Aprilia RS 125 idle's and dies
ice.shark
PostPosted: 09:31 - 02 Mar 2014    Post subject: Aprilia RS 125 idle's and dies Reply with quote
Hi guys,
So I have an aprilia rs 125. It's been sitting in the garden since December. This weekend I took it out and serviced it myself. The problem is that it starts first time at the moment (choke full on) but the idle revs slowly drop and drop and it dies. Actually, I have to ride with the choke on all the time because if I stop at a traffic light and let it idle without choke it will die almost as soon as I release the throttle. With choke on it takes up to a couple of minutes. I also give it a bit of throttle when still just to make sure that it does not die.
Here is what I've done so far:
1. When I took the bike out, battery was at 11.55V. I charged it with Optimate4 to about 12.7V (charger wasn't finished but I wanted to ride).
2. Changed the sparkplug. Old one had heavy carbon deposits so bike wouldn't start.
3. I've also had the carb off and I sprayed into each hole with halfords carburetor cleaner. I couldn't take the float bowl off as the bolt wouldn't bulge.
Took it for a ride today. Engine died several times so I had to start it several times. I eventually parked in my office and went for a coffee. Came back (bike was still warm) but it wouldn't start. I think the battery has died (it sounded/appeared so).
The bike is '05 and has the 28mm carb. I've screwed the air pin to max and turned back 2 turns. The idle screw is as much as it can go clockwise. If the bike is idling at about 1900rpm (full choke) an I twist this screw, the revs drop and eventually it dies.
Could the choke cable be loose? Maybe I need to tighten it? This is the first time I rode the bike since I bought it second hand.
I'm going over to the bike with my car and some tools to see what's happening. I'm almost certain the battery is flat. This, however, does not solve the issue with the idle which is why I believe the battery went flat so quickly - I had to start it up 7-10 times in the period of 30-45 minutes.
I have optimate4 at home. I might buy a second battery but I would rather buy a portable charger. Anyone have any experience with anything like that? I'm going to halfords to get one probably. The battery is really hard for me to get out so I don't want to do it very often. I have a charger lead connected but the nearest socket is few hundred feet away.
PostPosted: 14:09 - 02 Mar 2014    Post subject: Reply with quote
It is worth checking the battery. If the battery is shot then it will probably fail to hold charge and that might well cause odd problems. But on the other hand it does seem to have managed to charge the battery and the bike wasn't parked up for long so I would suspect the battery itself isn't the main culprit. However also check the charging (put a volt meter over the battery and check what the voltage does with the engine idling, and what it goes up to when revved).
My main concern would be the carb though. There is not much cleaning you can do without removing the float bowl. 14mm spanner required. The large bolt also holds the main jet.
ice.shark
PostPosted: 15:36 - 02 Mar 2014    Post subject: Reply with quote
Thanks Keith,
I have the tools for the job -it's just that the bolt is stuck. I removed the carb and then tried to undo it. I think I should have left the carb in and then try to undo it while the carb is fastened to the inlet manifold and the air filter. This should hold the carb body and allow me to undo it.
The guy who I bought the bike from said it was full power/derestricted. The spark plug that I have is the 8ES one (which is for restricted bikes and makes the engine run cold). I wonder if this could be causing poor idling?
I'll check the carb bowl. The bike is now stuck in a parking lot.
EDIT: It's ironing that where I live, just 5 minutes away from my front door there is a fantastic bike shop and the guys there appear to be excellent motorcycle mechanics who take seriously what they do. I rang them up today and the guy said that they don't do aprilias. I'm not sure why - it's a bike like any other. They do harley,s and Japanese bikes and I've seen scooters...
PostPosted: 16:06 - 02 Mar 2014    Post subject: Reply with quote
The number on the NGK plugs is the heat rating, with a higher number being a colder plug for a hotter running engine. The basic difference is the amount of insulation around the electrode (and so how much heat it transmits out). The higher number plugs should have less insulation to take more heat out and so reduce the combustion temp a touch, but mainly give the spark plug electrode a far easier life. Shouldn't make a big difference to the engine tempt (should be more than enough reserve cooling capacity to make that a non issue).
The 8 would probably be fine at normal speeds, just might not be a good idea if you take the bike out and thrash the nuts off it! Too high a number plug will result in it fouling up more easily (especially around town), while too low a number will result in the electrode over heating and the insulation blistering
The large bolt shouldn't be that tight really, so take care undoing it if someone has over tightened it.
ice.shark
PostPosted: 21:03 - 02 Mar 2014    Post subject: Reply with quote
Thanks mate. My bike seems to be derestricted/full power. I've looked at the CDI and there is a hole filled with transparent silicone at the back of it (I assume that means it's derestricted). The bike has BR8ES plug and it idles poorly. I assume I need a BR10ES?
Wouldn't BR9ES/BR9EG be better for city driving? I've heard you can do quite a bit of damage with a wrong spark plug so a bit cautions. I have a BR9ES and I'm thinking of fitting it. If it idles better, that should mean that the plug is to blame.
PostPosted: 21:17 - 02 Mar 2014    Post subject: Reply with quote
The mod to the cdi unit makes no difference to peak power at all. The RS had a deliberate massive flat spot between ~5k and 6k caused by a load of ignition retard. The cdi has both ignition maps and the mod cuts a bridge on the circuit board triggering it to use the decent map. Shouldn't make any difference to the plug required or jetting, etc.
The real derestriction is fitting a working power valve (and if poss a decent exhaust).
Don't think the 8 plug would cause any issues at idle. No load so I would doubt any heat issues for the plug; might well even be better than a 10 as it would be less prone to fouling up. However thrashing it with that plug could cause problem, potentially major ones.
The 9 is sometimes used as a compromise that shouldn't foul as easily as a 10 but hopefully won't cause problems with the plug melting in normal road use.
m3-paul
PostPosted: 21:18 - 02 Mar 2014    Post subject: Reply with quote
I have never owned let alone worked on an rs125 but on every 2T I have owned, if when trying to start the bike it doesn't idle and dies then cleaning the pilot jet(s) has in the main sorted the issue.
Yamaha TZR250 - love the smell of TTS!!!!
CBR900RR Fireblade - so much fun
bypass2
PostPosted: 21:44 - 02 Mar 2014    Post subject: Reply with quote
what about petrol starvation.as said give the jets a clean. how old is the petrol
ice.shark
PostPosted: 22:22 - 02 Mar 2014    Post subject: Reply with quote
There was a bit of petrol that was about 3 months old (not more). It was only a bit. I put in 5L of some of that good stuff the other day.
However, I have just fitted a new battery and I also put a BR9ES spark plug. With the BR8ES, the plug goes black almost as soon as the bike is run for a bit. The previous owner put a new plug in before i got it which was as black as it gets and I put a new plug in this morning, rode it for 30 minutes and the plug is black again.
With the new plug (BR9ES), there is still a cloud of smoke that comes out of the exhaust when the engine is cold started. Is that OK/expected?
EDIT: Also, not sure if it's relevant but I tightened the BR8ES plug pretty well (probably shouldn't have). When I tried to take it out, it was very easy. It didn't look very well done - it looked as though it's gotten loose.
EDIT2: With the choke open fully, the idle twisted clockwise as much as possible and the engine cold, the bike now idles at 3000rpm. I think BR9ES is a step in the right direction. Not sure if I need BR10ES (any benefit of an EG?). I only do short trips in 30/40 zones.
PostPosted: 22:24 - 02 Mar 2014    Post subject: Reply with quote
You will get smoke from a 2 stroke most of the time when starting.
Note that a 9 plug will foul up quicker than an 8. You do need to check the jetting and that the idle jet is clear, and for that you need to take the float bowl off
m3-paul
PostPosted: 22:28 - 02 Mar 2014    Post subject: Reply with quote
As kickstart says, when a 2t is started from cold on choke it will smoke, a lot. My tzr250 is pretty smokey when cold on choke and has the merest of smoke visible when still hot after a sound thrashing.
ice.shark
PostPosted: 20:54 - 03 Mar 2014    Post subject: Reply with quote
Thank you both. After the battery change and the plug change (using BR9ES) bike runs fine (well to me it appears to be fine). I might still take out the carb and clean it but I just want to ride for a bit. It's my first bike.
The last post was made 12 years, 262 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 80.54 Kb
