Picked up one of these.
nerald
PostPosted: 22:41 - 28 Feb 2014    Post subject: Picked up one of these. Reply with quote
Eastern Bloc exotica. Jawa 210. It fits perfectly in the back of my Bongo so roll on summer for moped mayem Embarassed
V-Twins - 60 or 90?
PostPosted: 22:47 - 28 Feb 2014    Post subject: Reply with quote
Two things to watch out for:
1) They coke up really badly. If you are finding it (even more) down on power than usual, give the baffles a clean.
2) If you experience a sudden loss of power after a longish run but it is still running, stop in case it's heat seizing. If it's still doing it after a cool down (ie running but badly), check the points. They sometimes weld themselves together after a long run, you can usually ping them apart with a screwdriver. There is no way the engine should run like that but they do.
bladerunner
PostPosted: 00:37 - 01 Mar 2014    Post subject: Reply with quote
The header pipe looks like it could coke up pretty easy to! That said....it actually looks pretty modern for a jawa Wink
PostPosted: 01:21 - 01 Mar 2014    Post subject: Reply with quote
I think it has a lot in common with a Tomos.
The header is too hot to coke up. There is a drilled tubular baffle in the exhaust (if it's like others I've seen) that gets easily blocked. You actually get big lumps of carbon like small stones forming in there after a while.
nerald
PostPosted: 07:51 - 01 Mar 2014    Post subject: Reply with quote
Will keep an eye out for the carbon build up. The pipe is pretty oily at the moment it looks like the premix has been a bit strong. It has only covered about 300 mile so hopefully won't be too coked up. I remember having to remove the baffles and use a blow torch to decoke them from an old RZ250 I had years ago with any luck it won't get to that.
V-Twins - 60 or 90?
twostroketit
PostPosted: 22:06 - 01 Mar 2014    Post subject: Reply with quote
Agh! i had one of those as my very first bike, many years ago. I hated it! top speed was 25 miles an hour.
After a few weeks it blew up because i put the wrong ratio of Petroil in it.
I then went back to cycling 9 miles to work every morning and didn't miss it. Very Happy
sup up your beer and collect your fags
RhynoCZ
PostPosted: 23:07 - 01 Mar 2014    Post subject: Reply with quote
Is it the two speed version? Thinking
nerald
PostPosted: 20:23 - 02 Mar 2014    Post subject: Reply with quote
Single speed by all accounts. Its even got a label on it saying "Maximum Speed 25MPH"
V-Twins - 60 or 90?
RhynoCZ
PostPosted: 20:28 - 02 Mar 2014    Post subject: Reply with quote
Do you have to register it, in order to use it on the public road?
Aff
PostPosted: 20:32 - 02 Mar 2014    Post subject: Reply with quote
AFAIK anything over 200W has to be. (250W for a trike)
Electric Bike Project
PostPosted: 00:49 - 03 Mar 2014    Post subject: Reply with quote
That means it is exempt from quite a few rules.
For example, I believe the legal minimum tread depth for such a machine is "visible tread".
RhynoCZ
PostPosted: 09:13 - 03 Mar 2014    Post subject: Reply with quote
Here, you do not register mopeds = motorized vehicle with pedals that can be used as on a bicycle. You just have to pay the mandatory insurance, which is about 9 pounds a year. You don't even go to MOT. Thumbs Up
PostPosted: 09:48 - 03 Mar 2014    Post subject: Reply with quote
Loving the bell. Thumbs Up
garth
PostPosted: 10:18 - 03 Mar 2014    Post subject: Reply with quote
I've heard that about you before.
PostPosted: 10:23 - 03 Mar 2014    Post subject: Reply with quote
Is that in your new line of work? You can't listen to everything they say in that knocking shop. They're not to be trusted. Thumbs Up
nerald
PostPosted: 20:35 - 03 Mar 2014    Post subject: Reply with quote
It is registered. I can insure it for £50 fully comp - The Wife can get it for £53 third party - she only has moped entitlement and has no experience whatsoever - Both quotes were with zero NCD.
V-Twins - 60 or 90?
The last post was made 12 years, 187 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 92.38 Kb
