it wont stall ?
drbaig
PostPosted: 01:33 - 02 Mar 2014    Post subject: it wont stall ? Reply with quote
Noticed something today. After letting the clutch go slowly, slipping it the bike kept on moving without and throttle. If i let go of the clutch suddenly it stalls but if i release it slowly it wont stall. It is as thundercat btw.
Any idea what is causing this ?
Maybe that is the cause of my poor fuel economy I am getting about 35-8 mpg. Apparently cats are supposed to get over 45 with ease.
yzf 600r Very Happy
PostPosted: 01:42 - 02 Mar 2014    Post subject: Reply with quote
Is this while stationary?
If you can let the clutch out with the bike in gear and not move forward or stall out, it is slipping horribly. This being the case, unless the cable is over-tight or the external clutch mechanism is somehow sticking, you need to drain down the oil, whip the cover off, strip down the clutch and have a look to see what's wrong. I'd go for a badly notched clutch basket or totally worn out or broken clutch plates
If it's moving forward when you let the clutch out slowly at idle speed in gear, congratulations on your fine clutch control.
drbaig
PostPosted: 02:14 - 02 Mar 2014    Post subject: Reply with quote
Two scenarios.
At stationary, let the clutch out completely and suddently. Bang, stalled.
At stationary, let the clutch out slowly, feel the bite, slip it and eventually completely release. At this point the bike just keeps going without any throttle.
I only noticed it today when I was looking for a parking and I had almost completely let the clutch out slowly whilst feathering it and the bike kept moving without any throttle. I had expected it to stall but it didn't. So I braked, pulled the clutch in, let it go without riding it and it stalled so I was a bit confused.
It was in my mind so when I was home I just went round the block without using the throttle, just let the clutch out slowly, felt the bite, bike started moving slowly and by the time I had released the clutch fully it just kept on going at a crawling rate without stalling. I don't know if it is normal. That's why the post at 2am hah!
yzf 600r Very Happy
Nipedley
PostPosted: 02:27 - 02 Mar 2014    Post subject: Reply with quote
Most bikes will ride just fine (and slowly) with no throttle and the clutch out, that's not unusual
If it stalls if you dump the clutch, and moves when you let it out, then it sounds like it's fine
Unlike my CBR which slowly slipped more and more until I could let the clutch out fully (and adjusted correctly) and the bike wouldn't even try to move. Full throttle with the clutch out and not moving is an odd thing
That seems pretty normal to me.
I can get my VFR into fourth without touching the throttle.
evilbond
PostPosted: 02:29 - 02 Mar 2014    Post subject: Reply with quote
Id say its quite normal.
It's also how the instructor initially introduced the clutch to me on the CBT before adding in throttle.
Works in my car too, so normal:)
Bike: K2 Bandit 600S
Car: Astra GTC
janner_10
PostPosted: 07:29 - 02 Mar 2014    Post subject: Reply with quote
First big bike? Sounds like it and your imagining all sort of non-existent faults.
sounds to be working perfectly from what you describe.
Clutchy
PostPosted: 07:32 - 02 Mar 2014    Post subject: Reply with quote
You can do the same in a car, but don't tell anyone! Shhh!
Laughing Laughing Laughing Laughing
gavbriggs
PostPosted: 07:39 - 02 Mar 2014    Post subject: Reply with quote
You can't in my automatic, I've tried letting the clutch out but the damn thing must be out already Mr. Green
weasley
PostPosted: 09:20 - 02 Mar 2014    Post subject: Reply with quote
Most decent sized engines will be able to propel their vehicle using the torque available at idle; my Cat will happily trickle along at idle in first and second (although, to be honest, it does get a bit lurchy). Suddenly releasing the clutch at idle in pretty much any vehicle will stall it.
Your fuel economy does sound low though; I get low to mid 50s out of mine, even when riding enthusiastically - 180 miles to a tank is easily achievable (a constant 100+ mph chase across Germany/Belgium/France to catch a Eurotunnel train did dent that somewhat).
Causes of your poor economy? Could be many things:
- binding brakes
- poorly set up carbs
- short journeys and/or aggressive riding
- fuel leak
- poor mpg calculation technique
- etc
drbaig
PostPosted: 14:13 - 02 Mar 2014    Post subject: Reply with quote
LoL. So its normal. Thanks.
Funny thing is I've been driving since donkeys and still haven't tried such a thing so never knew. Only feather the clutch on the bike because as taught to do so on the cbt. Learnt something new.
Calculating mpg. 130 miles till the light comes on. 15.9 ltrs, 4.54 ltrs in a gallon. I think I'm calculating alright. I do a lot of short journeys of about 4 to 5 miles. Brakes were binding so only last month rebuilt the calipers, also balanced carbs a few months back after checking the air filter and spark plugs. I think I've come to the conclusion that I need to reduce the Ham fisted throttle to get better mileage.
But thank you for all the helpful and sarcastic responses. Laughing
yzf 600r Very Happy
drbaig
PostPosted: 14:14 - 02 Mar 2014    Post subject: Reply with quote
yzf 600r Very Happy
PostPosted: 14:52 - 02 Mar 2014    Post subject: Reply with quote
You can stick it all in to google by the way.
https://www.google.co.uk/search?q=130+miles/15.9+litres+in+miles+per+imperial+gallon
The last post was made 12 years, 264 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 87.46 Kb
