MOT approaching
CG Sam
PostPosted: 18:38 - 01 Mar 2014    Post subject: MOT approaching Reply with quote
Hi all, not entirely sure if this should be here or in the new bikers section but I guess it counts as both. My bike is coming up to it's MOT and I was just wondering what they can fail on?
I know tyres, brakes, mirrors, blowing exhaust etc but are there any other things that aren't necessarily obvious that bikes fail on?
Thanks,
Sam
CG125, SV650S, CBR600F, GSXR600 SRAD
wr6133
PostPosted: 18:41 - 01 Mar 2014    Post subject: Reply with quote
Wheel bearings, easy to check but people often don't
doggone
PostPosted: 19:03 - 01 Mar 2014    Post subject: Reply with quote
Worn steering head bearing is another one that's easily overlooked.
Also the number plate light is easily forgotten if it's separate from the tail light.
PostPosted: 19:04 - 01 Mar 2014    Post subject: Re: MOT approaching Reply with quote
Thanks,
Sam
It's all here
https://www.motuk.co.uk/manual/mc_contents.htm
Very straightforward really, check the obvious.
clancy
PostPosted: 19:37 - 01 Mar 2014    Post subject: Reply with quote
Buckled wheels, distorted bead rims aren't always obvious
Steering bearings as well are often classed as "notchy"
All three can easily be checked with the front wheel off the ground.
Most other things are obvious like you said mate
KLX 300r
CG Sam
PostPosted: 19:40 - 01 Mar 2014    Post subject: Reply with quote
Am I right in thinking that to check the bearings you put the bike on it's centre stand and spin each wheel looking for smooth rotations, no or little elliptical movement and no knocking sounds?
The steering head is checked by moving the bars from full lock to full lock while on the stand isn't it?
Cheers for the link, about to read through it all now.
If I ask to watch the MOT be done will garages allow it?
brains_t
PostPosted: 19:43 - 01 Mar 2014    Post subject: Reply with quote
Delboy's you're friend
Pre MOT check
https://www.youtube.com/watch?v=uSC0MmS65qo
clancy
Yeah that's how you check all that mate
When looking for buckled wheels look along the wheel and side on from either side, large flat spots can be seen side on
Yeah they will let you watch mate, larger garages normally have a viewing area
KLX 300r
doggone
PostPosted: 19:44 - 01 Mar 2014    Post subject: Reply with quote
The one I go to is a one man band and needs me to help e.g hold brakes on while he puts a measured force on to test them.
It will vary, some won't be keen on anyone in workshop areas.
PostPosted: 19:51 - 01 Mar 2014    Post subject: Reply with quote
Grab the wheel at the top and try rocking it from side to side, not in the direction of the rotation, if you see what I mean. If there's any play then it's likely your bearings need replacing. It's an easy job.
FROGGYRIBBIT
PostPosted: 19:53 - 01 Mar 2014    Post subject: Reply with quote
Leaking forks
binding brakes
If it aint broken dont fix it
CG Sam
PostPosted: 20:33 - 01 Mar 2014    Post subject: Reply with quote
Cheers for all the advice, one last question. My front mudguard is cracked, is that something they could fail it on?
clancy
PostPosted: 20:40 - 01 Mar 2014    Post subject: Reply with quote
If its connected it had to be secure, if it's not there they can't test it
So remove it for the mot mate, might as well play it safe, would such to fail for something that little
KLX 300r
PostPosted: 20:51 - 01 Mar 2014    Post subject: Reply with quote
They COULD, depends on the testers oppinion/mood as to what constitutes "insecure".
I personally would tape over the crack with a bit of gaffa tape because a CG125 front mudgsard has an integral, pressed steel fork brace. The mudguard itself isn't required but the fork brace is.
Most places do free retests for minor fails so don't worry too much if it fails on something small like a cracked mudguard or incorrect healamp aim, you can go away, fix it and come back to show them it working the next day (I have been known to change wheel bearings on the pavement outside the MOT station).
Classic is flashers and horn which always seen to pick on the way to the MOT as the perfect time to stop working.
CG125s commonly fail on leaky fork seals, oval rear brake drums and loose spokes. MOT testers do love to ping spokes. Small cracks round the vent holes in brake discs (if fitted) are another favourite.
Nobby the Bastard
Harley Gaydar
PostPosted: 21:39 - 01 Mar 2014    Post subject: Reply with quote
To be frank, if something that goes through the sort of stresses as a brake disk has a crack of any size in it, I'll be throwing the fucker away before it fails and results in the bike cartwheeling down the road.
Triumph Sprint ST 1050
CG Sam
PostPosted: 22:49 - 01 Mar 2014    Post subject: Reply with quote
I actually have a spare mudguard, but I'm being lazy and it's not the right colour, I'll just swap it in the morning. My fork seals are fine, not had a spot of oil out in the time I've had her, no pitting on the forks either.
Cheers for all the help, will let you know how it goes. The previous MOT had one advisory for a binding front brake which we sorted before I even got her to mine.
The last post was made 12 years, 264 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 88.32 Kb
