelevant anyway, as If its a plated bore, you want to be sending off for a re-plate and obviously you will want to have a full professional crank re-build and true done.
It's not what you were asking, but no way would I ever buy a second hand 2stroke lump to throw in and run as it is, due to several reasons not least of all a sat around doing nothing engine is likely to be fucked crank seal wise and that's if moisture has not got into the bottom end and pitted the crank pins etc.
If buying this motor gives you access to a decent head, and all the gearbox components other than bearings to re-build the old motor then go for it.
The head isn't a major issue anyway, as welding and machining can fix the old head at a cost.
PostPosted: 16:10 - 26 Feb 2014    Post subject: Reply with quote
I'm just crying at the price of parts Sad Think Fizzer rebuilt that R1 engine for ~£800. I would cry if my engine was wanged and required £400 to repair Sad
PostPosted: 18:16 - 26 Feb 2014    Post subject: Reply with quote
Your 'contaminated' bearings can be flushed out. I recovered the bearings from my 1952 milling machine spindle and my tool 7 cutter grinder both were notchy with bits of hardened grease. They might be a wee bit loose afterwards but probably no worse then most bike gearbox bearings.
Shaft
PostPosted: 21:42 - 26 Feb 2014    Post subject: Reply with quote
_Iain_ wrote:
What do you think? I'm 50/50 on it.
Well, the first thing I think is, feck me that's a lot of money for some bearings, so I would be doing what Pete says and trying to reclaim them.
Failing that, whip out the Vernier guage and measure them up for replacements from somewhere that doesn't say Honda on the packet.
Then I think this
https://www.ebay.co.uk/itm/HONDA-CR125-CYLINDER-HEAD-KZ4-1996-/400669924487?pt=UK_Motorcycle_Parts&hash=item5d49c9dc87
So now you're just buying gearbox internals and a pile of bits to gather dust in a box somewhere.
You've haven't said how much this new potential doorstop is.
Shaft
PostPosted: 23:32 - 26 Feb 2014    Post subject: Reply with quote
You said a head is £150 and if it's as rare as you say, don't keep an eye on it, hit the fucking BIN button, before somebody else does.
Worst way, you get a part you dont use and can easily get your money back on.
As for this other engine, over 400 quid is a helluva punt; you've just saved £110 on the head and who knows what on the bearings, that just leaves the gearbox bits, which I'm sure could be picked up somewhere.
If it's a well used engine in karting, search the karting forums.
Shaft
PostPosted: 00:34 - 27 Feb 2014    Post subject: Reply with quote
Hit the BIN button in the morning, then stall him til Friday, that's a good head and you know it's for nothing.
Then forget this other engine nonsense; if things are that tight, you need to get creative and rebuild your existing unit.
You're thinking of paying a fair bit of wedge for a motor that's being described as all good, so that means you're paying a premium; what you actually want is an engine that's fubar, with a good gearbox, which will be a lot cheaper.
Quornholio This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
331X2
PostPosted: 03:25 - 27 Feb 2014    Post subject: Reply with quote
+1 what Pete and Shaft said, for the length of time that they were 'contaminated' I'd make sure they were flushed completely free of debris and re-use them.
The last post was made 12 years, 266 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.17 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 157.55 Kb
