Help with my ybr custom
James2012
PostPosted: 19:59 - 02 Mar 2014    Post subject: Help with my ybr custom Reply with quote
First off I have little to no bike knowledge apart from how to ride it.. One problem is that my engine cuts out sometimes when sat in idle and sometimes when I pull away... It normally takes around ten minutes to do so... The starting revs are at 2 and then they slowly move down to 1.5 is this normal?? And the second problem is that when I went to change the air filter the box had lots of either water/ oil in with a white/creamy substance?? What could be causing that and are they linked???
Many thanks in advance
Regards Cool Cool Cool
Still trying to learn
PostPosted: 20:46 - 02 Mar 2014    Post subject: Reply with quote
Hi James.
Fuel injected model? I'd expect it to rev a bit higher when cold. The cutting out when warm is the idle dropping too low. Could be...
YBR Ric wrote:
Tickover adjustment will be by way of an anticlockwise twist of the small brass screw found on the right hand side of the injector body when engine is at normal working temperature. 1300-1500rpm is book recommendation for idle speed.
Try 1/2 turn first.
...or the temperature or lambda sensors being a bit screwy. I'll leave that to the YBR owners.
The crankcase vents into the air box, so you should expect to find some condensed vapours in there. If there's a lot in there, it could be that the air filter was manky and the engine has been sucking from the crankcase - my Burgman is notorious for doing it.
The mayonnaise you're seeing is an emulsion of oil and water. It's a symptom of doing short runs where the engine doesn't get up to high enough temperatures to boil the water out of it. There's nothing you can do about it except ride longer, or change the oil more regularly.
James2012
PostPosted: 21:29 - 02 Mar 2014    Post subject: Reply with quote
Rogerborg wrote:
Hi James.
Try 1/2 turn first.
The crankcase vents into the air box, so you should expect to find some condensed vapours in there. If there's a lot in there, it could be that the oil filter was manky and the engine has been sucking from the crankcase - my Burgman is notorious for doing it.
Yes it's fuel injected
If the idle is dropping too low do you know how to adjust it??? Thanks for your reply
The last post was made 12 years, 263 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 38.7 Kb
