| ice.shark |
 ice.shark Nova Slayer
 Posted: 14:09 - 02 Mar 2014 Post subject: |
It is worth checking the battery. If the battery is shot then it will probably fail to hold charge and that might well cause odd problems. But on the other hand it does seem to have managed to charge the battery and the bike wasn't parked up for long so I would suspect the battery itself isn't the main culprit. However also check the charging (put a volt meter over the battery and check what the voltage does with the engine idling, and what it goes up to when revved).
My main concern would be the carb though. There is not much cleaning you can do without removing the float bowl. 14mm spanner required. The large bolt also holds the main jet.
| ice.shark |
 Posted: 16:06 - 02 Mar 2014 Post subject: |
The number on the NGK plugs is the heat rating, with a higher number being a colder plug for a hotter running engine. The basic difference is the amount of insulation around the electrode (and so how much heat it transmits out). The higher number plugs should have less insulation to take more heat out and so reduce the combustion temp a touch, but mainly give the spark plug electrode a far easier life. Shouldn't make a big difference to the engine tempt (should be more than enough reserve cooling capacity to make that a non issue).
The 8 would probably be fine at normal speeds, just might not be a good idea if you take the bike out and thrash the nuts off it! Too high a number plug will result in it fouling up more easily (especially around town), while too low a number will result in the electrode over heating and the insulation blistering
The large bolt shouldn't be that tight really, so take care undoing it if someone has over tightened it.
| ice.shark |
 Posted: 21:17 - 02 Mar 2014 Post subject: |
The mod to the cdi unit makes no difference to peak power at all. The RS had a deliberate massive flat spot between ~5k and 6k caused by a load of ignition retard. The cdi has both ignition maps and the mod cuts a bridge on the circuit board triggering it to use the decent map. Shouldn't make any difference to the plug required or jetting, etc.
The real derestriction is fitting a working power valve (and if poss a decent exhaust).
Don't think the 8 plug would cause any issues at idle. No load so I would doubt any heat issues for the plug; might well even be better than a 10 as it would be less prone to fouling up. However thrashing it with that plug could cause problem, potentially major ones.
The 9 is sometimes used as a compromise that shouldn't foul as easily as a 10 but hopefully won't cause problems with the plug melting in normal road use.
| m3-paul |
 m3-paul Spanner Monkey
| bypass2 |
 bypass2 Spanner Monkey
| ice.shark |
| m3-paul |
| ice.shark |
The last post was made 12 years, 262 days ago. Instead of replying here, would creating a new thread be more useful? |
