So I'm guessing these pads are worn then...
Rigga
PostPosted: 13:09 - 02 Mar 2014    Post subject: Reply with quote
I think sintered are better in the wet, well they are on my mountain bike anyway Laughing
Current bike: Honda CBR 1100xx
DrDonnyBrago
PostPosted: 13:13 - 02 Mar 2014    Post subject: Re: So I'm guessing these pads are worn then... Reply with quote
They don't look that worn, quite a bit of meat left by the looks of it. The metal plate is the back plate whilst the shiny bit stuck to it just looks like sintered pad material.
Sintered pads are made from metal and other powders fused together in a process called sintering.
They just generally perform better than organic pads, look it up if you wish, could fill a book with it so not much point summarising it here. They are especially good in the rain on a wet brake disc.
Price isn't normally much different IME, I always go for HH sintered on the front though and whatever I can find cheap for the back.
Easter Bunny
PostPosted: 13:35 - 02 Mar 2014    Post subject: Reply with quote
I've had em down to the metal before, makes a nice noise Laughing
PostPosted: 13:37 - 02 Mar 2014    Post subject: Re: So I'm guessing these pads are worn then... Reply with quote
Not all pads have grooves.
Looks like there's life in them yet to me.
Sintered have bits of metal squished in to them, which should let the pads handle with more extreme situation as well as giving better braking in all conditions.
bugeye_bob
PostPosted: 13:43 - 02 Mar 2014    Post subject: Reply with quote
https://i703.photobucket.com/albums/ww33/JDM_Stig/IMAG0078_zps4382cbd8.jpg
They look safer then these rear pads, this was after they had just passed an MOT!
almostthere
PostPosted: 14:19 - 02 Mar 2014    Post subject: brake pads Reply with quote
Also looks good at night when you get a shower of sparks every time you brake Laughing
Beer, It's the reason I get up every afternoon
www.mfairco.uk
PostPosted: 14:23 - 02 Mar 2014    Post subject: Reply with quote
How does the brake lever feel usually? Hard or spongy? Obviously now there won't be much resistance with the pads out with nothing pushing against the disc. Although with the pads out you can have a look to see if the brake piston is moving freely.
evilbond
PostPosted: 15:29 - 02 Mar 2014    Post subject: Reply with quote
MC wrote:
Hmm... I thought they were meant to have wear grooves, maybe that's just original pads?
Try taking a wire brush over it firmly, i cleaned up my front brakes recently and it too looked like a smooth surface untill i brushed them and the grooves magically appeared :o
They were caked in brake dust then the edges of the pads had worn into the grooves and filled em.
Bike: K2 Bandit 600S
Car: Astra GTC
STONEY!
PostPosted: 15:39 - 02 Mar 2014    Post subject: Reply with quote
I'd run with those pads for miles yet, then again I superglued the friction material back on my superdreams pads lol
serlant
PostPosted: 16:00 - 02 Mar 2014    Post subject: Reply with quote
this is fucked
https://i191.photobucket.com/albums/z170/serlant/IMAG0182_zpsgv0axkdo.jpg
i'd say they've got 1 or 2 thousand in them atleast
04 CBR1000RR, 1995 Husqvarna TE410, 1998 VTR1000(Sold), 1990 XJ600(sold), 1996 KH125(dead and sold)
flumpy7
PostPosted: 16:18 - 02 Mar 2014    Post subject: Reply with quote
MC wrote:
Last couple of days felt a bit weak, hence why I took the pads out to have a looksy. Sometimes the front brake feels a little squirrely, (very) occasionally it'll squeak. I was scared of touching the front brake with the pads out, as I read something about the piston locking onto the disc & being a bitch to push back (dunno if that's true or not).
Yeah think about it makes sense. There's no pads so the piston will keep coming out until they trap the disc or fall out. Obviously you would need to pump a good few times for that to happen. If you want to test the caliper function, take it off the disc and pump a little to see if the pistons come out smoothly, then push back in by hand and if its all nice and clean it should go back easily. If not clean em up Thumbs Up
2012 Sinnis apache
andyscooter
PostPosted: 17:10 - 02 Mar 2014    Post subject: Reply with quote
i had a garage do that to a bike of mine as they bought the wrong ones
they glued cut down the back plate and glued the pads onto the original ones to fit
smegballs
PostPosted: 17:45 - 02 Mar 2014    Post subject: Reply with quote
It's not actually that outlandish.
In days gone by, you could get your brake shoes refurbed with fresh friction material, same for clutch friction plates too.
There must be a few people still doing it, I'd imagine it's one of the only way to keep ancient cars/bikes on the road.
STONEY!
PostPosted: 18:36 - 02 Mar 2014    Post subject: Reply with quote
yep, there's a guy near me who refurbs brakes and clutches with new material and rivets. £40 to refurb a chevy clutch that is near on impossible to get hold of.
I think a shop gluing your pads together is taking the mick a bit not to mention a potential lawsuit against them! but I guess if they made it completely clear to you what they where doing its fine.
andyscooter
PostPosted: 19:42 - 02 Mar 2014    Post subject: Reply with quote
I didn'tfind out till a week or so later when they fell off
Changed mechanic after that
Also found iI had been charged for service work not done as well
Rigga
PostPosted: 19:47 - 02 Mar 2014    Post subject: Reply with quote
Shocking! Did they own up to it?
janner_10
PostPosted: 05:35 - 03 Mar 2014    Post subject: Reply with quote
Taken worse off to be fair. They don't look a critical.
Alienfish360
PostPosted: 09:02 - 03 Mar 2014    Post subject: Reply with quote
Rode with far worse.
I rely on the built in wear indicator, makes a metal on metal noise
Islander
PostPosted: 11:05 - 03 Mar 2014    Post subject: Reply with quote
Those pads are fine. When they get down to around 1.5mm it's time to change them. If the brakes aren't responsive enough perhaps it's time to clean the calipers and pistons and bleed the system. Thumbs Up
PostPosted: 12:24 - 03 Mar 2014    Post subject: Reply with quote
Vincent wrote:
Unless you want to remove the pistons, don't pull the brake lever while the pads are removed or the caliper is off the bike.
How do you clean your brake pistons then?
The last post was made 12 years, 262 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 127.97 Kb
