Laptop charger needs more meat?
smegballs
PostPosted: 17:50 - 26 Feb 2014    Post subject: Laptop charger needs more meat? Reply with quote
Just got a redonkulously large battery for my netbook 10400mAH (stock is 2200mAH), as expected charging with the stock charger (19V, 1.58A) is taking forever.
If I buy an Acer charger designed for bigger laptops (19V, 3.42A) will the end result be faster charging or is the max charge current limited by circuitry in the laptop?[/u]
Shinigami
PostPosted: 17:59 - 26 Feb 2014    Post subject: Reply with quote
1040mAH is less/smaller than the stock one you stated....
if you made a typo, think of the capacity as a bucket, you've bought a bigger bucket, pouring from the same tap at the same amount will take longer.
smegballs
Right you are Thumbs Up Left off a zero.
Edited.
Shinigami
PostPosted: 18:02 - 26 Feb 2014    Post subject: Reply with quote
also higher amp charger will be fine as long as the voltage is the same, it'll be like opening the tap a bit more so will charge quicker
smegballs
PostPosted: 18:11 - 26 Feb 2014    Post subject: Reply with quote
Yep that's what I thought, as long as the volts are correct, the laptop will just draw what it wants to draw.
sickpup
Old Timer
PostPosted: 18:19 - 26 Feb 2014    Post subject: Reply with quote
Not necessarily.
The motherboard components may not be able to handle the increased charge rate.
Shinigami
PostPosted: 18:50 - 26 Feb 2014    Post subject: Reply with quote
I should probably have added 'within reason' however I'd imagine 3.4 would be fine.
may I just add i'm not an expert and may find it amusing if your machine bursts into flames as that's how I roll
Rolling Eyes
sickpup
Old Timer
PostPosted: 21:27 - 26 Feb 2014    Post subject: Reply with quote
It is after all only 230% more than standard, seems perfectly fine to me.
smegballs
PostPosted: 22:01 - 26 Feb 2014    Post subject: Reply with quote
AFAIK the power supply can't simply force more amps "down the pipe" as it were without increasing the voltage. As the voltage is 19V in both cases, the current is going to be based on the laptop wanting to draw current.
I'd imagine that the charge circuitry of the laptop has overcurrent and thermal-cutout protection on the Li-ion charging board.
Think of a bike battery and a car battery, lighting up a headlight bulb. There are the same voltage yet the car battery is capable of supplying way more amps than the bike battery. Both can be used to power a bulb safely as the current is not dependant on the battery but the resistance of the bulb (the load).
sickpup
Old Timer
PostPosted: 22:13 - 26 Feb 2014    Post subject: Reply with quote
I know how they work but a flat battery will pull all the power it can until the charging circuit falls or goes on fire...
lihp
PostPosted: 22:31 - 26 Feb 2014    Post subject: Reply with quote
Correct, but a battery being charged will draw it
The last post was made 12 years, 203 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 67.21 Kb
