Troubleshooting
Darylw27
PostPosted: 14:44 - 26 Feb 2014    Post subject: Troubleshooting Reply with quote
In the past few hours a new problem has just developed with my bike (2011 ER6n) after overtaking a parked vehicle with a quick blast of acceleration something just went where the sound of the bike suddenly became much more deep and throaty as well as quiet. On the way home it was an absolute fight to get to 70mph on the motorway in 6th gear with the throttle open 100%.
To sum it up, bike feels like a 125. Spluttering and nearly stalling at 15mph in 1st gear. Bike also idles about 2-400rpm less. Could it be a cylinder is away/spark plug?
SQL
PostPosted: 14:47 - 26 Feb 2014    Post subject: Reply with quote
Might have dropped a cylinder, check the spark plug in both pots
sickpup
Old Timer
PostPosted: 20:23 - 26 Feb 2014    Post subject: Reply with quote
More likely the exhaust has snapped just in front of the silencer.
SQL
PostPosted: 20:51 - 26 Feb 2014    Post subject: Reply with quote
Ah possibly would explain the change in noise didn't think that would reduce power to that extent to be honest.
Darylw27
PostPosted: 22:35 - 26 Feb 2014    Post subject: Reply with quote
That's what I though and first checked sickpup that the exhaust had maybe blown, but looks to be in perfect condition, the sound and feel certainly suggests only one cylinder is firing. Getting new plugs on Friday to give them a try. Other than that I'm out of ideas!
sickpup
Old Timer
PostPosted: 22:46 - 26 Feb 2014    Post subject: Reply with quote
How did you check?
Darylw27
PostPosted: 00:16 - 28 Feb 2014    Post subject: Reply with quote
To check the exhaust I shoved a rag in the silencer, no sound of any air blowing. Had also run my hand around the length of the exhaust from the silencer up to the headers and nothing, not the most technical of checks but i'm sure that's a reliable DIY way of checking?
wots
PostPosted: 08:19 - 28 Feb 2014    Post subject: Reply with quote
Coil packs, prone to rusting. Other Kwaks use the same one (can't remember which) so don't pay ER6 premium prices.
Careful when you are taking them out, as if they've started to crumble the metal band around it can split and make it more difficult to pull them out. Suggest rag and something to grip the top with, then twist/pull.
When my exhaust went, it lost a lot of power. In fact I think it's leaking again (botched repair) as it's been running a little rough just recently. However, not bad after a year and I managed to cleanly remove all studs the other day, so I'm exchanging the manifold.
Darylw27
PostPosted: 14:39 - 28 Feb 2014    Post subject: Reply with quote
Had a friend round who's on his last year of his apprenticeship with bikes, double checked the exhaust confirmed its not blowing. Had a look at the coils, one of the left popped out with a bit of twisting and pulling. One on the right however is seized, almost completely, I have acquired two spare coils from a mate to replace it with. Problem now is the fact I'm unable to get the right one off... popped a rag over it and used vice grip pliers and the plastic is tearing off before the coil even budges. Totally lost at how I can remove this, used about half a can of WD40 in the hopes it would find its way down to no avail. Any ideas now? Seems likely the coil has packed it in given how corroded it must be.
wots
PostPosted: 14:42 - 28 Feb 2014    Post subject: Reply with quote
Same problem with mine, although mine hadn't actually gone, it wouldn't have been long. They were wedged in hard.
I just put a rag on and used some pipe grips, and made sure I was grabbing as much of the thing as possible. Twisting is more important than pulling until it starts to move.
Be very careful though.
PostPosted: 18:01 - 28 Feb 2014    Post subject: Reply with quote
Vincent wrote:
Are you sure you're not talking about exhaust baffles? Coils are electronic components usually attached to the frame under the fuel tank Wink
They have those dumbass plug-cap mounted ignition coils and appear to have carried over the design flaw from the EX500 engines where they have a very deep plug recess drained by a tiny little hole which can fill up with water and corrode the shit out of everything.
@ Darylw27 It might be simpler to drain down the coolant and remove the entire rocker cover then tackle them on a bench from both sides.
Darylw27
PostPosted: 21:45 - 04 Mar 2014    Post subject: Reply with quote
Just a little update, turns out it was indeed the coil. The rubber had split and the whole thing was a corroded mess, so much so I had to take it to a friends bike garage to remove it for me since the whole plastic snapped off the plug part in my efforts to twist it.
Thanks for the help and suggestions everyone! Thumbs Up
The last post was made 12 years, 260 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 82.16 Kb
