| dn38416 |
 dn38416 Nitrous Nuisance
| bodger |
 bodger Nova Slayer
| doggone |
 doggone World Chat Champion
| lukamon |
 lukamon World Chat Champion
 Posted: 18:56 - 01 Mar 2014 Post subject: |
yes, mine seized in too. I had to whack it quite a bit from the nut end to get it out. having a glamorous assistant turn the bolt head from the other side while you tap it will also help
tip: put block of wood between your hammer and the spindle or you will very easily fuckup the first couple of threads meaning the nut wont go back on and you need a new spindle
also; cover the spindle in a smear of LM (not coppaslip) grease on refit  ____________________ killa wrote: Im an ass man myself |
| dn38416 |
 Posted: 11:33 - 02 Mar 2014 Post subject: |
Thanks for the info guys, knocked it out in the end, luckily without damaging the end threads. Suppose being outside the whole of winter didn't help will invest in some proper grease.
When I went to undo the rear sprocket nuts though it just seemed as if i was rounding them off, tried the closest socket & spanner sizes i had but still no good fit, so I just changed the front sprocket and chain.
Put on a brand new DID chain and tightened up, but the slack is uneven (range from 2cm at the masterlink to >4cm), is there any other reason for that? |
| doggone |
 Posted: 11:38 - 02 Mar 2014 Post subject: |
| dn38416 wrote: | Thanks for the info guys, knocked it out in the end, luckily without damaging the end threads. Suppose being outside the whole of winter didn't help  will invest in some proper grease.
You can getaway with just changing the chain if the sprockets are reasonable, but it won't last as long as all new so false economy really.
If you are looking to sell it shortly no big problem, at least it won't fail for a few thousand miles. |
| dn38416 |
| Vincent |
 Vincent Banned
The last post was made 12 years, 263 days ago. Instead of replying here, would creating a new thread be more useful? |
