Removing rear axle spindle on CBF 125
dn38416
PostPosted: 17:04 - 01 Mar 2014    Post subject: Removing rear axle spindle on CBF 125 Reply with quote
In the process of replacing the rear sprocket, I'm following the Haynes manual.
Undone the rear axle nut and the brake rod, and the other rear brake arm connection - so everything on the right side. Loosened both the chain adjusters to the max. Now the manual shows the spindle being removed effortlessly from the left side, I can't seem to get any movement on it at all, (tried a hammer but that only takes the right side to the swingarm). Is there another pin or something that i'm overlooking? I have no idea how i'm going to get the rest of it through.
bodger
PostPosted: 17:27 - 01 Mar 2014    Post subject: Reply with quote
Yours should push out now
In an ideal world the axle would push out easily but they do seize in sometimes.
Is there any way you can twist the axle from the left side of the bike to get the thing moving. Some have a hole through the end of it.
Use a drift (steel rod or old bolt) carefully on the nut side of axle to try to free it. Careful not to damage threads.
Spray releasing fluid to help it along
doggone
PostPosted: 17:28 - 01 Mar 2014    Post subject: Reply with quote
It's probably just corroded and stuck.
I don't know that bike, there isn't some kind of pinching bolt like a front axle surely?
Try turning it and soak with WD40 or similar.
lukamon
PostPosted: 18:56 - 01 Mar 2014    Post subject: Reply with quote
yes, mine seized in too. I had to whack it quite a bit from the nut end to get it out. having a glamorous assistant turn the bolt head from the other side while you tap it will also help Thumbs Up
tip: put block of wood between your hammer and the spindle or you will very easily fuckup the first couple of threads meaning the nut wont go back on and you need a new spindle Embarassed
also; cover the spindle in a smear of LM (not coppaslip) grease on refit Thumbs Up
killa wrote: Im an ass man myself
dn38416
PostPosted: 11:33 - 02 Mar 2014    Post subject: Reply with quote
Thanks for the info guys, knocked it out in the end, luckily without damaging the end threads. Suppose being outside the whole of winter didn't help Crying or Very sad will invest in some proper grease.
When I went to undo the rear sprocket nuts though it just seemed as if i was rounding them off, tried the closest socket & spanner sizes i had but still no good fit, so I just changed the front sprocket and chain.
Put on a brand new DID chain and tightened up, but the slack is uneven (range from 2cm at the masterlink to >4cm), is there any other reason for that?
doggone
PostPosted: 11:38 - 02 Mar 2014    Post subject: Reply with quote
Rolling Eyes
You can getaway with just changing the chain if the sprockets are reasonable, but it won't last as long as all new so false economy really.
If you are looking to sell it shortly no big problem, at least it won't fail for a few thousand miles.
dn38416
PostPosted: 11:44 - 02 Mar 2014    Post subject: Reply with quote
Yeah I've got a new rear sprocket, just ran out of time to do it. The teeth didn't look too bad on the old one but like you say all new would be better.
So are you saying the uneven chain slack is likely down to wear on the rear sprocket?
The last post was made 12 years, 263 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 57.39 Kb
